Firstly I'd just like to say that I'm a complete beginner to Mikrotik xD
I'm trying to remove the default bridge on the hAP ac2 because each port will be used for a different VLAN (eventually I'd like to set up port isolation because of this) but I just keep getting locked out. I've tried changing the MAC address of the bridge and then removing all of the ports but no dice.
Before I delete the bridge, I notice that in the IP address list, the initial IP address the device has (192.168.88.1) is assigned to port 2 and not the bridge. Since I managed to remove other ports above port 2 and 3 (I'm connected via port 3) I thought I'd assign a different port an IP address (192.168.88.3) to try and connect that way outside of the bridge. I change the cable over to that port but get no connectivity. However upon switching the cable back to port 3 I can no longer connect (but I can ping).
I've no idea why it's doing this :S
I'd like to only use bridges when I need to setup a WAP to join to one of the VLANs. I intend to repurpose the WAN port to be a trunk port carrying out the VLANs on to my router.
Thanks in advance for any help!
