JimLafleur
2 separate subnets on 2 different router's ports
Thu Nov 19, 2020 3:20 am
I'm a total newbie to MikroTik and RouterOS.
I have lots of experience with Asus (Merlin), TP-Link, D-Link routers and the like ("normal routers"). Some experience with DD-WRT an Ubiquiti Unifi.
I'd need a little help on this one please.
I'll explain my goal and hopefully someone will point me in the proper direction or give me simple, step-by-step instructions.
Here's what I have : Mikrotik hEX RB750Gr3 5-port Ethernet Gigabit Router, with RouterOS 6.47.7
The goal:
  • I want to have 2 separate networks on 2 different ports of the router
  • Port 4 goes to switch A.
  • Port 5 goes to switch B.
  • Internet Port (Port 1) goes to the internet. Static IP.
  • The 2 networks need to be able to access the internet.
  • The 2 networks cannot communicate with each other.
  • Below I assume we'll use VLANs to separate the networks, but maybe there's another way to do it?
  • Port 4:
    Subnet A: 192.168.5.1 /24
    VLAN #4
  • Port 5:
    Subnet B: 10.10.10.1/24
    VLAN #5
  • Subnet A will have a DHCP server on.
  • Subnet B will NOT have a DHCP server (all of device there must be static IP'd, so I don't want a DHCP server)
So there it is. I'm pretty sure that must be very easy stuff for some you guys. Some input would be greatly appreciated.
tdw
Long time Member
Long time Member
Re: 2 separate subnets on 2 different router's ports
Thu Nov 19, 2020 3:56 pm
If you start with the default configuration that has ether1 configured as the WAN interface acquiring an IP address with DHCP client, and ether2-5 in a bridge configured as the LAN interface providing addresses with a DHCP server, along with a reasonable set of firewall and NAT rules.
If you only wish to have your two networks on individual and separate ports you can remove those ports from the bridge, add IP addresses to the ports, a DHCP server to one of them and firewall rules to block intercommunication without using VLANs.
However, if at some point you might want to make one of the networks available on more than one port, or to trunk the two networks over one port then using a single VLAN-aware bridge is preferable, there is a good primer on Mikrotik VLANs viewtopic.php?f=13&t=143620 and there are skeleton examples on the wiki https://wiki.mikrotik.com/wiki/Manual:I ... _Filtering
JimLafleur
Thu Nov 19, 2020 4:20 pm
Hi tdw,
That makes sense. I've found a tutorial on Youtube that does almost exactly what I need, using the same router as me. In his video, Net VN does what you say above.
He doesn't show how to block the traffic between the VLANS though. Would someone give me an example on how to do this?
Also I'll have to do some port forwarding. Some incoming traffic (Port 54110) from the internet will go to a device (192.168.5.215) on VLAN #4. Would someone give me an example on how to do this?
anav
Thu Nov 19, 2020 4:37 pm
Hi Jim, use the ref guide provided as the standard and be wary of youtube videos. Not saying the one you are accessing does not have some merit but there are often assumptions made by posters of the MT knowledge people have viewing the video
As soon as you are close to a working config feel free to post here for review
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
JimLafleur
Thu Nov 19, 2020 8:00 pm
OK,
Well can someone here post a few steps to get me started?
I think this should be pretty basic stuff. But since I'm new with VLANs and Mikrotik, I need help to get going.
Pointing me to documentation does help. But I'd like help from people with hands on experience for my specific case.
JimLafleur
Thu Nov 19, 2020 8:59 pm
Below, here's the config I have by now. If I connect the cable to port 4 I get an IP from DHCP server : 192.168.4.254. If I connect the cable to port 5 I get an IP from DHCP server : 192.168.5.254.
But I cannot ping 8.8.8.8 or go on the internet.
If I connect the cable to port 2 or 3, I get this IP : 192.168.88.254, and I can go on the internet.
What does prevent me from going on the internet on ports 4 and 5?
# nov/19/2020 14:46:09 by RouterOS 6.47.7
# software id = H2RB-DILS
# model = RB750Gr3
add admin-mac=C4:AD:34:91:1F:1B auto-mac=no comment=defconf name=bridge
add name=bridgeVLAN400
add name=bridgeVLAN500
/interface vlan
add interface=bridgeVLAN400 name=vlan400 vlan-id=400
add interface=bridgeVLAN500 name=vlan500 vlan-id=500
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_poolVLAN500 ranges=192.168.5.2-192.168.5.254
add name=dhcp_poolVLAN400 ranges=192.168.4.2-192.168.4.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_poolVLAN500 disabled=no insert-queue-before=bottom \
    interface=bridgeVLAN500 name=dhcpVLAN500
add address-pool=dhcp_poolVLAN400 disabled=no interface=bridgeVLAN400 name=\
    dhcpVLAN400
add bridge=bridgeVLAN400 comment=defconf interface=ether4
add bridge=bridgeVLAN500 comment=defconf interface=ether5
    192.168.88.0
add address=192.168.4.0/24 interface=bridgeVLAN400 network=192.168.4.0
add address=192.168.5.0/24 interface=bridgeVLAN500 network=192.168.5.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.4.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=192.168.4.1
add address=192.168.5.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=192.168.5.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/system clock
set time-zone-name=America/Moncton
/tool mac-server
/tool mac-server mac-winbox
anav
Thu Nov 19, 2020 11:09 pm
Only need one bridge!!
Create a homevlan for the 88 traffic,
Your IP addresses and dhcp servers should be the vlan interface not the bridge interface.............
Rules to add vlan access to internet but block all vlan traffic to each other in Green!!
add admin-mac=C4:AD:34:91:1F:1B auto-mac=no comment=defconf name=bridgehome
/interface vlan
add interface=bridgehome name=homevlan vlan-id=10
add interface=bridgehome name=vlan400 vlan-id=400
add interface=bridgehome name=vlan500 vlan-id=500
add address-pool=default-dhcp disabled=no interface=homevlan name=defconf
interface=vlan500 name=dhcpVLAN500
add address-pool=dhcp_poolVLAN400 disabled=no interface=vlan400 name=\
dhcpVLAN400
add bridge=bridgehome comment=defconf interface=ether2 frame-types=\
admit-only-untagged-and-priority-tagged pvid=10
add bridge=bridgehome comment=defconf interface=ether3 frame-types=\
add bridge=bridgeVLAN400 comment=defconf interface=ether4 ingress filtering=yes
add bridge=bridgeVLAN500 comment=defconf interface=ether5 ingress filtering=yes
add interface=homevlan list=LAN
add interface=vlan400 list=LAN
add interface=vlan500 list=LAN
add interface=homevlan list=admin
add address=192.168.88.1/24 comment=defconf interface=homevlan network=\
192.168.88.0
add address=192.168.4.0/24 interface=VLAN400 network=192.168.4.0
add address=192.168.5.0/24 interface=VLAN500 network=192.168.5.0
/ip dhcp-client
/ip dns static
[forward chain show]
add action=accept in-interface-list=LAN out-interface-list=WAN \
comment="allow lan to wan traffic"
add action=drop comment="drop all else"
/tool mac-server
set allowed-interface-list=LAN IF NOT USED SHOULD BE SELECTED TO NONE!
set allowed-interface-list=admin [assuming you dont want anybody on vlan400 or vlan500 to be able to access the router managment functions]
JimLafleur
Fri Nov 20, 2020 5:12 am
Thanks for that anav. I'll study it tomorrow. I've been working a new recipe (below). No Vlans this time. Internet works. LANs cannot communicate with each other. Any ways to improve this ?
# nov/19/2020 23:07:17 by RouterOS 6.47.7
# model = RB750Gr3
set [ find default-name=ether1 ] comment=WAN1 name=ether1-WAN1
set [ find default-name=ether4 ] comment=LAN1 name=ether4-LAN1
set [ find default-name=ether5 ] comment=LAN2 name=ether5-LAN2
/ip hotspot profile
add name=dhcp_pool0 ranges=10.10.40.2-10.10.40.254
add name=dhcp_pool5 ranges=10.10.50.2-10.10.50.254
add address-pool=dhcp_pool0 disabled=no interface=ether4-LAN1 name=dhcp1
add address-pool=dhcp_pool5 interface=ether5-LAN2 name=dhcp2
add address=10.10.40.1/24 interface=ether4-LAN1 network=10.10.40.0
add address=10.10.50.1/24 interface=ether5-LAN2 network=10.10.50.0
/ip dhcp-client
add disabled=no interface=ether1-WAN1
add address=10.10.40.0/24 gateway=10.10.40.1
add address=10.10.50.0/24 gateway=10.10.50.1
add action=drop chain=input dst-address=10.10.40.0/24 src-address=\
    10.10.50.0/24
add action=drop chain=input dst-address=10.10.50.0/24 src-address=\
    10.10.40.0/24
/ip firewall mangle
add action=accept chain=prerouting comment="Allow ping gateway LAN2" \
    dst-address=10.10.50.1 src-address=10.10.50.0/24
add action=accept chain=prerouting comment="Allow ping gateway LAN1" \
    dst-address=10.10.40.1 src-address=10.10.40.0/24
add action=masquerade chain=srcnat out-interface=ether1-WAN1
/system clock
aesmith
Fri Nov 20, 2020 2:43 pm
That's how I'd do it. If you only need each subnet on one interface only, no need for VLANs or bridges. Configuration can be applied directly to the interface.
Not sure on your filter rules, I would have thought they should be on chain "forward", as "input" refers to traffic received by the router itself rather than traffic to be forwarded.
JimLafleur
Fri Nov 20, 2020 4:13 pm
Hi Aesmith,
According to Mikrotik Manual:IP/Firewall/Filter :
  • input - used to process packets entering the router through one of the interfaces with the destination IP address which is one of the router's addresses. Packets passing through the router are not processed against the rules of the input chain
  • forward - used to process packets passing through the router
  • output - used to process packets originated from the router and leaving it through one of the interfaces. Packets passing through the router are not processed against the rules of the output chain
So packets from 10.10.40.1 entering through interface ether4-LAN1 (input) are dropped if trying to reach an IP of 10.10.50/24, for example.
But just to be sure, it wouldn't hurt to do the following, right?
    10.10.50.0/24
    10.10.40.0/24
add action=drop chain=forward dst-address=10.10.40.0/24 src-address=\
    10.10.50.0/24
add action=drop chain=forward dst-address=10.10.50.0/24 src-address=\
    10.10.40.0/24
add action=drop chain=output dst-address=10.10.40.0/24 src-address=\
    10.10.50.0/24
add action=drop chain=output dst-address=10.10.50.0/24 src-address=\
    10.10.40.0/24
JimLafleur
Fri Nov 20, 2020 4:20 pm
If I turn off the DHCP2 server on ether5-LAN2, when I do a traceroute from a PC connected to ether5-LAN2, the first hop is the first IP out of the WAN port, instead of the IP of the network (10.10.50.1). If I turn on the DHCP2 server on ether5-LAN2, the first hop goes to 10.10.50.1. Second hop goes to the first IP out of the WAN port.
I'd like to turn off the DHCP for port interface ether5-LAN2.
Could this somehow be a problem, if it doesn't go through 10.10.50.1 first?
mkx
You really should read the whole sentence:
Both bolded parts are equally important and are AND-ed together. The second sentence in the same paragraph finishes the description (actually points you to the next paragraph which describes forward).
BR,
Metod
mkx
Fri Nov 20, 2020 4:24 pm
If you turn off the DHCP2 server (BTW, how exactly do you achieve this?), then PC connected to this port can't get dynamic address. So which one does it use (after you disconnect UTP cable, wait for 10 seconds and reconnect)? Simply by disabling DHCP server the (logical) IP topology of the network should not change ... as long as IP address assignment to router's interfaces doesn't change.
BR,
Metod
JimLafleur
Fri Nov 20, 2020 4:34 pm
To disable the DHCP server, I go to Winbox: IP: DHCP-Server: click on DHCP2; and click on the "disable" button.
The PC connected to ether5-LAN2, has a static IP configured : IP: 10.10.50.1 mask: 255.255.255.0 Gateway: 10.10.50.1
mkx
Fri Nov 20, 2020 4:41 pm
My guess is that your weird firewall setup makes things slightly misbehave. E.g. ff your router is connected directly to ISP line, then it's not protected from possible WAN attacks at all.Then the mangle rules don't make much sense (there is no sense in having accept rules without a general drop rule at the end of chain ... implicit last rule is accept as well).
BR,
Metod
JimLafleur
Sat Nov 21, 2020 1:16 am
OK,
I've added some firewall rules to make it more secure. Based on this.
Then, when doing a traceroute 8.8.8.8, the first hop would go to 10.10.50.1 (Cable connected to ether5-LAN2; Static IP settings on PC).Second hop goes to the first IP out of the WAN port. That's how it should be. I'm not sure I understand why the firewall rules affected this. So I did a test: I deleted all the firewall rules and tried a traceroute 8.8.8.8 again. The first hop would go to 10.10.50.1!!! Before, it was skipping it and going directly to the first IP out of the WAN port... Weird.
mkx
Sat Nov 21, 2020 1:41 pm
I can imagine it was due to these two rules:
    10.10.50.0/24
    10.10.40.0/24
These were not affecting traffic between hosts of the two subnets, but they did affect traffic towards router. When doing traceroute, it's the router receiving packet with about-to-expire TTL field that has to react. I'm not entirely sure if input chain is used for that but based on your experience does seem so.
BTW, when it comes to router's own addresses, the actual address used doesn't matter much because all are treated equally. E.g. if you do traceroute to the router's address ftom another subnet, the "native" router's address won't be visible on the list of hops.
BR,
Metod
mkx
Sat Nov 21, 2020 1:45 pm
The article is fine. However it doesn't seem to reflect Mikrotik thinking, default firewall filter ruleset is pretty much simpler while being quite safe as well. You can always get ROS default config by executing /system default-configuration print (make sure the terminal window is wide enough, long lines are not wrapped aroud, they are rather truncated).
BR,
Metod
JimLafleur
Sat Nov 21, 2020 10:43 pm
OK, I've used the default firewall rules.
To block inter-LANs communications I've used input, forward and output, altogether, just to be sure. I've tested (Pinging PC on LAN2 from PC on LAN1). With just "forward", it would go through. With just "input", it would be blocked. Then, weirdly, 5 minutes later, it was the inverse: With just "forward" it would be blocked. With just "input", it would ping OK. Weird. So that's why I've put the 3.
Now, if I have PCs on ether4-LAN1 (10.10.40.x) using an IP of ether5-LAN2 (10.10.50.x), e.g. The PC on ether4-LAN1 sets a static ip of 10.50.50.111, it won't be blocked. Is there a way to block inter LANs communications with something else than just IP addresses?
# nov/21/2020 16:32:45 by RouterOS 6.47.7
# model = RB750Gr3
add name=LAN
add name=WAN
/ip hotspot profile
add interface=ether4-LAN1 list=LAN
add interface=ether5-LAN2 list=LAN
add interface=ether1-WAN1 list=WAN
/ip dhcp-client
add action=drop chain=input comment="Prevent inter LANs communications" \
    dst-address=10.10.40.0/24 src-address=10.10.50.0/24
    10.10.40.0/24
    10.10.50.0/24
    10.10.40.0/24
    10.10.50.0/24
    10.10.40.0/24
    invalid
/ip firewall mangle
/system clock
/tool mac-server
mkx
Sat Nov 21, 2020 11:10 pm
In your case with one interface per LAN you could block inter-LAN traffic based on in- and out- interfaces:
add chain=forward action=drop in-interface=ether4-LAN1 out-interface=ether5-LAN2
add chain=forward action=drop in-interface=ether5-LAN2 out-interface=ether4-LAN1
And I'd put these two rules somewhere near the end of rule list.
I'll mention it again: the two /ip firewall mangle don't act the way you wanted (according to their comments) and you better remove them.
And again: the only chain affecting traffic between two external devices (either different LANs or internet) is chain=forward. Other two chains deal with traffic either entering or leaving router's own services (e.g. Webfig or DNS server).
BR,
Metod
JimLafleur
Sat Nov 21, 2020 11:22 pm
Works great! Thanks!
OK. I've removed those 2.
Capisce!
JimLafleur
Sun Nov 22, 2020 10:16 pm
I plan to use this router in a small business. We're implementing a new IP phone system in house.
I've added all the port forwarding in the config (see below). Only the IP (199.51.2.4) of the SIP trunk provider is supposed to be able to use those ports.
Does everything look alright to you on a firewall filters and NAT rules point of view?
ether5-LAN1 : The switch for the IP phone system (PBX) is connected there.
ether4-LAN2: The switch for the PCs and other business devices is connected there.
