mirekns
Limit connection VPN
Thu Nov 05, 2020 12:49 pm
Hello
I have problem with my VPN. Only 10 users may connection to VPN in this same time, where I may change this value.
My device: RB4011iGS+5HacQ2HnD
Licence: 5
thanks for your help
cdiedrich
Forum Veteran
Forum Veteran
Re: Limit connection VPN
Thu Nov 05, 2020 1:28 pm
Your question is a bit ambigous.
Do you have a problem that only ten users can connect concurrently and you want more users or do you want to limit the amount of concurrent vpn connectios to a total of ten?
Either way, post an export of your config and we can see to find a way to accomplish the one or the other with you.
-Chris
mirekns
Re: Limit connection VPN  [SOLVED]
Thu Nov 05, 2020 1:51 pm
I find solution:
PPP->Interface->PPTP Server/L2TP Server->Max Session
wpyung
Tue Aug 24, 2021 2:59 pm
I have the same issue, only 5 users can connect.
The 6th users gets a message a connection could not be established to the PPP server
I have changed the mas sessions setting but it does not help.
[admin@MTK-DeanSt] /interface l2tp-server server> print
enabled: yes
max-mtu: 1450
max-mru: 1450
mrru: disabled
authentication: chap,mschap2
keepalive-timeout: 600
max-sessions: 12
default-profile: profile-vpn1
use-ipsec: yes
ipsec-secret: ***************************
caller-id-type: ip-address
one-session-per-host: no
allow-fast-path: yes
MikroTik RouterOS 6.48.3
wpyung
Tue Aug 24, 2021 4:09 pm
see log
result code 256 and 768
wpyung
Tue Aug 24, 2021 4:29 pm
I have fixed the issue. My vpn pool and had 10 addresses. I have increased this to 30, and more than 5 users can now connect
Users browsing this forum: No registered users and 96 guests
