Chatterstatic
Firewall connections
Fri Dec 25, 2020 6:37 pm
How can i log what comes on to the Firewall connections page, i have persistant logs going to a remote syslog server.
Thanks...
moveik
Re: Firewall connections
Fri Dec 25, 2020 11:04 pm
Via WebFig:
Simply click on the firewall rule (From menu: IP -> Firewall) and near the bottom of the page (after you scroll down) you see the option "Log" - tick the checkbox.
Then, you will see the log in the Log page (if a matching packet has arrived).
Chatterstatic
Fri Dec 25, 2020 11:41 pm
Via WebFig:
Thanks, next question is which of the firewall rules show everything in the connections tab?
Hominidae
Sat Dec 26, 2020 1:24 am
...try this; create a rule with action = log with the connection state set to an appropriate value you wish to track
Users browsing this forum: Bing [Bot], iokdss, spmd and 65 guests