PBX is on 10.10.50.101
# nov/22/2020 15:54:31 by RouterOS 6.47.7
# model = RB750Gr3
set [ find default-name=ether4 ] comment=LAN2 name=ether4-LAN2
set [ find default-name=ether5 ] comment=LAN1 name=ether5-LAN1
add name=LAN
add name=WAN
/ip hotspot profile
add address-pool=dhcp_pool0 disabled=no interface=ether4-LAN2 name=dhcp1
add address-pool=dhcp_pool5 interface=ether5-LAN1 name=dhcp2
add interface=ether4-LAN2 list=LAN
add interface=ether5-LAN1 list=LAN
add address=10.10.40.1/24 interface=ether4-LAN2 network=10.10.40.0
add address=10.10.50.1/24 interface=ether5-LAN1 network=10.10.50.0
add address=72.135.200.14/30 interface=ether1-WAN1 network=72.135.200.0
/ip dhcp-client
set servers=8.8.8.8,1.1.1.1
    invalid
add action=drop chain=forward comment="Prevent inter LANs communications" \
    in-interface=ether4-LAN2 out-interface=ether5-LAN1
    in-interface=ether5-LAN1 out-interface=ether4-LAN2
add action=dst-nat chain=dstnat comment=MGCP dst-port=2929 protocol=udp \
    src-address=199.51.2.4 to-addresses=10.10.50.101 to-ports=2929
add action=dst-nat chain=dstnat comment=PTAP dst-port=9500 protocol=udp \
    src-address=199.51.2.4 to-addresses=10.10.50.101 to-ports=9500
add action=dst-nat chain=dstnat comment="PBX Remote" dst-port=5980 protocol=\
    tcp src-address=199.51.2.4 to-addresses=10.10.50.101 to-ports=80
add action=dst-nat chain=dstnat comment=MGCP dst-port=2424 protocol=udp \
    src-address=199.51.2.4 to-addresses=10.10.50.101 to-ports=2424
add action=dst-nat chain=dstnat comment=cs dst-port=32929 protocol=udp \
    src-address=199.51.2.4 to-addresses=10.10.50.101 to-ports=32929
add action=dst-nat chain=dstnat comment=CS dst-port=39500 protocol=udp \
    src-address=199.51.2.4 to-addresses=10.10.50.101 to-ports=39500
add action=dst-nat chain=dstnat comment=PAGING-udp dst-port=61790 protocol=\
    udp src-address=199.51.2.4 to-addresses=10.10.50.101 to-ports=4060
add action=dst-nat chain=dstnat comment=PAGING-tcp dst-port=61790 protocol=\
    tcp src-address=199.51.2.4 to-addresses=10.10.50.101 to-ports=4060
add action=dst-nat chain=dstnat comment=paging-udp dst-port=61790 protocol=\
    udp src-address=199.51.2.4 to-addresses=10.10.50.102 to-ports=16000-16500
add action=dst-nat chain=dstnat comment=paging-tcp dst-port=61790 protocol=\
    tcp src-address=199.51.2.4 to-addresses=10.10.50.102 to-ports=16000-16500
add action=dst-nat chain=dstnat comment="Router Remote" dst-port=4770 \
    protocol=tcp src-address=199.51.2.4 to-addresses=10.10.50.1 to-ports=80
add action=dst-nat chain=dstnat comment=RTP dst-port=16000-16500 protocol=udp \
add distance=1 gateway=72.135.200.13
/system clock
/tool mac-server
JimLafleur
Mon Nov 23, 2020 8:12 pm
Does it look alright?
Of course all the IPs and ports have been changed for security.
JimLafleur
Mon Nov 23, 2020 8:43 pm
I'm testing it in pre-production right now.
I can access the PBX remotely, from the internet, without changing anything. The port forwarding seems to work alright.
I cannot access the router's webpage though, even though I did the port forwarding. The only way I found I could do it, is to add a rule in firewall to accept connection from the source IP. But my source IP will never be the same, so, is there a way to set it up so I can always access it, no matter what the source IP is?
add action=accept chain=input comment=Test1 disabled=no src-address=\
    148.155.15.75
tdw
Long time Member
Long time Member
Mon Nov 23, 2020 9:20 pm
To access the Mikrotik itself you do indeed need input not forward and/or dst-nat rules. The
add action=dst-nat chain=dstnat comment="Router Remote" dst-port=4770 protocol=tcp src-address=199.51.2.4 to-addresses=10.10.50.1 to-ports=80
is incorrect.
EDIT: incorrect is excessive, I missed the port being changed too. Specifying a to-address which exists on the Mikrotik, but is not the IP address of the ingress interface, can be misleading as the packets are still handled by the input chain, not the forward chain which may be expected.
Using HTTP for remote access rather than HTTPS is a bad idea as login credentials can be intercepted.
If you do not have a number of fixed source addresses there is no way to create a rule which allows you remote access but prevents others. Best practice would be to use a VPN which encrypts traffic, this protects otherwise insecure communications and requires both the VPN and device credentials in order to access the Mikrotik or device on your LAN.
JimLafleur
Tue Nov 24, 2020 4:21 am
The
is incorrect.
Why is is incorrect exactly?
True. Got ya.
Good idea. I'll try the VPN way as soon as I have a chance.
So it's by design? Mikrotik prevents direct access to it's webpage (via 80 or 443 port) from the internet?
mkx
Tue Nov 24, 2020 9:38 am
The
is incorrect.
There's a nice article on packet flow in ROS. It's heavy, but I'll try to explain a little bit of it.
When packet with dst-port=4770 protocol=tcp src-address=199.51.2.4 arrives, it'll enter router through physical in-interface (green oval in the "big picture" diagram). Let's assume that port is not part of bridge, so the packet will proceed until it enters routing decision square at point I.
Then we follow packet on Routing Diagram. We see that packet enters prerouting block .. which is explained a bit lower and as last step it performs dst-nat. Meaning that when packet exits prerouting block, it will already have new destination IP address and new destination port. Then it proceeds with Routing Decision parallelogram at which stage it should determine it belongs to input path, exiting Routing Diagram through point J.
Back at the "big picture" then ROS determines if the packet needs decapsulation (which it doesn't) and enters the right-most part with local in, router processes and local out. And that's exactly where you want the packet to land.
So according to my analysis (but it may be wrong) the above construct is valid one.
It's by design of default firewall filter rules ... if you remove them, router will accept connections to own services from everywhere.
Mind that for the case discussed above relevant default firewall filter rules are
/ip firewall
filter add chain=input action=drop in-interface-list=!LAN comment="defconf: drop all not coming from LAN"
filter add chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN comment="defconf: drop all from WAN not DSTNATed"
One would be tempted to believe that the last rule above has anything to do with packets discussed in my analysis above. But it doesn't because firewall filter rules only get executed after routing decision (in the Routing Diagram) and in this case routing decision is to take input path which executes rules in chain=input ... and default firewall filter rules (the first one in code block above) blocks those packets because in-interface is not member of interface list LAN. So you would need explicit rule allowing such connection, placed above the quoted rule.
BR,
Metod
JimLafleur
Wed Nov 25, 2020 7:01 pm
OK make sense. Thanks mkx.
JimLafleur
Wed Nov 25, 2020 7:53 pm
Since I did put the router in production, we have some new problems we didn't have with the network before.
2 of the IP phones started saying they had an IP Conflict on 198.168.0.x. When I do an IP scan, with Advance IP Scanner, it shows that all the IPs of the range are live (respond to ping or have open ports). But we only have like 15 devices on that network. All the "buggy" IP addresses show the same MAC address (B0:B9:8A:C5:0A:0B) belonging to Manufacturer Netgear. We don't have any Netgear equipment here. I did reboot the switch. Then all the IP phones complained about IP conflicts. Then after 30 minutes or so, without changing anything, the buggy IP addresses went away... The phones could then connect normally.
We use 1 switch for 2 subnets. The Microtik router has 2 of its ports serving 2 different subnets. Both ports are connected to the that same switch.
ether5-LAN1 : Devices of the IP phone system (PBX) use that gateway: 192.168.0.1.
ether4-LAN2: Main network: PCs and other business devices use that gateway: 192.168.1.1
If I look at the log of the Mikrotik, weirdly, all the errors related to that MAC address (B0:B9:8A:C5:0A:0B), are for the other subnet (192.168.1.x)... Not the one of the Phone system (192.168.0.x).
Errors: (Filtered by MAC address B0:B9:8A:C5:0A:0B):
# nov/25/2020 13:40:48 by RouterOS 6.47.7
10:16:59 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
10:17:08 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from B0:B9:8A:C5:0A:0B
10:17:16 dhcp,warning Detected conflict by ARP response for 192.168.1.99 from B0:B9:8A:C5:0A:0B
10:17:17 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
10:17:17 dhcp,warning Detected conflict by ARP response for 192.168.1.70 from B0:B9:8A:C5:0A:0B
10:17:18 dhcp,warning Detected conflict by ARP response for 192.168.1.248 from B0:B9:8A:C5:0A:0B
10:17:33 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
10:17:35 dhcp,warning Detected conflict by ARP response for 192.168.1.239 from B0:B9:8A:C5:0A:0B
10:17:54 dhcp,warning Detected conflict by ARP response for 192.168.1.238 from B0:B9:8A:C5:0A:0B
10:17:56 dhcp,warning Detected conflict by ARP response for 192.168.1.242 from B0:B9:8A:C5:0A:0B
10:17:56 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
10:18:15 dhcp,warning Detected conflict by ARP response for 192.168.1.239 from B0:B9:8A:C5:0A:0B
10:18:17 dhcp,warning Detected conflict by ARP response for 192.168.1.243 from B0:B9:8A:C5:0A:0B
10:18:19 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
10:18:24 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:18:25 dhcp,warning Detected conflict by ARP response for 192.168.1.238 from B0:B9:8A:C5:0A:0B
10:18:26 dhcp,warning Detected conflict by ARP response for 192.168.1.194 from B0:B9:8A:C5:0A:0B
10:18:29 dhcp,warning Detected conflict by ARP response for 192.168.1.237 from B0:B9:8A:C5:0A:0B
10:18:33 dhcp,warning Detected conflict by ARP response for 192.168.1.251 from B0:B9:8A:C5:0A:0B
10:18:59 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
10:19:01 dhcp,warning Detected conflict by ARP response for 192.168.1.117 from B0:B9:8A:C5:0A:0B
10:19:04 dhcp,warning Detected conflict by ARP response for 192.168.1.206 from B0:B9:8A:C5:0A:0B
10:19:08 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
10:19:17 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:19:42 dhcp,warning Detected conflict by ARP response for 192.168.1.169 from B0:B9:8A:C5:0A:0B
10:19:47 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
10:19:47 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
10:19:49 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:19:52 dhcp,warning Detected conflict by ARP response for 192.168.1.104 from B0:B9:8A:C5:0A:0B
10:20:08 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
10:20:09 dhcp,warning Detected conflict by ARP response for 192.168.1.115 from B0:B9:8A:C5:0A:0B
10:20:12 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from B0:B9:8A:C5:0A:0B
10:20:12 dhcp,warning Detected conflict by ARP response for 192.168.1.121 from B0:B9:8A:C5:0A:0B
10:20:13 dhcp,warning Detected conflict by ARP response for 192.168.1.201 from B0:B9:8A:C5:0A:0B
10:20:15 dhcp,warning Detected conflict by ARP response for 192.168.1.203 from B0:B9:8A:C5:0A:0B
10:20:20 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:20:28 dhcp,warning Detected conflict by ARP response for 192.168.1.251 from B0:B9:8A:C5:0A:0B
10:20:30 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
10:20:32 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
10:21:05 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:21:07 dhcp,warning Detected conflict by ARP response for 192.168.1.207 from B0:B9:8A:C5:0A:0B
10:21:23 dhcp,warning Detected conflict by ARP response for 192.168.1.210 from B0:B9:8A:C5:0A:0B
10:21:24 dhcp,warning Detected conflict by ARP response for 192.168.1.213 from B0:B9:8A:C5:0A:0B
10:21:27 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:21:31 dhcp,warning Detected conflict by ARP response for 192.168.1.251 from B0:B9:8A:C5:0A:0B
10:22:45 dhcp,warning Detected conflict by ARP response for 192.168.1.243 from B0:B9:8A:C5:0A:0B
10:22:47 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
10:22:49 dhcp,warning Detected conflict by ARP response for 192.168.1.240 from B0:B9:8A:C5:0A:0B
10:22:55 dhcp,warning Detected conflict by ARP response for 192.168.1.239 from B0:B9:8A:C5:0A:0B
10:23:14 dhcp,warning Detected conflict by ARP response for 192.168.1.238 from B0:B9:8A:C5:0A:0B
10:23:36 dhcp,warning Detected conflict by ARP response for 192.168.1.237 from B0:B9:8A:C5:0A:0B
10:23:50 dhcp,warning Detected conflict by ARP response for 192.168.1.125 from B0:B9:8A:C5:0A:0B
10:24:26 dhcp,warning Detected conflict by ARP response for 192.168.1.251 from B0:B9:8A:C5:0A:0B
10:24:27 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from B0:B9:8A:C5:0A:0B
10:24:29 dhcp,warning Detected conflict by ARP response for 192.168.1.76 from B0:B9:8A:C5:0A:0B
10:24:33 dhcp,warning Detected conflict by ARP response for 192.168.1.77 from B0:B9:8A:C5:0A:0B
10:25:02 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
10:26:21 dhcp,warning Detected conflict by ARP response for 192.168.1.184 from B0:B9:8A:C5:0A:0B
10:26:23 dhcp,warning Detected conflict by ARP response for 192.168.1.237 from B0:B9:8A:C5:0A:0B
10:26:35 dhcp,warning Detected conflict by ARP response for 192.168.1.235 from B0:B9:8A:C5:0A:0B
10:26:37 dhcp,warning Detected conflict by ARP response for 192.168.1.234 from B0:B9:8A:C5:0A:0B
10:26:39 dhcp,warning Detected conflict by ARP response for 192.168.1.205 from B0:B9:8A:C5:0A:0B
10:27:17 dhcp,warning Detected conflict by ARP response for 192.168.1.232 from B0:B9:8A:C5:0A:0B
10:27:24 dhcp,warning Detected conflict by ARP response for 192.168.1.229 from B0:B9:8A:C5:0A:0B
10:27:38 dhcp,warning Detected conflict by ARP response for 192.168.1.228 from B0:B9:8A:C5:0A:0B
10:27:51 dhcp,warning Detected conflict by ARP response for 192.168.1.227 from B0:B9:8A:C5:0A:0B
10:27:53 dhcp,warning Detected conflict by ARP response for 192.168.1.226 from B0:B9:8A:C5:0A:0B
10:28:11 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
10:28:13 dhcp,warning Detected conflict by ARP response for 192.168.1.102 from B0:B9:8A:C5:0A:0B
10:28:15 dhcp,warning Detected conflict by ARP response for 192.168.1.112 from B0:B9:8A:C5:0A:0B
