igpetkov
Firewall message
Tue Dec 22, 2020 7:57 am
Hi,All!!
I have multiple messagess in my router log with same conntent.
Can someone explain it?
Time: Dec/22/2020 07:51:32
Buffer: memory
Topics: firewall
info
Message: dstnat: in:sfp1 out:(unknown 0), src-mac 00:23:3e:5e:7f:9a, proto TCP (SYN), 87.251.67.74:34330->my external ip:57816, len 52
Is that some kind of attack?
Thank You
Sob
Re: Firewall message
Tue Dec 22, 2020 9:35 pm
Some of your firewall NAT rules has enabled logging, so you see this message when matching connection comes in. Find which one, check what if does, if you need it, etc.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
Users browsing this forum: Baidu [Spider] and 50 guests