10:29:08 dhcp,warning Detected conflict by ARP response for 192.168.1.225 from B0:B9:8A:C5:0A:0B
10:29:08 dhcp,warning Detected conflict by ARP response for 192.168.1.140 from B0:B9:8A:C5:0A:0B
10:29:47 dhcp,warning Detected conflict by ARP response for 192.168.1.202 from B0:B9:8A:C5:0A:0B
10:29:48 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
10:29:49 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:29:49 dhcp,warning Detected conflict by ARP response for 192.168.1.251 from B0:B9:8A:C5:0A:0B
10:29:51 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from B0:B9:8A:C5:0A:0B
10:31:28 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:31:29 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from B0:B9:8A:C5:0A:0B
10:31:40 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
10:31:41 dhcp,warning Detected conflict by ARP response for 192.168.1.242 from B0:B9:8A:C5:0A:0B
10:31:48 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
10:32:07 dhcp,warning Detected conflict by ARP response for 192.168.1.240 from B0:B9:8A:C5:0A:0B
10:32:09 dhcp,warning Detected conflict by ARP response for 192.168.1.239 from B0:B9:8A:C5:0A:0B
10:32:11 dhcp,warning Detected conflict by ARP response for 192.168.1.228 from B0:B9:8A:C5:0A:0B
10:33:36 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:35:21 dhcp,warning Detected conflict by ARP response for 192.168.1.208 from B0:B9:8A:C5:0A:0B
10:35:23 dhcp,warning Detected conflict by ARP response for 192.168.1.209 from B0:B9:8A:C5:0A:0B
10:35:26 dhcp,warning Detected conflict by ARP response for 192.168.1.211 from B0:B9:8A:C5:0A:0B
10:35:34 dhcp,warning Detected conflict by ARP response for 192.168.1.214 from B0:B9:8A:C5:0A:0B
10:35:50 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from B0:B9:8A:C5:0A:0B
10:35:57 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
10:35:59 dhcp,warning Detected conflict by ARP response for 192.168.1.80 from B0:B9:8A:C5:0A:0B
10:36:03 dhcp,warning Detected conflict by ARP response for 192.168.1.245 from B0:B9:8A:C5:0A:0B
10:36:11 dhcp,warning Detected conflict by ARP response for 192.168.1.92 from B0:B9:8A:C5:0A:0B
10:36:26 dhcp,warning Detected conflict by ARP response for 192.168.1.204 from B0:B9:8A:C5:0A:0B
10:36:27 dhcp,warning Detected conflict by ARP response for 192.168.1.93 from B0:B9:8A:C5:0A:0B
10:36:28 dhcp,warning Detected conflict by ARP response for 192.168.1.106 from B0:B9:8A:C5:0A:0B
10:36:31 dhcp,warning Detected conflict by ARP response for 192.168.1.167 from B0:B9:8A:C5:0A:0B
10:36:36 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
10:37:38 dhcp,warning Detected conflict by ARP response for 192.168.1.141 from B0:B9:8A:C5:0A:0B
10:37:39 dhcp,warning Detected conflict by ARP response for 192.168.1.78 from B0:B9:8A:C5:0A:0B
10:37:41 dhcp,warning Detected conflict by ARP response for 192.168.1.79 from B0:B9:8A:C5:0A:0B
10:37:59 dhcp,warning Detected conflict by ARP response for 192.168.1.244 from B0:B9:8A:C5:0A:0B
10:38:13 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
10:38:15 dhcp,warning Detected conflict by ARP response for 192.168.1.212 from B0:B9:8A:C5:0A:0B
10:38:17 dhcp,warning Detected conflict by ARP response for 192.168.1.216 from B0:B9:8A:C5:0A:0B
10:38:22 dhcp,warning Detected conflict by ARP response for 192.168.1.217 from B0:B9:8A:C5:0A:0B
10:38:30 dhcp,warning Detected conflict by ARP response for 192.168.1.221 from B0:B9:8A:C5:0A:0B
10:39:48 dhcp,warning Detected conflict by ARP response for 192.168.1.147 from B0:B9:8A:C5:0A:0B
10:39:50 dhcp,warning Detected conflict by ARP response for 192.168.1.148 from B0:B9:8A:C5:0A:0B
10:40:06 dhcp,warning Detected conflict by ARP response for 192.168.1.149 from B0:B9:8A:C5:0A:0B
10:40:08 dhcp,warning Detected conflict by ARP response for 192.168.1.171 from B0:B9:8A:C5:0A:0B
10:40:11 dhcp,warning Detected conflict by ARP response for 192.168.1.183 from B0:B9:8A:C5:0A:0B
10:40:15 dhcp,warning Detected conflict by ARP response for 192.168.1.185 from B0:B9:8A:C5:0A:0B
10:40:24 dhcp,warning Detected conflict by ARP response for 192.168.1.196 from B0:B9:8A:C5:0A:0B
10:40:32 dhcp,warning Detected conflict by ARP response for 192.168.1.215 from B0:B9:8A:C5:0A:0B
10:40:40 dhcp,warning Detected conflict by ARP response for 192.168.1.222 from B0:B9:8A:C5:0A:0B
10:40:43 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
10:40:47 dhcp,warning Detected conflict by ARP response for 192.168.1.98 from B0:B9:8A:C5:0A:0B
10:40:56 dhcp,warning Detected conflict by ARP response for 192.168.1.101 from B0:B9:8A:C5:0A:0B
10:40:58 dhcp,warning Detected conflict by ARP response for 192.168.1.223 from B0:B9:8A:C5:0A:0B
10:41:00 dhcp,warning Detected conflict by ARP response for 192.168.1.105 from B0:B9:8A:C5:0A:0B
10:41:03 dhcp,warning Detected conflict by ARP response for 192.168.1.195 from B0:B9:8A:C5:0A:0B
10:41:07 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:41:08 dhcp,warning Detected conflict by ARP response for 192.168.1.87 from B0:B9:8A:C5:0A:0B
10:41:11 dhcp,warning Detected conflict by ARP response for 192.168.1.251 from B0:B9:8A:C5:0A:0B
10:42:00 dhcp,warning Detected conflict by ARP response for 192.168.1.81 from B0:B9:8A:C5:0A:0B
10:42:01 dhcp,warning Detected conflict by ARP response for 192.168.1.95 from B0:B9:8A:C5:0A:0B
10:42:25 dhcp,warning Detected conflict by ARP response for 192.168.1.163 from B0:B9:8A:C5:0A:0B
10:42:57 dhcp,warning Detected conflict by ARP response for 192.168.1.186 from B0:B9:8A:C5:0A:0B
10:43:00 dhcp,warning Detected conflict by ARP response for 192.168.1.224 from B0:B9:8A:C5:0A:0B
10:43:04 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:43:28 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
10:43:34 dhcp,warning Detected conflict by ARP response for 192.168.1.243 from B0:B9:8A:C5:0A:0B
10:43:36 dhcp,warning Detected conflict by ARP response for 192.168.1.240 from B0:B9:8A:C5:0A:0B
10:43:38 dhcp,warning Detected conflict by ARP response for 192.168.1.239 from B0:B9:8A:C5:0A:0B
10:43:41 dhcp,warning Detected conflict by ARP response for 192.168.1.238 from B0:B9:8A:C5:0A:0B
10:43:42 dhcp,warning Detected conflict by ARP response for 192.168.1.237 from B0:B9:8A:C5:0A:0B
10:43:43 dhcp,warning Detected conflict by ARP response for 192.168.1.236 from B0:B9:8A:C5:0A:0B
10:43:51 dhcp,warning Detected conflict by ARP response for 192.168.1.235 from B0:B9:8A:C5:0A:0B
10:44:17 dhcp,warning Detected conflict by ARP response for 192.168.1.234 from B0:B9:8A:C5:0A:0B
10:44:50 dhcp,warning Detected conflict by ARP response for 192.168.1.91 from B0:B9:8A:C5:0A:0B
10:45:10 dhcp,warning Detected conflict by ARP response for 192.168.1.233 from B0:B9:8A:C5:0A:0B
10:46:45 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
10:46:46 dhcp,warning Detected conflict by ARP response for 192.168.1.245 from B0:B9:8A:C5:0A:0B
10:47:07 dhcp,warning Detected conflict by ARP response for 192.168.1.229 from B0:B9:8A:C5:0A:0B
10:48:04 dhcp,warning Detected conflict by ARP response for 192.168.1.244 from B0:B9:8A:C5:0A:0B
10:48:06 dhcp,warning Detected conflict by ARP response for 192.168.1.242 from B0:B9:8A:C5:0A:0B
10:48:08 dhcp,warning Detected conflict by ARP response for 192.168.1.228 from B0:B9:8A:C5:0A:0B
10:48:12 dhcp,warning Detected conflict by ARP response for 192.168.1.226 from B0:B9:8A:C5:0A:0B
10:48:13 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
10:48:16 dhcp,warning Detected conflict by ARP response for 192.168.1.73 from B0:B9:8A:C5:0A:0B
10:48:17 dhcp,warning Detected conflict by ARP response for 192.168.1.75 from B0:B9:8A:C5:0A:0B
10:48:18 dhcp,warning Detected conflict by ARP response for 192.168.1.135 from B0:B9:8A:C5:0A:0B
10:48:21 dhcp,warning Detected conflict by ARP response for 192.168.1.138 from B0:B9:8A:C5:0A:0B
10:48:21 dhcp,warning Detected conflict by ARP response for 192.168.1.139 from B0:B9:8A:C5:0A:0B
10:49:11 dhcp,warning Detected conflict by ARP response for 192.168.1.154 from B0:B9:8A:C5:0A:0B
10:49:12 dhcp,warning Detected conflict by ARP response for 192.168.1.155 from B0:B9:8A:C5:0A:0B
10:49:15 dhcp,warning Detected conflict by ARP response for 192.168.1.223 from B0:B9:8A:C5:0A:0B
10:49:19 dhcp,warning Detected conflict by ARP response for 192.168.1.221 from B0:B9:8A:C5:0A:0B
10:50:35 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
10:50:37 dhcp,warning Detected conflict by ARP response for 192.168.1.187 from B0:B9:8A:C5:0A:0B
10:50:39 dhcp,warning Detected conflict by ARP response for 192.168.1.193 from B0:B9:8A:C5:0A:0B
10:50:44 dhcp,warning Detected conflict by ARP response for 192.168.1.198 from B0:B9:8A:C5:0A:0B
10:51:38 dhcp,warning Detected conflict by ARP response for 192.168.1.199 from B0:B9:8A:C5:0A:0B
10:51:40 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
10:52:22 dhcp,warning Detected conflict by ARP response for 192.168.1.136 from B0:B9:8A:C5:0A:0B
10:52:23 dhcp,warning Detected conflict by ARP response for 192.168.1.152 from B0:B9:8A:C5:0A:0B
10:52:25 dhcp,warning Detected conflict by ARP response for 192.168.1.153 from B0:B9:8A:C5:0A:0B
10:52:46 dhcp,warning Detected conflict by ARP response for 192.168.1.162 from B0:B9:8A:C5:0A:0B
10:52:49 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
10:52:51 dhcp,warning Detected conflict by ARP response for 192.168.1.71 from B0:B9:8A:C5:0A:0B
10:52:54 dhcp,warning Detected conflict by ARP response for 192.168.1.128 from B0:B9:8A:C5:0A:0B
10:53:03 dhcp,warning Detected conflict by ARP response for 192.168.1.133 from B0:B9:8A:C5:0A:0B
10:53:42 dhcp,warning Detected conflict by ARP response for 192.168.1.156 from B0:B9:8A:C5:0A:0B
10:53:43 dhcp,warning Detected conflict by ARP response for 192.168.1.157 from B0:B9:8A:C5:0A:0B
10:53:46 dhcp,warning Detected conflict by ARP response for 192.168.1.158 from B0:B9:8A:C5:0A:0B
10:53:50 dhcp,warning Detected conflict by ARP response for 192.168.1.170 from B0:B9:8A:C5:0A:0B
10:53:51 dhcp,warning Detected conflict by ARP response for 192.168.1.172 from B0:B9:8A:C5:0A:0B
10:53:52 dhcp,warning Detected conflict by ARP response for 192.168.1.173 from B0:B9:8A:C5:0A:0B
10:53:54 dhcp,warning Detected conflict by ARP response for 192.168.1.174 from B0:B9:8A:C5:0A:0B
10:53:58 dhcp,warning Detected conflict by ARP response for 192.168.1.175 from B0:B9:8A:C5:0A:0B
10:55:03 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
10:55:04 dhcp,warning Detected conflict by ARP response for 192.168.1.86 from B0:B9:8A:C5:0A:0B
10:55:07 dhcp,warning Detected conflict by ARP response for 192.168.1.113 from B0:B9:8A:C5:0A:0B
10:55:11 dhcp,warning Detected conflict by ARP response for 192.168.1.114 from B0:B9:8A:C5:0A:0B
10:55:19 dhcp,warning Detected conflict by ARP response for 192.168.1.116 from B0:B9:8A:C5:0A:0B
10:59:54 dhcp,warning Detected conflict by ARP response for 192.168.1.243 from B0:B9:8A:C5:0A:0B
10:59:54 dhcp,warning Detected conflict by ARP response for 192.168.1.123 from B0:B9:8A:C5:0A:0B
10:59:56 dhcp,warning Detected conflict by ARP response for 192.168.1.142 from B0:B9:8A:C5:0A:0B
10:59:57 dhcp,warning Detected conflict by ARP response for 192.168.1.143 from B0:B9:8A:C5:0A:0B
11:00:00 dhcp,warning Detected conflict by ARP response for 192.168.1.145 from B0:B9:8A:C5:0A:0B
11:00:00 dhcp,warning Detected conflict by ARP response for 192.168.1.146 from B0:B9:8A:C5:0A:0B
11:00:04 dhcp,warning Detected conflict by ARP response for 192.168.1.150 from B0:B9:8A:C5:0A:0B
11:00:13 dhcp,warning Detected conflict by ARP response for 192.168.1.159 from B0:B9:8A:C5:0A:0B
11:00:15 dhcp,warning Detected conflict by ARP response for 192.168.1.177 from B0:B9:8A:C5:0A:0B
11:00:19 dhcp,warning Detected conflict by ARP response for 192.168.1.192 from B0:B9:8A:C5:0A:0B
11:00:23 dhcp,warning Detected conflict by ARP response for 192.168.1.218 from B0:B9:8A:C5:0A:0B
11:00:26 dhcp,warning Detected conflict by ARP response for 192.168.1.219 from B0:B9:8A:C5:0A:0B
11:00:27 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
11:00:28 dhcp,warning Detected conflict by ARP response for 192.168.1.74 from B0:B9:8A:C5:0A:0B
11:00:29 dhcp,warning Detected conflict by ARP response for 192.168.1.82 from B0:B9:8A:C5:0A:0B
11:00:32 dhcp,warning Detected conflict by ARP response for 192.168.1.88 from B0:B9:8A:C5:0A:0B
11:00:33 dhcp,warning Detected conflict by ARP response for 192.168.1.119 from B0:B9:8A:C5:0A:0B
11:00:41 dhcp,warning Detected conflict by ARP response for 192.168.1.122 from B0:B9:8A:C5:0A:0B
11:00:50 dhcp,warning Detected conflict by ARP response for 192.168.1.132 from B0:B9:8A:C5:0A:0B
11:00:58 dhcp,warning Detected conflict by ARP response for 192.168.1.134 from B0:B9:8A:C5:0A:0B
11:01:06 dhcp,warning Detected conflict by ARP response for 192.168.1.166 from B0:B9:8A:C5:0A:0B
11:01:15 dhcp,warning Detected conflict by ARP response for 192.168.1.197 from B0:B9:8A:C5:0A:0B
11:01:16 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
11:01:17 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
11:01:20 dhcp,warning Detected conflict by ARP response for 192.168.1.248 from B0:B9:8A:C5:0A:0B
11:01:20 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
11:01:21 dhcp,warning Detected conflict by ARP response for 192.168.1.118 from B0:B9:8A:C5:0A:0B
11:01:25 dhcp,warning Detected conflict by ARP response for 192.168.1.126 from B0:B9:8A:C5:0A:0B
11:01:26 dhcp,warning Detected conflict by ARP response for 192.168.1.120 from B0:B9:8A:C5:0A:0B
11:01:26 dhcp,warning Detected conflict by ARP response for 192.168.1.165 from B0:B9:8A:C5:0A:0B
11:01:27 dhcp,warning Detected conflict by ARP response for 192.168.1.179 from B0:B9:8A:C5:0A:0B
11:01:33 dhcp,warning Detected conflict by ARP response for 192.168.1.188 from B0:B9:8A:C5:0A:0B
11:01:42 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
11:01:51 dhcp,warning Detected conflict by ARP response for 192.168.1.131 from B0:B9:8A:C5:0A:0B
11:02:09 dhcp,warning Detected conflict by ARP response for 192.168.1.194 from B0:B9:8A:C5:0A:0B
11:02:17 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
11:02:18 dhcp,warning Detected conflict by ARP response for 192.168.1.245 from B0:B9:8A:C5:0A:0B
11:02:21 dhcp,warning Detected conflict by ARP response for 192.168.1.244 from B0:B9:8A:C5:0A:0B
11:02:25 dhcp,warning Detected conflict by ARP response for 192.168.1.242 from B0:B9:8A:C5:0A:0B
11:02:29 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
11:02:34 dhcp,warning Detected conflict by ARP response for 192.168.1.240 from B0:B9:8A:C5:0A:0B
11:03:01 dhcp,warning Detected conflict by ARP response for 192.168.1.239 from B0:B9:8A:C5:0A:0B
11:03:02 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
11:03:08 dhcp,warning Detected conflict by ARP response for 192.168.1.227 from B0:B9:8A:C5:0A:0B
11:03:09 dhcp,warning Detected conflict by ARP response for 192.168.1.109 from B0:B9:8A:C5:0A:0B
11:03:12 dhcp,warning Detected conflict by ARP response for 192.168.1.169 from B0:B9:8A:C5:0A:0B
11:03:17 dhcp,warning Detected conflict by ARP response for 192.168.1.103 from B0:B9:8A:C5:0A:0B
11:03:19 dhcp,warning Detected conflict by ARP response for 192.168.1.178 from B0:B9:8A:C5:0A:0B
11:03:19 dhcp,warning Detected conflict by ARP response for 192.168.1.206 from B0:B9:8A:C5:0A:0B
11:03:22 dhcp,warning Detected conflict by ARP response for 192.168.1.104 from B0:B9:8A:C5:0A:0B
11:03:29 dhcp,warning Detected conflict by ARP response for 192.168.1.244 from B0:B9:8A:C5:0A:0B
11:03:58 dhcp,warning Detected conflict by ARP response for 192.168.1.239 from B0:B9:8A:C5:0A:0B
11:04:00 dhcp,warning Detected conflict by ARP response for 192.168.1.238 from B0:B9:8A:C5:0A:0B
11:04:03 dhcp,warning Detected conflict by ARP response for 192.168.1.237 from B0:B9:8A:C5:0A:0B
11:04:07 dhcp,warning Detected conflict by ARP response for 192.168.1.236 from B0:B9:8A:C5:0A:0B
11:04:18 dhcp,warning Detected conflict by ARP response for 192.168.1.235 from B0:B9:8A:C5:0A:0B
11:04:21 dhcp,warning Detected conflict by ARP response for 192.168.1.201 from B0:B9:8A:C5:0A:0B
11:04:22 dhcp,warning Detected conflict by ARP response for 192.168.1.203 from B0:B9:8A:C5:0A:0B
11:04:27 dhcp,warning Detected conflict by ARP response for 192.168.1.234 from B0:B9:8A:C5:0A:0B
11:04:28 dhcp,warning Detected conflict by ARP response for 192.168.1.233 from B0:B9:8A:C5:0A:0B
11:04:29 dhcp,warning Detected conflict by ARP response for 192.168.1.232 from B0:B9:8A:C5:0A:0B
11:04:31 dhcp,warning Detected conflict by ARP response for 192.168.1.229 from B0:B9:8A:C5:0A:0B
11:05:05 dhcp,warning Detected conflict by ARP response for 192.168.1.228 from B0:B9:8A:C5:0A:0B
11:05:06 dhcp,warning Detected conflict by ARP response for 192.168.1.226 from B0:B9:8A:C5:0A:0B
11:05:09 dhcp,warning Detected conflict by ARP response for 192.168.1.225 from B0:B9:8A:C5:0A:0B
11:05:14 dhcp,warning Detected conflict by ARP response for 192.168.1.224 from B0:B9:8A:C5:0A:0B
11:05:22 dhcp,warning Detected conflict by ARP response for 192.168.1.223 from B0:B9:8A:C5:0A:0B
11:05:30 dhcp,warning Detected conflict by ARP response for 192.168.1.222 from B0:B9:8A:C5:0A:0B
11:05:39 dhcp,warning Detected conflict by ARP response for 192.168.1.207 from B0:B9:8A:C5:0A:0B
11:05:48 dhcp,warning Detected conflict by ARP response for 192.168.1.221 from B0:B9:8A:C5:0A:0B
11:05:56 dhcp,warning Detected conflict by ARP response for 192.168.1.220 from B0:B9:8A:C5:0A:0B
11:06:29 dhcp,warning Detected conflict by ARP response for 192.168.1.242 from B0:B9:8A:C5:0A:0B
11:06:30 dhcp,warning Detected conflict by ARP response for 192.168.1.89 from B0:B9:8A:C5:0A:0B
11:06:31 dhcp,warning Detected conflict by ARP response for 192.168.1.129 from B0:B9:8A:C5:0A:0B
11:07:27 dhcp,warning Detected conflict by ARP response for 192.168.1.189 from B0:B9:8A:C5:0A:0B
11:07:28 dhcp,warning Detected conflict by ARP response for 192.168.1.210 from B0:B9:8A:C5:0A:0B
11:07:31 dhcp,warning Detected conflict by ARP response for 192.168.1.213 from B0:B9:8A:C5:0A:0B
11:08:29 dhcp,warning Detected conflict by ARP response for 192.168.1.234 from B0:B9:8A:C5:0A:0B
11:09:05 dhcp,warning Detected conflict by ARP response for 192.168.1.229 from B0:B9:8A:C5:0A:0B
11:09:11 dhcp,warning Detected conflict by ARP response for 192.168.1.228 from B0:B9:8A:C5:0A:0B
11:09:16 dhcp,warning Detected conflict by ARP response for 192.168.1.226 from B0:B9:8A:C5:0A:0B
11:09:25 dhcp,warning Detected conflict by ARP response for 192.168.1.225 from B0:B9:8A:C5:0A:0B
11:09:27 dhcp,warning Detected conflict by ARP response for 192.168.1.224 from B0:B9:8A:C5:0A:0B
11:09:29 dhcp,warning Detected conflict by ARP response for 192.168.1.222 from B0:B9:8A:C5:0A:0B
11:09:30 dhcp,warning Detected conflict by ARP response for 192.168.1.137 from B0:B9:8A:C5:0A:0B
11:09:34 dhcp,warning Detected conflict by ARP response for 192.168.1.164 from B0:B9:8A:C5:0A:0B
11:09:43 dhcp,warning Detected conflict by ARP response for 192.168.1.221 from B0:B9:8A:C5:0A:0B
11:10:18 dhcp,warning Detected conflict by ARP response for 192.168.1.70 from B0:B9:8A:C5:0A:0B
11:10:30 dhcp,warning Detected conflict by ARP response for 192.168.1.107 from B0:B9:8A:C5:0A:0B
11:10:34 dhcp,warning Detected conflict by ARP response for 192.168.1.99 from B0:B9:8A:C5:0A:0B
11:10:38 dhcp,warning Detected conflict by ARP response for 192.168.1.125 from B0:B9:8A:C5:0A:0B
11:11:01 dhcp,warning Detected conflict by ARP response for 192.168.1.240 from B0:B9:8A:C5:0A:0B
11:11:04 dhcp,warning Detected conflict by ARP response for 192.168.1.223 from B0:B9:8A:C5:0A:0B
11:11:05 dhcp,warning Detected conflict by ARP response for 192.168.1.220 from B0:B9:8A:C5:0A:0B
11:11:17 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
11:11:19 dhcp,warning Detected conflict by ARP response for 192.168.1.115 from B0:B9:8A:C5:0A:0B
11:11:21 dhcp,warning Detected conflict by ARP response for 192.168.1.121 from B0:B9:8A:C5:0A:0B
11:11:21 dhcp,warning Detected conflict by ARP response for 192.168.1.219 from B0:B9:8A:C5:0A:0B
11:11:23 dhcp,warning Detected conflict by ARP response for 192.168.1.168 from B0:B9:8A:C5:0A:0B
11:11:25 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
11:11:30 dhcp,warning Detected conflict by ARP response for 192.168.1.77 from B0:B9:8A:C5:0A:0B
11:11:34 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
11:11:42 dhcp,warning Detected conflict by ARP response for 192.168.1.76 from B0:B9:8A:C5:0A:0B
11:11:42 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
11:11:44 dhcp,warning Detected conflict by ARP response for 192.168.1.202 from B0:B9:8A:C5:0A:0B
11:11:46 dhcp,warning Detected conflict by ARP response for 192.168.1.248 from B0:B9:8A:C5:0A:0B
11:11:51 dhcp,warning Detected conflict by ARP response for 192.168.1.247 from B0:B9:8A:C5:0A:0B
11:11:51 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
11:12:00 dhcp,warning Detected conflict by ARP response for 192.168.1.224 from B0:B9:8A:C5:0A:0B
11:12:09 dhcp,warning Detected conflict by ARP response for 192.168.1.223 from B0:B9:8A:C5:0A:0B
11:12:19 dhcp,warning Detected conflict by ARP response for 192.168.1.219 from B0:B9:8A:C5:0A:0B
11:14:26 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
11:14:27 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
11:14:30 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
11:14:34 dhcp,warning Detected conflict by ARP response for 192.168.1.245 from B0:B9:8A:C5:0A:0B
11:15:20 dhcp,warning Detected conflict by ARP response for 192.168.1.244 from B0:B9:8A:C5:0A:0B
11:17:17 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
11:17:50 dhcp,warning Detected conflict by ARP response for 192.168.1.239 from B0:B9:8A:C5:0A:0B
11:18:08 dhcp,warning Detected conflict by ARP response for 192.168.1.238 from B0:B9:8A:C5:0A:0B
11:18:09 dhcp,warning Detected conflict by ARP response for 192.168.1.237 from B0:B9:8A:C5:0A:0B
11:18:12 dhcp,warning Detected conflict by ARP response for 192.168.1.236 from B0:B9:8A:C5:0A:0B
11:19:30 dhcp,warning Detected conflict by ARP response for 192.168.1.205 from B0:B9:8A:C5:0A:0B
11:19:31 dhcp,warning Detected conflict by ARP response for 192.168.1.235 from B0:B9:8A:C5:0A:0B
11:19:33 dhcp,warning Detected conflict by ARP response for 192.168.1.140 from B0:B9:8A:C5:0A:0B
11:19:38 dhcp,warning Detected conflict by ARP response for 192.168.1.141 from B0:B9:8A:C5:0A:0B
11:19:47 dhcp,warning Detected conflict by ARP response for 192.168.1.78 from B0:B9:8A:C5:0A:0B
11:19:47 dhcp,warning Detected conflict by ARP response for 192.168.1.234 from B0:B9:8A:C5:0A:0B
11:19:48 dhcp,warning Detected conflict by ARP response for 192.168.1.79 from B0:B9:8A:C5:0A:0B
11:19:50 dhcp,warning Detected conflict by ARP response for 192.168.1.102 from B0:B9:8A:C5:0A:0B
11:19:55 dhcp,warning Detected conflict by ARP response for 192.168.1.233 from B0:B9:8A:C5:0A:0B
11:20:03 dhcp,warning Detected conflict by ARP response for 192.168.1.232 from B0:B9:8A:C5:0A:0B
11:20:05 dhcp,warning Detected conflict by ARP response for 192.168.1.231 from B0:B9:8A:C5:0A:0B
11:20:08 dhcp,warning Detected conflict by ARP response for 192.168.1.229 from B0:B9:8A:C5:0A:0B
11:22:48 dhcp,warning Detected conflict by ARP response for 192.168.1.228 from B0:B9:8A:C5:0A:0B
11:22:50 dhcp,warning Detected conflict by ARP response for 192.168.1.226 from B0:B9:8A:C5:0A:0B
11:22:53 dhcp,warning Detected conflict by ARP response for 192.168.1.225 from B0:B9:8A:C5:0A:0B
11:22:57 dhcp,warning Detected conflict by ARP response for 192.168.1.224 from B0:B9:8A:C5:0A:0B
11:23:06 dhcp,warning Detected conflict by ARP response for 192.168.1.223 from B0:B9:8A:C5:0A:0B
11:23:14 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
11:23:23 dhcp,warning Detected conflict by ARP response for 192.168.1.160 from B0:B9:8A:C5:0A:0B
11:23:31 dhcp,warning Detected conflict by ARP response for 192.168.1.204 from B0:B9:8A:C5:0A:0B
11:23:40 dhcp,warning Detected conflict by ARP response for 192.168.1.222 from B0:B9:8A:C5:0A:0B
11:23:49 dhcp,warning Detected conflict by ARP response for 192.168.1.106 from B0:B9:8A:C5:0A:0B
11:24:04 dhcp,warning Detected conflict by ARP response for 192.168.1.148 from B0:B9:8A:C5:0A:0B
11:24:06 dhcp,warning Detected conflict by ARP response for 192.168.1.149 from B0:B9:8A:C5:0A:0B
11:24:09 dhcp,warning Detected conflict by ARP response for 192.168.1.167 from B0:B9:8A:C5:0A:0B
11:24:13 dhcp,warning Detected conflict by ARP response for 192.168.1.171 from B0:B9:8A:C5:0A:0B
11:24:20 dhcp,warning Detected conflict by ARP response for 192.168.1.183 from B0:B9:8A:C5:0A:0B
11:24:22 dhcp,warning Detected conflict by ARP response for 192.168.1.196 from B0:B9:8A:C5:0A:0B
11:24:24 dhcp,warning Detected conflict by ARP response for 192.168.1.215 from B0:B9:8A:C5:0A:0B
11:24:28 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
11:24:37 dhcp,warning Detected conflict by ARP response for 192.168.1.87 from B0:B9:8A:C5:0A:0B
11:24:46 dhcp,warning Detected conflict by ARP response for 192.168.1.185 from B0:B9:8A:C5:0A:0B
11:24:50 dhcp,warning Detected conflict by ARP response for 192.168.1.195 from B0:B9:8A:C5:0A:0B
11:24:55 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
11:24:57 dhcp,warning Detected conflict by ARP response for 192.168.1.81 from B0:B9:8A:C5:0A:0B
11:24:59 dhcp,warning Detected conflict by ARP response for 192.168.1.95 from B0:B9:8A:C5:0A:0B
11:25:01 dhcp,warning Detected conflict by ARP response for 192.168.1.111 from B0:B9:8A:C5:0A:0B
11:25:03 dhcp,warning Detected conflict by ARP response for 192.168.1.105 from B0:B9:8A:C5:0A:0B
11:25:03 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
11:25:05 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
11:25:05 dhcp,warning Detected conflict by ARP response for 192.168.1.245 from B0:B9:8A:C5:0A:0B
11:25:08 dhcp,warning Detected conflict by ARP response for 192.168.1.242 from B0:B9:8A:C5:0A:0B
11:25:11 dhcp,warning Detected conflict by ARP response for 192.168.1.240 from B0:B9:8A:C5:0A:0B
11:25:29 dhcp,warning Detected conflict by ARP response for 192.168.1.232 from B0:B9:8A:C5:0A:0B
11:25:33 dhcp,warning Detected conflict by ARP response for 192.168.1.80 from B0:B9:8A:C5:0A:0B
11:25:35 dhcp,warning Detected conflict by ARP response for 192.168.1.92 from B0:B9:8A:C5:0A:0B
11:25:37 dhcp,warning Detected conflict by ARP response for 192.168.1.93 from B0:B9:8A:C5:0A:0B
11:25:42 dhcp,warning Detected conflict by ARP response for 192.168.1.208 from B0:B9:8A:C5:0A:0B
11:25:43 dhcp,warning Detected conflict by ARP response for 192.168.1.209 from B0:B9:8A:C5:0A:0B
11:25:45 dhcp,warning Detected conflict by ARP response for 192.168.1.212 from B0:B9:8A:C5:0A:0B
11:25:50 dhcp,warning Detected conflict by ARP response for 192.168.1.216 from B0:B9:8A:C5:0A:0B
11:25:59 dhcp,warning Detected conflict by ARP response for 192.168.1.217 from B0:B9:8A:C5:0A:0B
11:26:02 dhcp,warning Detected conflict by ARP response for 192.168.1.211 from B0:B9:8A:C5:0A:0B
11:26:03 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
11:26:06 dhcp,warning Detected conflict by ARP response for 192.168.1.98 from B0:B9:8A:C5:0A:0B
11:26:10 dhcp,warning Detected conflict by ARP response for 192.168.1.101 from B0:B9:8A:C5:0A:0B
11:26:18 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
11:26:27 dhcp,warning Detected conflict by ARP response for 192.168.1.163 from B0:B9:8A:C5:0A:0B
11:26:52 dhcp,warning Detected conflict by ARP response for 192.168.1.252 from B0:B9:8A:C5:0A:0B
11:26:56 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
11:27:01 dhcp,warning Detected conflict by ARP response for 192.168.1.75 from B0:B9:8A:C5:0A:0B
11:27:09 dhcp,warning Detected conflict by ARP response for 192.168.1.91 from B0:B9:8A:C5:0A:0B
11:27:11 dhcp,warning Detected conflict by ARP response for 192.168.1.135 from B0:B9:8A:C5:0A:0B
11:27:12 dhcp,warning Detected conflict by ARP response for 192.168.1.214 from B0:B9:8A:C5:0A:0B
11:27:13 dhcp,warning Detected conflict by ARP response for 192.168.1.139 from B0:B9:8A:C5:0A:0B
11:27:13 dhcp,warning Detected conflict by ARP response for 192.168.1.136 from B0:B9:8A:C5:0A:0B
11:27:15 dhcp,warning Detected conflict by ARP response for 192.168.1.152 from B0:B9:8A:C5:0A:0B
11:27:16 dhcp,warning Detected conflict by ARP response for 192.168.1.153 from B0:B9:8A:C5:0A:0B
11:27:26 dhcp,warning Detected conflict by ARP response for 192.168.1.186 from B0:B9:8A:C5:0A:0B
11:27:34 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
11:27:43 dhcp,warning Detected conflict by ARP response for 192.168.1.248 from B0:B9:8A:C5:0A:0B
11:27:51 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
11:28:03 dhcp,warning Detected conflict by ARP response for 192.168.1.71 from B0:B9:8A:C5:0A:0B
11:28:03 dhcp,warning Detected conflict by ARP response for 192.168.1.128 from B0:B9:8A:C5:0A:0B
11:28:04 dhcp,warning Detected conflict by ARP response for 192.168.1.133 from B0:B9:8A:C5:0A:0B
11:28:05 dhcp,warning Detected conflict by ARP response for 192.168.1.162 from B0:B9:8A:C5:0A:0B
11:28:06 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
11:28:07 dhcp,warning Detected conflict by ARP response for 192.168.1.245 from B0:B9:8A:C5:0A:0B
11:28:11 dhcp,warning Detected conflict by ARP response for 192.168.1.244 from B0:B9:8A:C5:0A:0B
11:28:36 dhcp,warning Detected conflict by ARP response for 192.168.1.242 from B0:B9:8A:C5:0A:0B
11:28:38 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
11:28:47 dhcp,warning Detected conflict by ARP response for 192.168.1.239 from B0:B9:8A:C5:0A:0B
11:29:31 dhcp,warning Detected conflict by ARP response for 192.168.1.151 from B0:B9:8A:C5:0A:0B
11:29:33 dhcp,warning Detected conflict by ARP response for 192.168.1.156 from B0:B9:8A:C5:0A:0B
11:29:36 dhcp,warning Detected conflict by ARP response for 192.168.1.157 from B0:B9:8A:C5:0A:0B
11:29:58 dhcp,warning Detected conflict by ARP response for 192.168.1.158 from B0:B9:8A:C5:0A:0B
11:29:59 dhcp,warning Detected conflict by ARP response for 192.168.1.170 from B0:B9:8A:C5:0A:0B
11:30:01 dhcp,warning Detected conflict by ARP response for 192.168.1.175 from B0:B9:8A:C5:0A:0B
11:31:14 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
11:31:15 dhcp,warning Detected conflict by ARP response for 192.168.1.73 from B0:B9:8A:C5:0A:0B
11:31:30 dhcp,warning Detected conflict by ARP response for 192.168.1.138 from B0:B9:8A:C5:0A:0B
11:31:31 dhcp,warning Detected conflict by ARP response for 192.168.1.154 from B0:B9:8A:C5:0A:0B
11:31:54 dhcp,warning Detected conflict by ARP response for 192.168.1.155 from B0:B9:8A:C5:0A:0B
11:31:56 dhcp,warning Detected conflict by ARP response for 192.168.1.242 from B0:B9:8A:C5:0A:0B
11:31:59 dhcp,warning Detected conflict by ARP response for 192.168.1.241 from B0:B9:8A:C5:0A:0B
11:35:40 dhcp,warning Detected conflict by ARP response for 192.168.1.247 from B0:B9:8A:C5:0A:0B
11:35:42 dhcp,warning Detected conflict by ARP response for 192.168.1.237 from B0:B9:8A:C5:0A:0B
11:35:44 dhcp,warning Detected conflict by ARP response for 192.168.1.236 from B0:B9:8A:C5:0A:0B
11:35:49 dhcp,warning Detected conflict by ARP response for 192.168.1.235 from B0:B9:8A:C5:0A:0B
11:35:58 dhcp,warning Detected conflict by ARP response for 192.168.1.234 from B0:B9:8A:C5:0A:0B
11:36:06 dhcp,warning Detected conflict by ARP response for 192.168.1.233 from B0:B9:8A:C5:0A:0B
11:36:15 dhcp,warning Detected conflict by ARP response for 192.168.1.232 from B0:B9:8A:C5:0A:0B
11:36:23 dhcp,warning Detected conflict by ARP response for 192.168.1.231 from B0:B9:8A:C5:0A:0B
11:37:34 dhcp,warning Detected conflict by ARP response for 192.168.1.254 from B0:B9:8A:C5:0A:0B
11:37:35 dhcp,warning Detected conflict by ARP response for 192.168.1.86 from B0:B9:8A:C5:0A:0B
11:37:38 dhcp,warning Detected conflict by ARP response for 192.168.1.113 from B0:B9:8A:C5:0A:0B
11:37:42 dhcp,warning Detected conflict by ARP response for 192.168.1.114 from B0:B9:8A:C5:0A:0B
11:37:51 dhcp,warning Detected conflict by ARP response for 192.168.1.116 from B0:B9:8A:C5:0A:0B
11:38:12 dhcp,warning Detected conflict by ARP response for 192.168.1.119 from B0:B9:8A:C5:0A:0B
11:38:14 dhcp,warning Detected conflict by ARP response for 192.168.1.123 from B0:B9:8A:C5:0A:0B
11:38:16 dhcp,warning Detected conflict by ARP response for 192.168.1.145 from B0:B9:8A:C5:0A:0B
11:38:16 dhcp,warning Detected conflict by ARP response for 192.168.1.176 from B0:B9:8A:C5:0A:0B
11:38:20 dhcp,warning Detected conflict by ARP response for 192.168.1.180 from B0:B9:8A:C5:0A:0B
11:38:21 dhcp,warning Detected conflict by ARP response for 192.168.1.187 from B0:B9:8A:C5:0A:0B
11:38:23 dhcp,warning Detected conflict by ARP response for 192.168.1.193 from B0:B9:8A:C5:0A:0B
11:38:29 dhcp,warning Detected conflict by ARP response for 192.168.1.198 from B0:B9:8A:C5:0A:0B
11:38:33 dhcp,warning Detected conflict by ARP response for 192.168.1.199 from B0:B9:8A:C5:0A:0B
11:38:58 dhcp,warning Detected conflict by ARP response for 192.168.1.74 from B0:B9:8A:C5:0A:0B
11:38:59 dhcp,warning Detected conflict by ARP response for 192.168.1.82 from B0:B9:8A:C5:0A:0B
11:39:03 dhcp,warning Detected conflict by ARP response for 192.168.1.124 from B0:B9:8A:C5:0A:0B
11:39:06 dhcp,warning Detected conflict by ARP response for 192.168.1.172 from B0:B9:8A:C5:0A:0B
11:42:57 dhcp,warning Detected conflict by ARP response for 192.168.1.173 from B0:B9:8A:C5:0A:0B
11:43:40 dhcp,warning Detected conflict by ARP response for 192.168.1.174 from B0:B9:8A:C5:0A:0B
11:43:41 dhcp,warning Detected conflict by ARP response for 192.168.1.253 from B0:B9:8A:C5:0A:0B
11:43:44 dhcp,warning Detected conflict by ARP response for 192.168.1.142 from B0:B9:8A:C5:0A:0B
11:46:53 dhcp,warning Detected conflict by ARP response for 192.168.1.143 from B0:B9:8A:C5:0A:0B
11:46:55 dhcp,warning Detected conflict by ARP response for 192.168.1.146 from B0:B9:8A:C5:0A:0B
11:46:59 dhcp,warning Detected conflict by ARP response for 192.168.1.150 from B0:B9:8A:C5:0A:0B
11:47:07 dhcp,warning Detected conflict by ARP response for 192.168.1.159 from B0:B9:8A:C5:0A:0B
11:47:23 dhcp,warning Detected conflict by ARP response for 192.168.1.166 from B0:B9:8A:C5:0A:0B
11:47:33 dhcp,warning Detected conflict by ARP response for 192.168.1.177 from B0:B9:8A:C5:0A:0B
11:47:33 dhcp,warning Detected conflict by ARP response for 192.168.1.192 from B0:B9:8A:C5:0A:0B
11:47:35 dhcp,warning Detected conflict by ARP response for 192.168.1.197 from B0:B9:8A:C5:0A:0B
11:47:39 dhcp,warning Detected conflict by ARP response for 192.168.1.218 from B0:B9:8A:C5:0A:0B
11:49:49 dhcp,warning Detected conflict by ARP response for 192.168.1.103 from B0:B9:8A:C5:0A:0B
11:49:50 dhcp,warning Detected conflict by ARP response for 192.168.1.122 from B0:B9:8A:C5:0A:0B
11:49:53 dhcp,warning Detected conflict by ARP response for 192.168.1.132 from B0:B9:8A:C5:0A:0B
11:49:57 dhcp,warning Detected conflict by ARP response for 192.168.1.134 from B0:B9:8A:C5:0A:0B
11:50:05 dhcp,warning Detected conflict by ARP response for 192.168.1.178 from B0:B9:8A:C5:0A:0B
11:50:22 dhcp,warning Detected conflict by ARP response for 192.168.1.104 from B0:B9:8A:C5:0A:0B
11:50:31 dhcp,warning Detected conflict by ARP response for 192.168.1.249 from B0:B9:8A:C5:0A:0B
11:50:39 dhcp,warning Detected conflict by ARP response for 192.168.1.248 from B0:B9:8A:C5:0A:0B
11:50:47 dhcp,warning Detected conflict by ARP response for 192.168.1.247 from B0:B9:8A:C5:0A:0B
11:50:55 dhcp,warning Detected conflict by ARP response for 192.168.1.246 from B0:B9:8A:C5:0A:0B
11:50:57 dhcp,warning Detected conflict by ARP response for 192.168.1.245 from B0:B9:8A:C5:0A:0B
11:50:59 dhcp,warning Detected conflict by ARP response for 192.168.1.244 from B0:B9:8A:C5:0A:0B
Full log:
# software id = H2RB-DILS
10:17:02 dhcp,info dhcp1 assigned 192.168.1.250 to 3E:64:C6:2B:C5:1A
10:17:08 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.250
10:17:08 dhcp,info dhcp1 deassigned 192.168.1.250 from 3E:64:C6:2B:C5:1A
10:17:20 dhcp,info dhcp1 assigned 192.168.1.245 to A2:7E:4A:35:48:12
10:17:21 dhcp,info dhcp1 assigned 192.168.1.242 to 3E:64:C6:2B:C5:1A
10:17:23 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.242
10:17:23 dhcp,info dhcp1 deassigned 192.168.1.242 from 3E:64:C6:2B:C5:1A
10:17:38 dhcp,info dhcp1 assigned 192.168.1.238 to 3E:64:C6:2B:C5:1A
10:17:44 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.238
10:17:44 dhcp,info dhcp1 deassigned 192.168.1.238 from 3E:64:C6:2B:C5:1A
10:18:00 dhcp,info dhcp1 assigned 192.168.1.239 to 3E:64:C6:2B:C5:1A
10:18:05 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.239
10:18:05 dhcp,info dhcp1 deassigned 192.168.1.239 from 3E:64:C6:2B:C5:1A
10:18:07 dhcp,info dhcp1 assigned 192.168.1.248 to EC:F4:BB:68:47:AC
10:18:30 dhcp,info dhcp1 deassigned 192.168.1.251 from EC:CE:D7:BE:72:31
10:18:35 dhcp,info dhcp1 assigned 192.168.1.236 to D2:6F:50:94:4F:09
10:18:36 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.236
10:18:36 dhcp,info dhcp1 deassigned 192.168.1.236 from D2:6F:50:94:4F:09
10:18:37 dhcp,info dhcp1 deassigned 192.168.1.245 from A2:7E:4A:35:48:12
10:18:38 dhcp,info dhcp1 assigned 192.168.1.245 to A2:7E:4A:35:48:12
10:18:43 dhcp,info dhcp1 assigned 192.168.1.254 to 3E:64:C6:2B:C5:1A
10:18:48 dhcp,info dhcp1 assigned 192.168.1.236 to D2:6F:50:94:4F:09
10:18:49 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.254
10:18:49 dhcp,info dhcp1 deassigned 192.168.1.254 from 3E:64:C6:2B:C5:1A
10:18:50 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.236
10:18:50 dhcp,info dhcp1 deassigned 192.168.1.236 from D2:6F:50:94:4F:09
10:19:01 dhcp,info dhcp1 assigned 192.168.1.103 to D2:6F:50:94:4F:09
10:19:07 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.103
10:19:07 dhcp,info dhcp1 deassigned 192.168.1.103 from D2:6F:50:94:4F:09
10:19:19 dhcp,info dhcp1 assigned 192.168.1.251 to D2:6F:50:94:4F:09
10:19:20 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.251
10:19:20 dhcp,info dhcp1 deassigned 192.168.1.251 from D2:6F:50:94:4F:09
10:19:22 dhcp,info dhcp1 deassigned 192.168.1.244 from 24:E3:14:5D:B1:D1
10:19:23 dhcp,info dhcp1 assigned 192.168.1.244 to 24:E3:14:5D:B1:D1
10:19:28 dhcp,warning dhcp1 client 24:E3:14:5D:B1:D1 declines IP address 192.168.1.244
10:19:28 dhcp,info dhcp1 deassigned 192.168.1.244 from 24:E3:14:5D:B1:D1
10:19:32 dhcp,info dhcp1 assigned 192.168.1.251 to D2:6F:50:94:4F:09
10:19:37 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.251
10:19:37 dhcp,info dhcp1 deassigned 192.168.1.251 from D2:6F:50:94:4F:09
10:19:42 dhcp,info dhcp1 assigned 192.168.1.168 to 3E:64:C6:2B:C5:1A
10:19:44 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.168
10:19:44 dhcp,info dhcp1 deassigned 192.168.1.168 from 3E:64:C6:2B:C5:1A
10:19:56 dhcp,info dhcp1 assigned 192.168.1.168 to 3E:64:C6:2B:C5:1A
10:19:57 dhcp,info dhcp1 assigned 192.168.1.178 to 24:E3:14:5D:B1:D1
10:19:58 dhcp,info dhcp1 assigned 192.168.1.250 to D2:6F:50:94:4F:09
10:19:58 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.168
10:19:58 dhcp,info dhcp1 deassigned 192.168.1.168 from 3E:64:C6:2B:C5:1A
10:19:59 dhcp,warning dhcp1 client 24:E3:14:5D:B1:D1 declines IP address 192.168.1.178
10:19:59 dhcp,info dhcp1 deassigned 192.168.1.178 from 24:E3:14:5D:B1:D1
10:20:02 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.250
10:20:02 dhcp,info dhcp1 deassigned 192.168.1.250 from D2:6F:50:94:4F:09
10:20:13 dhcp,info dhcp1 deassigned 192.168.1.245 from A2:7E:4A:35:48:12
10:20:15 dhcp,info dhcp1 assigned 192.168.1.245 to A2:7E:4A:35:48:12
10:20:20 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.245
10:20:20 dhcp,info dhcp1 deassigned 192.168.1.245 from A2:7E:4A:35:48:12
10:20:35 dhcp,info dhcp1 assigned 192.168.1.244 to A2:7E:4A:35:48:12
10:20:38 dhcp,info dhcp1 assigned 192.168.1.243 to D2:6F:50:94:4F:09
10:20:40 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.243
10:20:40 dhcp,info dhcp1 deassigned 192.168.1.243 from D2:6F:50:94:4F:09
10:20:51 dhcp,info dhcp1 assigned 192.168.1.243 to D2:6F:50:94:4F:09
10:20:55 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.243
10:20:55 dhcp,info dhcp1 deassigned 192.168.1.243 from D2:6F:50:94:4F:09
10:21:05 dhcp,info dhcp1 assigned 192.168.1.253 to 3E:64:C6:2B:C5:1A
10:21:10 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.253
10:21:10 dhcp,info dhcp1 deassigned 192.168.1.253 from 3E:64:C6:2B:C5:1A
10:21:11 dhcp,info dhcp1 assigned 192.168.1.210 to D2:6F:50:94:4F:09
10:21:13 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.210
10:21:13 dhcp,info dhcp1 deassigned 192.168.1.210 from D2:6F:50:94:4F:09
10:21:41 dhcp,info dhcp1 assigned 192.168.1.250 to D2:6F:50:94:4F:09
10:21:47 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.250
10:21:47 dhcp,info dhcp1 deassigned 192.168.1.250 from D2:6F:50:94:4F:09
10:21:59 dhcp,info dhcp1 assigned 192.168.1.250 to D2:6F:50:94:4F:09
10:22:11 dhcp,info dhcp1 assigned 192.168.1.252 to 3E:64:C6:2B:C5:1A
10:22:14 dhcp,info dhcp1 deassigned 192.168.1.250 from D2:6F:50:94:4F:09
10:22:15 dhcp,info dhcp1 assigned 192.168.1.250 to D2:6F:50:94:4F:09
10:22:16 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.252
10:22:16 dhcp,info dhcp1 deassigned 192.168.1.252 from 3E:64:C6:2B:C5:1A
10:22:21 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.250
10:22:21 dhcp,info dhcp1 deassigned 192.168.1.250 from D2:6F:50:94:4F:09
10:22:33 dhcp,info dhcp1 assigned 192.168.1.251 to D2:6F:50:94:4F:09
10:22:36 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.251
10:22:36 dhcp,info dhcp1 deassigned 192.168.1.251 from D2:6F:50:94:4F:09
10:23:17 dhcp,info dhcp1 assigned 192.168.1.237 to D2:6F:50:94:4F:09
10:23:22 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.237
10:23:22 dhcp,info dhcp1 deassigned 192.168.1.237 from D2:6F:50:94:4F:09
10:23:31 dhcp,info dhcp1 deassigned 192.168.1.244 from A2:7E:4A:35:48:12
10:23:32 dhcp,info dhcp1 assigned 192.168.1.244 to A2:7E:4A:35:48:12
10:23:38 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.244
10:23:38 dhcp,info dhcp1 deassigned 192.168.1.244 from A2:7E:4A:35:48:12
10:23:38 dhcp,info dhcp1 assigned 192.168.1.107 to D2:6F:50:94:4F:09
10:23:44 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.107
10:23:44 dhcp,info dhcp1 deassigned 192.168.1.107 from D2:6F:50:94:4F:09
10:23:48 dhcp,warning Detected conflict by ARP response for 192.168.1.108 from 44:47:CC:BD:E5:48
10:23:53 dhcp,info dhcp1 assigned 192.168.1.250 to A2:7E:4A:35:48:12
10:23:57 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.250
10:23:57 dhcp,info dhcp1 deassigned 192.168.1.250 from A2:7E:4A:35:48:12
10:23:57 dhcp,info dhcp1 assigned 192.168.1.238 to D2:6F:50:94:4F:09
10:24:03 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.238
10:24:03 dhcp,info dhcp1 deassigned 192.168.1.238 from D2:6F:50:94:4F:09
10:24:09 dhcp,info dhcp1 deassigned 192.168.1.233 from 5C:F2:07:40:1E:E5
10:25:00 dhcp,info dhcp1 assigned 192.168.1.249 to A2:7E:4A:35:48:12
10:25:01 dhcp,info dhcp1 assigned 192.168.1.238 to D2:6F:50:94:4F:09
10:25:06 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.238
10:25:06 dhcp,info dhcp1 deassigned 192.168.1.238 from D2:6F:50:94:4F:09
10:25:18 dhcp,info dhcp1 assigned 192.168.1.245 to D2:6F:50:94:4F:09
10:25:22 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.245
10:25:22 dhcp,info dhcp1 deassigned 192.168.1.245 from D2:6F:50:94:4F:09
10:26:13 dhcp,info dhcp1 deassigned 192.168.1.249 from A2:7E:4A:35:48:12
10:26:14 dhcp,info dhcp1 assigned 192.168.1.249 to A2:7E:4A:35:48:12
10:26:17 dhcp,info dhcp1 assigned 192.168.1.244 to D2:6F:50:94:4F:09
10:26:20 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.249
10:26:20 dhcp,info dhcp1 deassigned 192.168.1.249 from A2:7E:4A:35:48:12
10:26:21 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.244
10:26:21 dhcp,info dhcp1 deassigned 192.168.1.244 from D2:6F:50:94:4F:09
10:26:32 dhcp,info dhcp1 assigned 192.168.1.236 to D2:6F:50:94:4F:09
10:26:38 dhcp,info dhcp1 deassigned 192.168.1.236 from D2:6F:50:94:4F:09
10:26:40 dhcp,info dhcp1 assigned 192.168.1.236 to D2:6F:50:94:4F:09
10:26:44 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.236
10:26:44 dhcp,info dhcp1 deassigned 192.168.1.236 from D2:6F:50:94:4F:09
10:26:45 dhcp,info dhcp1 assigned 192.168.1.233 to A2:7E:4A:35:48:12
10:27:57 dhcp,info dhcp1 assigned 192.168.1.225 to 3E:64:C6:2B:C5:1A
10:28:03 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.225
10:28:03 dhcp,info dhcp1 deassigned 192.168.1.225 from 3E:64:C6:2B:C5:1A
10:29:13 dhcp,info dhcp1 assigned 192.168.1.141 to 3E:64:C6:2B:C5:1A
10:29:39 dhcp,info dhcp1 deassigned 192.168.1.141 from 3E:64:C6:2B:C5:1A
10:29:41 dhcp,info dhcp1 assigned 192.168.1.141 to 3E:64:C6:2B:C5:1A
10:29:57 dhcp,info dhcp1 assigned 192.168.1.243 to CE:F8:D5:DE:5F:79
10:29:59 dhcp,warning dhcp1 client CE:F8:D5:DE:5F:79 declines IP address 192.168.1.243
10:29:59 dhcp,info dhcp1 deassigned 192.168.1.243 from CE:F8:D5:DE:5F:79
10:30:11 dhcp,info dhcp1 assigned 192.168.1.243 to CE:F8:D5:DE:5F:79
10:30:17 dhcp,info dhcp1 deassigned 192.168.1.141 from 3E:64:C6:2B:C5:1A
10:32:07 dhcp,info dhcp1 deassigned 192.168.1.233 from A2:7E:4A:35:48:12
10:32:08 dhcp,info dhcp1 assigned 192.168.1.233 to A2:7E:4A:35:48:12
10:32:11 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.233
10:32:11 dhcp,info dhcp1 deassigned 192.168.1.233 from A2:7E:4A:35:48:12
10:32:15 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
10:32:19 dhcp,info dhcp1 assigned 192.168.1.226 to D2:6F:50:94:4F:09
10:32:23 dhcp,info dhcp1 assigned 192.168.1.141 to 3E:64:C6:2B:C5:1A
10:32:53 dhcp,info dhcp1 deassigned 192.168.1.226 from D2:6F:50:94:4F:09
10:32:55 dhcp,info dhcp1 assigned 192.168.1.226 to D2:6F:50:94:4F:09
10:33:00 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.226
10:33:00 dhcp,info dhcp1 deassigned 192.168.1.226 from D2:6F:50:94:4F:09
10:33:21 dhcp,info dhcp1 assigned 192.168.1.226 to D2:6F:50:94:4F:09
10:33:26 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.226
10:33:26 dhcp,info dhcp1 deassigned 192.168.1.226 from D2:6F:50:94:4F:09
10:33:27 dhcp,info dhcp1 deassigned 192.168.1.141 from 3E:64:C6:2B:C5:1A
10:33:40 dhcp,info dhcp1 assigned 192.168.1.160 to D2:6F:50:94:4F:09
10:33:41 dhcp,info dhcp1 assigned 192.168.1.117 to 30:52:CB:31:4E:6D
10:34:30 dhcp,info dhcp1 deassigned 192.168.1.160 from D2:6F:50:94:4F:09
10:34:32 dhcp,info dhcp1 assigned 192.168.1.160 to D2:6F:50:94:4F:09
10:34:36 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.160
10:34:36 dhcp,info dhcp1 deassigned 192.168.1.160 from D2:6F:50:94:4F:09
10:37:47 dhcp,info dhcp1 assigned 192.168.1.244 to 3E:64:C6:2B:C5:1A
10:37:48 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.244
10:37:48 dhcp,info dhcp1 deassigned 192.168.1.244 from 3E:64:C6:2B:C5:1A
10:38:01 dhcp,info dhcp1 assigned 192.168.1.242 to 3E:64:C6:2B:C5:1A
10:38:03 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.242
10:38:03 dhcp,info dhcp1 deassigned 192.168.1.242 from 3E:64:C6:2B:C5:1A
10:38:41 dhcp,info dhcp1 assigned 192.168.1.241 to 3E:64:C6:2B:C5:1A
10:40:11 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.241
10:40:11 dhcp,info dhcp1 deassigned 192.168.1.241 from 3E:64:C6:2B:C5:1A
10:40:11 dhcp,info dhcp1 deassigned 192.168.1.243 from CE:F8:D5:DE:5F:79
10:40:36 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
10:40:37 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
10:40:42 dhcp,info dhcp1 assigned 192.168.1.223 to D2:6F:50:94:4F:09
10:40:48 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.223
10:40:48 dhcp,info dhcp1 deassigned 192.168.1.223 from D2:6F:50:94:4F:09
10:41:18 dhcp,info dhcp1 assigned 192.168.1.249 to D2:6F:50:94:4F:09
10:41:19 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.249
10:41:19 dhcp,info dhcp1 deassigned 192.168.1.249 from D2:6F:50:94:4F:09
10:41:20 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
10:41:22 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
10:41:31 dhcp,info dhcp1 assigned 192.168.1.249 to D2:6F:50:94:4F:09
10:41:33 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.249
10:41:33 dhcp,info dhcp1 deassigned 192.168.1.249 from D2:6F:50:94:4F:09
10:41:45 dhcp,info dhcp1 assigned 192.168.1.252 to D2:6F:50:94:4F:09
10:41:50 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.252
10:41:50 dhcp,info dhcp1 deassigned 192.168.1.252 from D2:6F:50:94:4F:09
10:42:04 dhcp,warning Detected conflict by ARP response for 192.168.1.111 from 00:03:2D:18:45:C7
10:42:09 dhcp,info dhcp1 assigned 192.168.1.163 to D2:6F:50:94:4F:09
10:42:15 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.163
10:42:15 dhcp,info dhcp1 deassigned 192.168.1.163 from D2:6F:50:94:4F:09
10:43:11 dhcp,info dhcp1 assigned 192.168.1.251 to D8:C4:E9:88:5D:91
10:45:14 dhcp,info dhcp1 assigned 192.168.1.232 to D2:6F:50:94:4F:09
10:45:20 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.232
10:45:20 dhcp,info dhcp1 deassigned 192.168.1.232 from D2:6F:50:94:4F:09
10:46:04 dhcp,info dhcp1 deassigned 192.168.1.248 from EC:F4:BB:68:47:AC
10:46:04 dhcp,info dhcp1 assigned 192.168.1.248 to EC:F4:BB:68:47:AC
10:46:17 dhcp,info dhcp1 assigned 192.168.1.250 to D2:6F:50:94:4F:09
10:46:23 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.250
10:46:23 dhcp,info dhcp1 deassigned 192.168.1.250 from D2:6F:50:94:4F:09
10:49:17 dhcp,info dhcp1 assigned 192.168.1.225 to 3E:64:C6:2B:C5:1A
10:51:22 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
10:51:45 dhcp,info dhcp1 assigned 192.168.1.124 to D2:6F:50:94:4F:09
10:52:04 dhcp,info dhcp1 deassigned 192.168.1.225 from 3E:64:C6:2B:C5:1A
10:52:06 dhcp,info dhcp1 assigned 192.168.1.225 to 3E:64:C6:2B:C5:1A
10:52:12 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.225
10:52:12 dhcp,info dhcp1 deassigned 192.168.1.225 from 3E:64:C6:2B:C5:1A
10:52:32 dhcp,info dhcp1 assigned 192.168.1.162 to 3E:64:C6:2B:C5:1A
10:52:36 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.162
10:52:36 dhcp,info dhcp1 deassigned 192.168.1.162 from 3E:64:C6:2B:C5:1A
10:53:12 dhcp,info dhcp1 assigned 192.168.1.151 to 3E:64:C6:2B:C5:1A
10:53:14 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.151
10:53:14 dhcp,info dhcp1 deassigned 192.168.1.151 from 3E:64:C6:2B:C5:1A
10:53:26 dhcp,info dhcp1 assigned 192.168.1.151 to 3E:64:C6:2B:C5:1A
10:53:32 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.151
10:53:32 dhcp,info dhcp1 deassigned 192.168.1.151 from 3E:64:C6:2B:C5:1A
10:53:33 dhcp,info dhcp1 deassigned 192.168.1.124 from D2:6F:50:94:4F:09
10:53:35 dhcp,info dhcp1 assigned 192.168.1.124 to D2:6F:50:94:4F:09
10:53:41 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.124
10:53:41 dhcp,info dhcp1 deassigned 192.168.1.124 from D2:6F:50:94:4F:09
10:54:17 dhcp,info dhcp1 assigned 192.168.1.176 to 3E:64:C6:2B:C5:1A
10:54:22 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.176
10:54:22 dhcp,info dhcp1 deassigned 192.168.1.176 from 3E:64:C6:2B:C5:1A
10:54:34 dhcp,info dhcp1 assigned 192.168.1.176 to 3E:64:C6:2B:C5:1A
10:54:36 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.176
10:54:36 dhcp,info dhcp1 deassigned 192.168.1.176 from 3E:64:C6:2B:C5:1A
10:54:47 dhcp,info dhcp1 assigned 192.168.1.180 to 3E:64:C6:2B:C5:1A
10:54:53 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.180
10:54:53 dhcp,info dhcp1 deassigned 192.168.1.180 from 3E:64:C6:2B:C5:1A
10:56:38 dhcp,info dhcp1 deassigned 192.168.1.248 from EC:F4:BB:68:47:AC
10:57:21 interface,info ether4-LAN2 link down
10:57:21 interface,info ether5-LAN1 link down
10:57:27 system,info,account user Admin logged out from 78:2B:CB:83:0B:CF via winbox
10:59:45 interface,info ether4-LAN2 link up (speed 1G, full duplex)
10:59:45 interface,info ether5-LAN1 link up (speed 1G, full duplex)
10:59:47 interface,info ether5-LAN1 link down
10:59:47 dhcp,info dhcp1 deassigned 192.168.1.85 from 54:7F:54:85:3A:1D
10:59:47 dhcp,info dhcp1 assigned 192.168.1.85 to 54:7F:54:85:3A:1D
10:59:49 interface,info ether5-LAN1 link up (speed 1G, full duplex)
10:59:56 dhcp,info dhcp1 deassigned 192.168.1.191 from 8C:DC:D4:41:6D:33
10:59:56 dhcp,info dhcp1 assigned 192.168.1.191 to 8C:DC:D4:41:6D:33
10:59:59 dhcp,info dhcp1 deassigned 192.168.1.85 from 54:7F:54:85:3A:1D
10:59:59 dhcp,info dhcp1 assigned 192.168.1.85 to 54:7F:54:85:3A:1D
11:00:02 dhcp,info dhcp1 deassigned 192.168.1.100 from 08:9E:01:42:8F:00
11:00:02 dhcp,info dhcp1 assigned 192.168.1.100 to 08:9E:01:42:8F:00
11:00:21 dhcp,info dhcp1 assigned 192.168.1.144 to 5C:5F:67:6D:7A:40
11:00:31 dhcp,info dhcp1 assigned 192.168.1.83 to DA:76:1E:C4:8A:AF
11:00:39 dhcp,info dhcp1 assigned 192.168.1.120 to 3E:64:C6:2B:C5:1A
11:00:41 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.120
11:00:41 dhcp,info dhcp1 deassigned 192.168.1.120 from 3E:64:C6:2B:C5:1A
11:00:45 dhcp,info dhcp1 deassigned 192.168.1.83 from DA:76:1E:C4:8A:AF
11:00:46 dhcp,info dhcp1 assigned 192.168.1.83 to DA:76:1E:C4:8A:AF
11:00:50 dhcp,warning dhcp1 client DA:76:1E:C4:8A:AF declines IP address 192.168.1.83
11:00:50 dhcp,info dhcp1 deassigned 192.168.1.83 from DA:76:1E:C4:8A:AF
11:01:02 dhcp,info dhcp1 assigned 192.168.1.83 to DA:76:1E:C4:8A:AF
11:01:08 dhcp,warning dhcp1 client DA:76:1E:C4:8A:AF declines IP address 192.168.1.83
11:01:08 dhcp,info dhcp1 deassigned 192.168.1.83 from DA:76:1E:C4:8A:AF
11:01:18 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from C4:E9:0A:82:4A:A0
11:02:45 dhcp,info dhcp1 assigned 192.168.1.239 to D2:6F:50:94:4F:09
11:02:50 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.239
11:02:50 dhcp,info dhcp1 deassigned 192.168.1.239 from D2:6F:50:94:4F:09
11:03:06 dhcp,info dhcp1 assigned 192.168.1.103 to D2:6F:50:94:4F:09
11:03:07 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.103
11:03:07 dhcp,info dhcp1 deassigned 192.168.1.103 from D2:6F:50:94:4F:09
11:03:23 dhcp,info dhcp1 assigned 192.168.1.246 to A2:7E:4A:35:48:12
11:03:28 dhcp,info dhcp1 assigned 192.168.1.245 to D2:6F:50:94:4F:09
11:03:29 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.245
11:03:29 dhcp,info dhcp1 deassigned 192.168.1.245 from D2:6F:50:94:4F:09
11:03:33 dhcp,info dhcp1 assigned 192.168.1.245 to 3E:64:C6:2B:C5:1A
11:03:38 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.245
11:03:38 dhcp,info dhcp1 deassigned 192.168.1.245 from 3E:64:C6:2B:C5:1A
11:03:41 dhcp,info dhcp1 assigned 192.168.1.242 to D2:6F:50:94:4F:09
11:03:43 system,info,account user Admin logged in from 78:2B:CB:83:0B:CF via winbox
11:03:45 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.242
11:03:45 dhcp,info dhcp1 deassigned 192.168.1.242 from D2:6F:50:94:4F:09
11:03:57 dhcp,info dhcp1 assigned 192.168.1.240 to D2:6F:50:94:4F:09
11:04:02 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.240
11:04:02 dhcp,info dhcp1 deassigned 192.168.1.240 from D2:6F:50:94:4F:09
11:04:06 dhcp,info dhcp1 deassigned 192.168.1.246 from A2:7E:4A:35:48:12
11:04:07 system,info filter rule changed by Admin
11:04:07 dhcp,info dhcp1 assigned 192.168.1.246 to A2:7E:4A:35:48:12
11:04:59 dhcp,info dhcp1 assigned 192.168.1.85 to 54:7F:54:85:3A:1D
11:06:07 dhcp,info dhcp1 assigned 192.168.1.219 to D2:6F:50:94:4F:09
11:06:13 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.219
11:06:13 dhcp,info dhcp1 deassigned 192.168.1.219 from D2:6F:50:94:4F:09
11:06:24 dhcp,info dhcp1 assigned 192.168.1.219 to D2:6F:50:94:4F:09
11:06:29 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.219
11:06:29 dhcp,info dhcp1 deassigned 192.168.1.219 from D2:6F:50:94:4F:09
11:07:12 system,info filter rule changed by Admin
11:08:30 dhcp,info dhcp1 assigned 192.168.1.240 to D2:6F:50:94:4F:09
11:08:31 dhcp,info dhcp1 assigned 192.168.1.233 to DA:76:1E:C4:8A:AF
11:08:41 dhcp,info dhcp1 deassigned 192.168.1.240 from D2:6F:50:94:4F:09
11:08:44 dhcp,info dhcp1 assigned 192.168.1.240 to D2:6F:50:94:4F:09
11:08:45 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.240
11:08:45 dhcp,info dhcp1 deassigned 192.168.1.240 from D2:6F:50:94:4F:09
11:09:47 dhcp,info dhcp1 assigned 192.168.1.223 to D2:6F:50:94:4F:09
11:09:52 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.223
11:09:52 dhcp,info dhcp1 deassigned 192.168.1.223 from D2:6F:50:94:4F:09
11:10:00 dhcp,info dhcp1 assigned 192.168.1.243 to EC:F4:BB:68:47:AC
11:10:21 dhcp,info dhcp1 deassigned 192.168.1.144 from 5C:5F:67:6D:7A:40
11:10:22 dhcp,info dhcp1 assigned 192.168.1.99 to D2:6F:50:94:4F:09
11:10:24 dhcp,info dhcp1 deassigned 192.168.1.246 from A2:7E:4A:35:48:12
11:10:24 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.99
11:10:24 dhcp,info dhcp1 deassigned 192.168.1.99 from D2:6F:50:94:4F:09
11:10:30 dhcp,info dhcp1 deassigned 192.168.1.233 from DA:76:1E:C4:8A:AF
11:10:35 dhcp,info dhcp1 assigned 192.168.1.246 to A2:7E:4A:35:48:12
11:10:35 dhcp,warning Detected conflict by ARP response for 192.168.1.108 from 44:47:CC:BD:E5:48
11:10:40 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.246
11:10:40 dhcp,info dhcp1 deassigned 192.168.1.246 from A2:7E:4A:35:48:12
11:10:44 dhcp,info dhcp1 assigned 192.168.1.240 to D2:6F:50:94:4F:09
11:10:50 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.240
11:10:50 dhcp,info dhcp1 deassigned 192.168.1.240 from D2:6F:50:94:4F:09
11:10:52 dhcp,info dhcp1 assigned 192.168.1.224 to A2:7E:4A:35:48:12
11:10:53 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.224
11:10:53 dhcp,info dhcp1 deassigned 192.168.1.224 from A2:7E:4A:35:48:12
11:11:04 dhcp,info dhcp1 assigned 192.168.1.233 to D2:6F:50:94:4F:09
11:11:07 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.233
11:11:07 dhcp,info dhcp1 deassigned 192.168.1.233 from D2:6F:50:94:4F:09
11:11:09 dhcp,info dhcp1 assigned 192.168.1.219 to A2:7E:4A:35:48:12
11:11:11 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.219
11:11:11 dhcp,info dhcp1 deassigned 192.168.1.219 from A2:7E:4A:35:48:12
11:11:22 dhcp,info dhcp1 deassigned 192.168.1.247 from 2C:0E:3D:A4:76:50
11:11:27 dhcp,info dhcp1 assigned 192.168.1.76 to A2:7E:4A:35:48:12
11:11:31 dhcp,warning Detected conflict by ICMP response for 192.168.1.250
11:11:32 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.76
11:11:32 dhcp,info dhcp1 deassigned 192.168.1.76 from A2:7E:4A:35:48:12
11:12:02 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
11:12:19 dhcp,info dhcp1 assigned 192.168.1.220 to D2:6F:50:94:4F:09
11:12:34 dhcp,info dhcp1 deassigned 192.168.1.220 from D2:6F:50:94:4F:09
11:12:35 dhcp,info dhcp1 assigned 192.168.1.220 to D2:6F:50:94:4F:09
11:12:37 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.220
11:12:37 dhcp,info dhcp1 deassigned 192.168.1.220 from D2:6F:50:94:4F:09
11:12:40 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
11:12:41 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
11:12:49 dhcp,info dhcp1 assigned 192.168.1.220 to D2:6F:50:94:4F:09
11:12:54 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.220
11:12:54 dhcp,info dhcp1 deassigned 192.168.1.220 from D2:6F:50:94:4F:09
11:13:02 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
11:13:03 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
11:13:05 dhcp,info dhcp1 assigned 192.168.1.254 to D2:6F:50:94:4F:09
11:13:09 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.254
11:13:09 dhcp,info dhcp1 deassigned 192.168.1.254 from D2:6F:50:94:4F:09
11:13:21 dhcp,info dhcp1 assigned 192.168.1.253 to D2:6F:50:94:4F:09
11:13:42 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
11:13:43 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
11:13:47 dhcp,info dhcp1 deassigned 192.168.1.253 from D2:6F:50:94:4F:09
11:13:49 dhcp,info dhcp1 assigned 192.168.1.253 to D2:6F:50:94:4F:09
11:13:55 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.253
11:13:55 dhcp,info dhcp1 deassigned 192.168.1.253 from D2:6F:50:94:4F:09
11:14:18 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
11:14:19 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
11:14:22 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
11:14:23 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
11:14:43 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
11:14:44 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
11:16:21 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
11:16:22 dhcp,info dhcp1 assigned 192.168.1.227 to A2:7E:4A:35:48:12
11:16:24 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.227
11:16:24 dhcp,info dhcp1 deassigned 192.168.1.227 from A2:7E:4A:35:48:12
11:16:41 dhcp,info dhcp1 assigned 192.168.1.242 to D2:6F:50:94:4F:09
11:17:10 dhcp,info dhcp1 deassigned 192.168.1.242 from D2:6F:50:94:4F:09
11:17:12 dhcp,info dhcp1 assigned 192.168.1.242 to D2:6F:50:94:4F:09
11:17:17 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.242
11:17:17 dhcp,info dhcp1 deassigned 192.168.1.242 from D2:6F:50:94:4F:09
11:17:20 dhcp,info dhcp1 assigned 192.168.1.184 to A2:7E:4A:35:48:12
11:17:41 dhcp,info dhcp1 deassigned 192.168.1.184 from A2:7E:4A:35:48:12
11:17:42 dhcp,info dhcp1 assigned 192.168.1.184 to A2:7E:4A:35:48:12
11:17:43 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.184
11:17:43 dhcp,info dhcp1 deassigned 192.168.1.184 from A2:7E:4A:35:48:12
11:17:57 dhcp,info dhcp1 assigned 192.168.1.240 to D2:6F:50:94:4F:09
11:19:42 dhcp,info dhcp1 deassigned 192.168.1.231 from B8:D7:AF:1E:F0:83
11:19:49 dhcp,info dhcp1 deassigned 192.168.1.240 from D2:6F:50:94:4F:09
11:19:51 dhcp,info dhcp1 assigned 192.168.1.240 to D2:6F:50:94:4F:09
11:19:53 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.240
11:19:53 dhcp,info dhcp1 deassigned 192.168.1.240 from D2:6F:50:94:4F:09
11:19:55 dhcp,info dhcp1 assigned 192.168.1.112 to A2:7E:4A:35:48:12
11:20:05 dhcp,info dhcp1 deassigned 192.168.1.112 from A2:7E:4A:35:48:12
11:20:06 dhcp,info dhcp1 assigned 192.168.1.112 to A2:7E:4A:35:48:12
11:22:33 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from C4:E9:0A:82:4A:A0
11:22:36 dhcp,info dhcp1 assigned 192.168.1.248 to 3E:64:C6:2B:C5:1A
11:22:38 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.248
11:22:38 dhcp,info dhcp1 deassigned 192.168.1.248 from 3E:64:C6:2B:C5:1A
11:22:39 dhcp,info dhcp1 assigned 192.168.1.247 to DA:76:1E:C4:8A:AF
11:24:04 dhcp,info dhcp1 assigned 192.168.1.147 to CE:F8:D5:DE:5F:79
11:24:10 dhcp,warning dhcp1 client CE:F8:D5:DE:5F:79 declines IP address 192.168.1.147
11:24:10 dhcp,info dhcp1 deassigned 192.168.1.147 from CE:F8:D5:DE:5F:79
11:24:30 dhcp,info dhcp1 assigned 192.168.1.185 to D2:6F:50:94:4F:09
11:24:36 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.185
11:24:36 dhcp,info dhcp1 deassigned 192.168.1.185 from D2:6F:50:94:4F:09
11:24:47 dhcp,info dhcp1 assigned 192.168.1.105 to CE:F8:D5:DE:5F:79
11:24:53 dhcp,warning dhcp1 client CE:F8:D5:DE:5F:79 declines IP address 192.168.1.105
11:24:53 dhcp,info dhcp1 deassigned 192.168.1.105 from CE:F8:D5:DE:5F:79
11:25:08 dhcp,info dhcp1 assigned 192.168.1.246 to D2:6F:50:94:4F:09
11:25:15 dhcp,info dhcp1 assigned 192.168.1.232 to 3E:64:C6:2B:C5:1A
11:25:16 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.246
11:25:16 dhcp,info dhcp1 deassigned 192.168.1.246 from D2:6F:50:94:4F:09
11:25:19 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.232
11:25:19 dhcp,info dhcp1 deassigned 192.168.1.232 from 3E:64:C6:2B:C5:1A
11:25:21 dhcp,info dhcp1 assigned 192.168.1.254 to CE:F8:D5:DE:5F:79
11:25:23 dhcp,warning dhcp1 client CE:F8:D5:DE:5F:79 declines IP address 192.168.1.254
11:25:23 dhcp,info dhcp1 deassigned 192.168.1.254 from CE:F8:D5:DE:5F:79
11:25:27 dhcp,info dhcp1 assigned 192.168.1.246 to D2:6F:50:94:4F:09
11:25:32 dhcp,info dhcp1 assigned 192.168.1.254 to 3E:64:C6:2B:C5:1A
11:25:33 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.246
11:25:33 dhcp,info dhcp1 deassigned 192.168.1.246 from D2:6F:50:94:4F:09
11:25:33 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.254
11:25:33 dhcp,info dhcp1 deassigned 192.168.1.254 from 3E:64:C6:2B:C5:1A
11:25:46 dhcp,info dhcp1 assigned 192.168.1.211 to 3E:64:C6:2B:C5:1A
11:25:49 dhcp,info dhcp1 assigned 192.168.1.214 to D2:6F:50:94:4F:09
11:25:51 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.211
11:25:51 dhcp,info dhcp1 deassigned 192.168.1.211 from 3E:64:C6:2B:C5:1A
11:26:00 dhcp,info dhcp1 deassigned 192.168.1.214 from D2:6F:50:94:4F:09
11:26:01 dhcp,info dhcp1 assigned 192.168.1.214 to D2:6F:50:94:4F:09
11:26:07 dhcp,warning dhcp1 client D2:6F:50:94:4F:09 declines IP address 192.168.1.214
11:26:07 dhcp,info dhcp1 deassigned 192.168.1.214 from D2:6F:50:94:4F:09
11:26:36 dhcp,info dhcp1 assigned 192.168.1.252 to 3E:64:C6:2B:C5:1A
11:26:41 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.252
11:26:41 dhcp,info dhcp1 deassigned 192.168.1.252 from 3E:64:C6:2B:C5:1A
11:27:17 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from C4:E9:0A:82:4A:A0
11:28:47 dhcp,info dhcp1 assigned 192.168.1.240 to CE:F8:D5:DE:5F:79
11:28:50 dhcp,info dhcp1 assigned 192.168.1.238 to D2:6F:50:94:4F:09
11:28:52 dhcp,warning dhcp1 client CE:F8:D5:DE:5F:79 declines IP address 192.168.1.240
11:28:52 dhcp,info dhcp1 deassigned 192.168.1.240 from CE:F8:D5:DE:5F:79
11:28:55 dhcp,info dhcp1 assigned 192.168.1.240 to CE:F8:D5:DE:5F:79
11:29:01 dhcp,warning dhcp1 client CE:F8:D5:DE:5F:79 declines IP address 192.168.1.240
11:29:01 dhcp,info dhcp1 deassigned 192.168.1.240 from CE:F8:D5:DE:5F:79
11:29:15 dhcp,info dhcp1 deassigned 192.168.1.112 from A2:7E:4A:35:48:12
11:29:16 dhcp,info dhcp1 assigned 192.168.1.112 to A2:7E:4A:35:48:12
11:29:21 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.112
11:29:21 dhcp,info dhcp1 deassigned 192.168.1.112 from A2:7E:4A:35:48:12
11:29:41 dhcp,info dhcp1 assigned 192.168.1.158 to A2:7E:4A:35:48:12
11:29:47 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.158
11:29:47 dhcp,info dhcp1 deassigned 192.168.1.158 from A2:7E:4A:35:48:12
11:30:08 dhcp,info dhcp1 assigned 192.168.1.246 to A2:7E:4A:35:48:12
11:30:27 dhcp,info dhcp1 deassigned 192.168.1.246 from A2:7E:4A:35:48:12
11:30:28 dhcp,info dhcp1 assigned 192.168.1.246 to A2:7E:4A:35:48:12
11:30:34 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.246
11:30:34 dhcp,info dhcp1 deassigned 192.168.1.246 from A2:7E:4A:35:48:12
11:32:39 dhcp,info dhcp1 deassigned 192.168.1.247 from DA:76:1E:C4:8A:AF
11:38:00 dhcp,info dhcp1 assigned 192.168.1.119 to A2:7E:4A:35:48:12
11:38:02 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.119
11:38:02 dhcp,info dhcp1 deassigned 192.168.1.119 from A2:7E:4A:35:48:12
11:38:43 dhcp,info dhcp1 assigned 192.168.1.254 to A2:7E:4A:35:48:12
11:38:47 dhcp,warning dhcp1 client A2:7E:4A:35:48:12 declines IP address 192.168.1.254
11:38:47 dhcp,info dhcp1 deassigned 192.168.1.254 from A2:7E:4A:35:48:12
11:38:48 dhcp,info dhcp1 assigned 192.168.1.254 to 70:66:55:FC:14:CD
11:43:50 dhcp,info dhcp1 deassigned 192.168.1.238 from D2:6F:50:94:4F:09
11:46:13 dhcp,info dhcp1 deassigned 192.168.1.127 from D8:CB:8A:00:77:25
11:46:13 dhcp,info dhcp1 assigned 192.168.1.127 to D8:CB:8A:00:77:25
11:47:48 dhcp,info dhcp1 assigned 192.168.1.252 to 2C:0E:3D:A4:76:50
11:49:20 dhcp,info dhcp1 assigned 192.168.1.88 to A2:7E:4A:35:48:12
11:50:14 dhcp,warning Detected conflict by ARP response for 192.168.1.250 from C4:E9:0A:82:4A:A0
11:51:06 dhcp,info dhcp1 assigned 192.168.1.242 to 3E:64:C6:2B:C5:1A
11:51:08 dhcp,warning dhcp1 client 3E:64:C6:2B:C5:1A declines IP address 192.168.1.242
11:51:08 dhcp,info dhcp1 deassigned 192.168.1.242 from 3E:64:C6:2B:C5:1A
11:52:31 dhcp,info dhcp1 assigned 192.168.1.242 to 3E:64:C6:2B:C5:1A
11:57:40 dhcp,info dhcp1 assigned 192.168.1.144 to 5C:5F:67:6D:7A:40
11:59:20 dhcp,info dhcp1 deassigned 192.168.1.88 from A2:7E:4A:35:48:12
11:59:52 dhcp,info dhcp1 deassigned 192.168.1.85 from 54:7F:54:85:3A:1D
11:59:53 dhcp,info dhcp1 assigned 192.168.1.85 to 54:7F:54:85:3A:1D
12:00:01 dhcp,info dhcp1 deassigned 192.168.1.243 from EC:F4:BB:68:47:AC
12:00:05 dhcp,info dhcp1 deassigned 192.168.1.85 from 54:7F:54:85:3A:1D
12:00:05 dhcp,info dhcp1 assigned 192.168.1.85 to 54:7F:54:85:3A:1D
12:00:17 dhcp,info dhcp1 deassigned 192.168.1.85 from 54:7F:54:85:3A:1D
12:00:17 dhcp,info dhcp1 assigned 192.168.1.85 to 54:7F:54:85:3A:1D
12:02:58 system,info,account user Admin logged in from BC:E9:2F:87:91:54 via winbox
12:02:59 system,info,account user Admin logged in via local
12:06:47 dhcp,info dhcp1 assigned 192.168.1.88 to A2:7E:4A:35:48:12
12:07:40 dhcp,info dhcp1 deassigned 192.168.1.144 from 5C:5F:67:6D:7A:40
12:10:19 dhcp,info dhcp1 deassigned 192.168.1.254 from 70:66:55:FC:14:CD
12:21:38 dhcp,info dhcp1 deassigned 192.168.1.88 from A2:7E:4A:35:48:12
12:25:07 dhcp,info dhcp1 deassigned 192.168.1.161 from 86:3A:32:28:B6:D4
12:28:37 dhcp,info dhcp1 deassigned 192.168.1.251 from D8:C4:E9:88:5D:91
12:28:37 dhcp,info dhcp1 assigned 192.168.1.251 to D8:C4:E9:88:5D:91
12:32:59 system,info,account user Admin logged in via local
12:33:26 dhcp,info dhcp1 assigned 192.168.1.254 to 40:D3:AE:64:32:40
12:36:59 system,info filter rule added by Admin
12:37:01 system,info filter rule added by Admin
12:38:04 system,info filter rule moved by Admin
12:50:43 dhcp,info dhcp1 assigned 192.168.1.207 to B4:F6:1C:F0:86:BC
12:53:19 system,info filter rule added by Admin
12:53:42 system,info filter rule changed by Admin
12:53:48 system,info filter rule moved by Admin
12:53:57 system,info filter rule changed by Admin
12:54:04 system,info filter rule changed by Admin
12:56:20 dhcp,info dhcp1 assigned 192.168.1.253 to 32:F2:14:A0:27:4A
12:57:22 system,info user admin password changed by Admin
12:57:23 system,info user admin password changed by Admin
12:57:28 system,info,account user Admin logged in via local
12:57:33 system,info,account user Admin logged out via local
12:57:34 dhcp,info dhcp1 deassigned 192.168.1.251 from D8:C4:E9:88:5D:91
12:57:34 dhcp,info dhcp1 assigned 192.168.1.251 to D8:C4:E9:88:5D:91
12:59:07 dhcp,info dhcp1 assigned 192.168.1.161 to 86:3A:32:28:B6:D4
13:00:29 dhcp,info dhcp1 assigned 192.168.1.160 to CC:AF:78:4A:1F:63
13:00:56 system,info,account user Admin logged out from BC:E9:2F:87:91:54 via winbox
13:00:56 system,info,account user Admin logged out via local
13:01:04 dhcp,info dhcp1 assigned 192.168.1.250 to 70:66:55:FC:14:CD
13:01:08 dhcp,info dhcp1 deassigned 192.168.1.161 from 86:3A:32:28:B6:D4
13:01:08 dhcp,info dhcp1 assigned 192.168.1.161 to 86:3A:32:28:B6:D4
13:03:10 dhcp,info dhcp1 deassigned 192.168.1.242 from 3E:64:C6:2B:C5:1A
13:03:13 dhcp,info dhcp1 assigned 192.168.1.242 to 3E:64:C6:2B:C5:1A
13:06:20 dhcp,info dhcp1 deassigned 192.168.1.253 from 32:F2:14:A0:27:4A
13:11:24 dhcp,info dhcp1 deassigned 192.168.1.250 from 70:66:55:FC:14:CD
13:14:46 dhcp,info dhcp1 assigned 192.168.1.243 to EC:F4:BB:68:47:AC
13:17:44 dhcp,info dhcp1 assigned 192.168.1.118 to 2A:78:2C:49:58:76
13:23:09 system,info,account user Admin logged in from BC:E9:2F:87:91:54 via winbox
13:23:09 system,info,account user Admin logged in via local
13:23:10 system,info,account user Admin logged in via local
13:25:38 dhcp,info dhcp1 assigned 192.168.1.253 to 0A:B3:BD:71:E2:B9
13:26:08 system,info,account user Admin logged in via local
13:26:14 dhcp,info dhcp1 assigned 192.168.1.250 to CE:F8:D5:DE:5F:79
13:27:16 dhcp,info dhcp1 deassigned 192.168.1.251 from D8:C4:E9:88:5D:91
13:27:40 dhcp,info dhcp1 assigned 192.168.1.238 to D2:6F:50:94:4F:09
13:27:44 dhcp,info dhcp1 assigned 192.168.1.88 to A2:7E:4A:35:48:12
13:31:23 dhcp,info dhcp1 assigned 192.168.1.251 to DA:76:1E:C4:8A:AF
13:32:44 dhcp,info dhcp1 deassigned 192.168.1.118 from 2A:78:2C:49:58:76
13:35:38 dhcp,info dhcp1 deassigned 192.168.1.253 from 0A:B3:BD:71:E2:B9
13:36:14 dhcp,info dhcp1 deassigned 192.168.1.250 from CE:F8:D5:DE:5F:79
13:38:23 system,info,account user Admin logged out from BC:E9:2F:87:91:54 via winbox
13:38:23 system,info,account user Admin logged out via local
13:40:29 dhcp,info dhcp1 deassigned 192.168.1.160 from CC:AF:78:4A:1F:63
13:40:41 system,info,account user Admin logged in from BC:E9:2F:87:91:54 via winbox
13:40:42 system,info,account user Admin logged in via local
Could it my something in my Mikrotik Router's config that could be responsible for that? I thought it could be the switch, but like said, before we installed that router, we didn't have that problem.
Here's our current config:
# nov/25/2020 13:26:47 by RouterOS 6.47.7
# model = RB750Gr3
set [ find default-name=ether1 ] comment=WAN1 name=ether1-WAN1
set [ find default-name=ether4 ] comment=LAN2 name=ether4-LAN2
set [ find default-name=ether5 ] comment=LAN1 name=ether5-LAN1
add name=LAN
add name=WAN
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.1.70-192.168.1.254
add name=dhcp_pool5 ranges=192.168.0.2-192.168.0.254
add address-pool=dhcp_pool0 disabled=no interface=ether4-LAN2 name=dhcp1
add address-pool=dhcp_pool5 interface=ether5-LAN1 name=dhcp2
add interface=ether4-LAN2 list=LAN
add interface=ether5-LAN1 list=LAN
add interface=ether1-WAN1 list=WAN
add address=192.168.1.1/24 interface=ether4-LAN2 network=192.168.1.0
add address=192.168.0.1/24 interface=ether5-LAN1 network=192.168.0.0
add address=172.21.111.74/30 interface=ether1-WAN1 network=172.21.111.72
/ip dhcp-client
add address=192.168.0.0/24 gateway=192.168.0.1
add address=192.168.1.0/24 gateway=192.168.1.1
set servers=8.8.8.8,1.1.1.1
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=output comment="Block port 25 (SMTP)" log=yes \
    log-prefix=Spammers_ protocol=25
add action=add-src-to-address-list address-list=spammers \
    address-list-timeout=3h chain=forward comment=\
    "Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=\
    25,587 limit=30/1m,0:packet log=yes log-prefix=Spammers_ protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 \
    log=yes log-prefix=Spammers_ protocol=tcp src-address-list=spammers
add action=drop chain=forward comment="Prevent inter LANs communications" \
    in-interface=ether4-LAN2 out-interface=ether5-LAN1
    in-interface=ether5-LAN1 out-interface=ether4-LAN2
    connection-state=invalid
add action=dst-nat chain=dstnat comment=MGCP dst-port=5426 protocol=udp \
    src-address=197.14.111.2 to-addresses=192.168.0.101 to-ports=1245
add action=dst-nat chain=dstnat comment=PTAP dst-port=9654 protocol=udp \
    src-address=197.14.111.2 to-addresses=192.168.0.101 to-ports=5421
add action=dst-nat chain=dstnat comment="PBX Remote" dst-port=8541 protocol=\
    tcp to-addresses=192.168.0.101 to-ports=6652
add action=dst-nat chain=dstnat comment=MGCP dst-port=9654 protocol=udp \
    src-address=197.14.111.2 to-addresses=192.168.0.101 to-ports=4521
add action=dst-nat chain=dstnat comment="Paging\?" dst-port=8421 protocol=udp \
    src-address=197.14.111.2 to-addresses=192.168.0.101 to-ports=8421
add action=dst-nat chain=dstnat comment=cs dst-port=6214 protocol=udp \
    src-address=197.14.111.2 to-addresses=192.168.0.101 to-ports=6214
add action=dst-nat chain=dstnat comment=CS dst-port=4125 protocol=udp \
    src-address=197.14.111.2 to-addresses=192.168.0.101 to-ports=4125
add action=dst-nat chain=dstnat comment=PAGING-udp dst-port=74521 protocol=\
    udp src-address=197.14.111.2 to-addresses=192.168.0.101 to-ports=8421
add action=dst-nat chain=dstnat comment=PAGING-tcp dst-port=74521 protocol=\
    tcp src-address=197.14.111.2 to-addresses=192.168.0.101 to-ports=8421
add action=dst-nat chain=dstnat comment=paging-udp dst-port=74521 protocol=\
    udp src-address=197.14.111.2 to-addresses=192.168.0.102 to-ports=\
    12000-12300
add action=dst-nat chain=dstnat comment="SIP TRUNK" dst-port=45189 protocol=\
    udp src-address=197.14.111.2 to-addresses=192.168.0.101 to-ports=45189
add action=dst-nat chain=dstnat comment=paging-tcp dst-port=74521 protocol=\
    tcp src-address=197.14.111.2 to-addresses=192.168.0.102 to-ports=\
    12000-12300
add action=dst-nat chain=dstnat comment=RTP dst-port=12000-12300 protocol=udp \
    src-address=197.14.111.2 to-addresses=192.168.0.102 to-ports=12000-12300
/ip firewall service-port
set sip disabled=yes
add distance=1 gateway=172.21.111.73
/system clock
set time-zone-name=America/Moncton
/tool mac-server
/tool mac-server mac-winbox
JimLafleur
Re: 2 separate subnets on 2 different router's ports
Wed Nov 25, 2020 9:13 pm
Here's the ARP table. We can see that a bunch of devices have that same MAC address B0:B9:8A:C5:0A:0B. Those devices don't exist.
# nov/25/2020 15:10:16 by RouterOS 6.47.7
Flags: X - disabled, I - invalid, H - DHCP, D - dynamic, P - published,
C - complete
 #    ADDRESS         MAC-ADDRESS       INTERFACE
 0 DC 156.34.130.73   00:90:1A:A2:22:5C ether1-WAN1
 1 DC 192.168.1.84    A4:5D:36:9C:20:BD ether4-LAN2
 2 DC 192.168.1.190   6C:3B:E5:2A:BC:53 ether4-LAN2
 3 DC 192.168.0.101   BC:C3:42:EB:FE:AE ether5-LAN1
 4 DC 192.168.1.130   00:23:24:73:E5:8A ether4-LAN2
 5 DC 192.168.1.181   8C:DC:D4:48:19:D5 ether4-LAN2
 6 DC 192.168.1.110   B0:83:FE:A7:0C:5A ether4-LAN2
 7 DC 192.168.1.90    E4:11:5B:F5:5F:20 ether4-LAN2
 8 DC 192.168.1.19    9C:93:4E:B4:1F:C2 ether4-LAN2
 9 DC 192.168.1.117   30:52:CB:31:4E:6D ether4-LAN2
10 DC 192.168.1.50    78:2B:CB:83:0B:CF ether4-LAN2
11 DC 192.168.1.97    04:D9:F5:7D:84:85 ether4-LAN2
12 DC 192.168.1.2     BC:AE:C5:E3:3E:EA ether4-LAN2
13 DC 192.168.1.191   8C:DC:D4:41:6D:33 ether4-LAN2
14 DC 192.168.1.108   44:47:CC:BD:E5:48 ether4-LAN2
15 DC 192.168.1.230   54:BF:64:10:30:BB ether4-LAN2
16 DC 192.168.1.96    9C:8E:99:DC:17:DB ether4-LAN2
17 DC 192.168.1.100   08:9E:01:42:8F:00 ether4-LAN2
18 DC 192.168.0.125   B0:B9:8A:C5:0A:0B ether5-LAN1
19 DC 192.168.0.121   B0:B9:8A:C5:0A:0B ether5-LAN1
20 DC 192.168.0.128   B0:B9:8A:C5:0A:0B ether5-LAN1
21 DC 192.168.0.124   B0:B9:8A:C5:0A:0B ether5-LAN1
22 DC 192.168.0.120   B0:B9:8A:C5:0A:0B ether5-LAN1
23 DC 192.168.0.127   B0:B9:8A:C5:0A:0B ether5-LAN1
24 DC 192.168.0.123   B0:B9:8A:C5:0A:0B ether5-LAN1
25 DC 192.168.0.119   B0:B9:8A:C5:0A:0B ether5-LAN1
26 DC 192.168.0.126   B0:B9:8A:C5:0A:0B ether5-LAN1
27 DC 192.168.0.122   B0:B9:8A:C5:0A:0B ether5-LAN1
28 DC 192.168.0.148   B0:B9:8A:C5:0A:0B ether5-LAN1
29 DC 192.168.0.144   B0:B9:8A:C5:0A:0B ether5-LAN1
30 DC 192.168.0.140   B0:B9:8A:C5:0A:0B ether5-LAN1
31 DC 192.168.0.136   B0:B9:8A:C5:0A:0B ether5-LAN1
32 DC 192.168.0.132   B0:B9:8A:C5:0A:0B ether5-LAN1
33 DC 192.168.0.151   B0:B9:8A:C5:0A:0B ether5-LAN1
34 DC 192.168.0.147   B0:B9:8A:C5:0A:0B ether5-LAN1
35 DC 192.168.0.143   B0:B9:8A:C5:0A:0B ether5-LAN1
36 DC 192.168.0.139   B0:B9:8A:C5:0A:0B ether5-LAN1
37 DC 192.168.0.131   B0:B9:8A:C5:0A:0B ether5-LAN1
38 DC 192.168.0.150   B0:B9:8A:C5:0A:0B ether5-LAN1
39 DC 192.168.0.146   B0:B9:8A:C5:0A:0B ether5-LAN1
40 DC 192.168.0.142   B0:B9:8A:C5:0A:0B ether5-LAN1
41 DC 192.168.0.138   B0:B9:8A:C5:0A:0B ether5-LAN1
42 DC 192.168.0.134   B0:B9:8A:C5:0A:0B ether5-LAN1
43 DC 192.168.0.130   B0:B9:8A:C5:0A:0B ether5-LAN1
44 DC 192.168.0.149   B0:B9:8A:C5:0A:0B ether5-LAN1
45 DC 192.168.0.145   B0:B9:8A:C5:0A:0B ether5-LAN1
46 DC 192.168.0.141   B0:B9:8A:C5:0A:0B ether5-LAN1
47 DC 192.168.0.137   B0:B9:8A:C5:0A:0B ether5-LAN1
48 DC 192.168.0.133   B0:B9:8A:C5:0A:0B ether5-LAN1
49 DC 192.168.0.129   B0:B9:8A:C5:0A:0B ether5-LAN1
50 DC 192.168.0.135   B0:B9:8A:C5:0A:0B ether5-LAN1
51 DC 192.168.1.5     C4:E9:0A:82:4A:A0 ether4-LAN2
52 D  192.168.1.207   B4:F6:1C:F0:86:BC ether4-LAN2
53 DC 192.168.1.243   EC:F4:BB:68:47:AC ether4-LAN2
54 DC 192.168.1.238   D2:6F:50:94:4F:09 ether4-LAN2
55 D  192.168.1.160   CC:AF:78:4A:1F:63 ether4-LAN2
56 DC 192.168.1.254   40:D3:AE:64:32:40 ether4-LAN2
57 DC 192.168.0.51    BC:E9:2F:87:91:54 ether5-LAN1
58 DC 192.168.1.127   D8:CB:8A:00:77:25 ether4-LAN2
59 DC 192.168.1.242   3E:64:C6:2B:C5:1A ether4-LAN2
60 DC 192.168.1.252   2C:0E:3D:A4:76:50 ether4-LAN2
61 DC 192.168.1.200   A4:13:4E:B8:50:90 ether4-LAN2
62 DC 192.168.1.72    A4:13:4E:A0:2C:F0 ether4-LAN2
63 DC 192.168.1.94    B8:B7:D7:0B:47:D8 ether4-LAN2
64 DC 192.168.1.253   16:2D:BA:D8:56:4E ether4-LAN2
65 D  192.168.0.111   16:2D:BA:D8:56:4E ether5-LAN1
66 DC 192.168.1.88    A2:7E:4A:35:48:12 ether4-LAN2
67 DC 192.168.1.182   5C:F2:07:34:48:93 ether4-LAN2
68 DC 192.168.1.251   D8:C4:E9:88:5D:91 ether4-LAN2
mkx
Wed Nov 25, 2020 9:19 pm
MAC address can easily be spoofed or set manually. And it seems as if that device was doing some proxy-arp for whole subnet.
BR,
Metod
JimLafleur
Wed Nov 25, 2020 9:25 pm
Could a malware do that? Or would it be one of the device doing that?
mkx
Wed Nov 25, 2020 9:44 pm
I don't know if normal network interfaces (with normal drivers) can actually have multiple MAC addresses set. So most probably that device has only one MAC address set. Sure some malware can change MAC address.
I guess you'll have to "pull the wires" to find out which part of physical network that device is connected to. Start a ping (endless) to one of those IP addresses (verify that it's the plaintiff responding) and start disconnecting wires from network nodes (router, switches) untill you determine which branch is it. Then move further to tge next node in that branch and repeat the exercise with wires. Alternatively you can disable individual ports on router/switches (if that's possible).
BR,
Metod
anav
Wed Nov 25, 2020 9:53 pm
Looks like a typical MKX config to me,,, couldn't resist!! ;-))))
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
JimLafleur
Wed Nov 25, 2020 10:19 pm
But could it be the Mikrotik router config? Before we replaced the router we didn't experience any ip conflic problems.
mkx
Wed Nov 25, 2020 11:05 pm
Anything is possible. And you should start ruling out some possibilities. One possibility is to tripple-check full Mikrotik config, including MAC addresses of all interfaces. The Netgear MAC address should be present in exported config because it can't be default setting.
BR,
Metod
JimLafleur
Wed Nov 25, 2020 11:24 pm
How do I export this? I already did: export hide-sensitive file=anynameyouwish
I went into Interfaces and checked the MAC of all the interfaces. They all start with "C4:AD:34"
JimLafleur
Wed Nov 25, 2020 11:39 pm
Here's the MAC address part of the config:
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled \
    arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited \
    comment=WAN1 disabled=no full-duplex=yes l2mtu=1596 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=\
    C4:AD:34:91:1F:1A mtu=1500 name=ether1-WAN1 orig-mac-address=\
    C4:AD:34:91:1F:1A rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether2 ] advertise=\
    C4:AD:34:91:1F:1B mtu=1500 name=ether2 orig-mac-address=C4:AD:34:91:1F:1B \
set [ find default-name=ether3 ] advertise=\
    C4:AD:34:91:1F:1C mtu=1500 name=ether3 orig-mac-address=C4:AD:34:91:1F:1C \
set [ find default-name=ether4 ] advertise=\
    comment=LAN2 disabled=no full-duplex=yes l2mtu=1596 loop-protect=default \
    C4:AD:34:91:1F:1D mtu=1500 name=ether4-LAN2 orig-mac-address=\
    C4:AD:34:91:1F:1D rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether5 ] advertise=\
    comment=LAN1 disabled=no full-duplex=yes l2mtu=1596 loop-protect=default \
    C4:AD:34:91:1F:1E mtu=1500 name=ether5-LAN1 orig-mac-address=\
    C4:AD:34:91:1F:1E rx-flow-control=off speed=1Gbps tx-flow-control=off
JimLafleur
Thu Nov 26, 2020 1:11 am
So is this a good way to troubleshoot this:
Unplug 1 cable from the switch.
Clear the ARP table of the Mikrotik Router.
Wait 1 minute to see if that buggy MAC address comes back.
If yes, repeat with the next cable from the switch.
Sound good?
Or on windows use the arp -a command?
Any other useful tools? I know of Wireshark with the "arp" filter. Any other good filter?
JimLafleur
Thu Nov 26, 2020 2:54 am
Hi man,
I think we've nailed it.
When I've arrived this morning, I've unplugged the new ventilation controller (that they've installed this week) from the switch and plugged my laptop. No problems, really, noted all day long I was troubleshooting.
Before I left this afternoon, I unplugged my laptop and re-plugged the new ventilation controller to the only port left on the 28 ports switch.
Tonight, got a call from the staff saying that their IP Phones started back to say there was some IP conflicts. I've connected to the office and saw lots of arp traffic (wireshark) related to that weird MAC address B0:B9:8A... (Associated with Netgear Manufacturer). And also notice an IP not related to our subnets in there ( In the 173.x.x.x range.).
I've used XArp (new to me) : Advanced ARP Spoofing Detection : XArp performs advanced ARP spoofing detection mechanism. As soon as I've started it said "ARP attack" in big, but I couldn't really see the culprit just then. I've let it run for 1 hour before going back to the office. It got time to collect data (707 alerts when I checked). When I arrived at the office I saw that 2 IPs out of our subnets ( In the 173.x.x.x range.) were quite frequent. In XArp theres a column named "How often seen"; Well 1 was at 30 and the other one was at 4. The one at 4 also showed the name of the ventilation controller Manufacturer in the Vendor column! Bingo!
And guess what? One of those IP was written on the "Netgear" cellular router they used for their install, right close to the roof!
As soon as I've disconnected the RJ45 cable coming from that ventilation controller, all returned to normal. The wireshark output was a lot more quiet, with no more B0:B9:8A... MAC address. The phones started reconnecting properly (after a reboot). The network scans were normal. And, after a restart, Xarp said in big: No ARP attacks!
What a relief!!!
Thanks so much mkx for pointing me in that right direction (ARP Proxy). That was the key to resolve this whole weird thing happening!
JimLafleur
Thu Dec 03, 2020 4:59 am
The migration to the SIP trunk was done yesterday and everything went well.
I wanted to thank everyone on this thread for helping me out. I really appreciate it.
mkx
tdw
anav
aesmith
Thank you!
Users browsing this forum: andyh747, Baidu [Spider], Bing [Bot] and 69 guests
