I am a new mikrotik user and have been using a LtAP LTE6 to connect to an LTE network for internet access in my home network. I am on ROS 6.46.8 and the modem is on firmware V26. When I first purchased the devise the network connection was incredibly stable and fast. Since updating the modem, or possibly the ROS version, I now suffer from disconnects that take my network down for a little over a minute. I tried ROS 6.48 to see if that would have any positive effect on my situation but it did not. I've also completely reset the router and that has made no difference. I have a very simple setup with the LtAP only connecting to the LTE network and then serving as the uplink for a pfsense router. I've seen other postings on this forum that suggest there is a problem with the modem firmware.
I have enabled logging and do notice what I believe is the problem that is occurring. Here is the output of the latest event at 0618 this morning. I see the same type of issues every time the network connection dies. Would appreciate any help or confirmation of a firmware bug that anyone can provide.
Code: Select all
06:18:52 lte,async,raw lte1: +CREG: 0
06:18:52 lte,async,raw lte1: $CREG: 0
06:18:52 lte,async,event lte1: ^MODE:3
06:18:52 lte,async,event lte1: +MSRI: 1
06:18:53 lte,async,event lte1: +MPBK: 0
06:18:53 lte,async,event lte1: *SIMDETEC:2,NOS
06:18:53 lte,async,event lte1: +MMSG: 0, 0
06:18:53 lte,async,raw lte1: +CGREG: 0
06:18:53 lte,async,raw lte1: +CEREG: 0
06:18:53 lte,info lte1: not registred, state: 0
06:18:53 lte,async,event lte1: +CPAS: 5
06:18:53 lte,async,event lte1: *SIMDETEC:1,SIM
06:18:54 lte,async,raw lte1: sent AT+CFUN?
06:18:54 lte,async,raw lte1: rcvd +CFUN: 4
06:18:54 lte,async,event lte1: *ICCID: 6768008
06:18:54 lte,async,event lte1: *EUICC: 1
06:18:54 lte,async,raw lte1: +CREG: 0
06:18:54 lte,async,raw lte1: $CREG: 0
06:18:54 lte,async,raw lte1: +CGREG: 0
06:18:54 lte,async,raw lte1: +CEREG: 0
06:18:54 lte,async,event lte1: *RADIOPOWER: 0
06:18:55 lte,async,event lte1: *ADMINDATA: 0, 0, 0
06:18:55 lte,async,event lte1: +CPIN: READY
06:18:55 lte,async,event lte1: *EUICC: 1
06:18:55 lte,async,event lte1: *ECCLIST: 5, 0, 112, 0, 000, 0, 08, 0, 118, 0, 911
06:18:55 lte,async,event lte1: +MMSG: 0, 0
06:18:58 lte,async,event lte1: +MMSG: 0, 1
06:18:58 lte,async,event lte1: +MPBK: 1
06:19:01 lte,async,event lte1: +MMSG: 1, 1
06:19:53 lte,error failed to register on network
06:19:53 lte,account lte1 session: 30947s 7495017348/396975471 bytes 5695852/2162343 packets
06:19:53 lte,async lte1: sent AT+CFUN=4
06:19:53 interface,info lte1 link down
06:19:53 lte,async lte1: rcvd OK
06:19:53 lte,async lte1: sent AT+EEMOPT=1
06:19:53 lte,async,event lte1: *RADIOPOWER: 0
06:19:53 lte,async lte1: sent AT*MRD_SN?
06:19:53 lte,async lte1: rcvd *MRD_SN:30DB6B7
06:19:53 lte,async lte1: sent AT+CPIN?
06:19:53 lte,async lte1: rcvd +CPIN: READY
06:19:54 lte,async,raw lte1: sent AT+CFUN?
06:19:54 lte,async,raw lte1: rcvd +CFUN: 4
06:19:57 lte,async lte1: sent AT+CPMS="SM","SM","SM"
06:19:57 lte,async,event lte1: +MMSG: 1, 1
06:19:57 lte,async lte1: rcvd +CPMS: 60,60,60,60,60,60
06:19:57 lte,async lte1: sent AT+CFUN?
06:19:57 lte,async lte1: rcvd +CFUN: 4
06:19:57 lte,async lte1: sent AT*ICCID?
06:19:57 lte,async lte1: rcvd *ICCID: 68008
06:19:57 lte,async lte1: sent AT+CNUM
06:19:57 lte,async lte1: sent AT+CIMI
06:19:57 lte,async lte1: rcvd 7861563
06:19:57 lte,async lte1: sent AT+CPIN?
06:19:57 lte,async lte1: rcvd +CPIN: READY
06:19:57 lte,async lte1: sent AT*BAND?
06:19:57 lte,async lte1: rcvd *BAND: 5, 78, 147, 0, 524289, 0, 2, 2, 0
06:19:57 lte,async lte1: sent AT*BAND=5,78,147,0,524289,0,2,0
06:19:57 lte,async lte1: rcvd OK
06:19:57 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
06:19:58 lte,async lte1: sent AT+ZGDCONT=5,"IP","apn1",0
06:19:58 lte,async lte1: rcvd OK
06:19:58 lte,async lte1: sent AT+ZGPCOAUTH=5,"","",0
06:19:58 lte,async lte1: sent AT+COPS=0
06:19:58 lte,async lte1: sent AT+COPS=3,0
06:19:58 lte,async lte1: sent AT+CFUN=1
06:19:58 lte,async,event lte1: +CPAS: 2
06:19:58 lte,async,event lte1: *RADIOPOWER: 1
06:19:58 lte,debug lte1: config ok
06:19:59 lte,async,raw lte1: +CEREG: 1,"a065","00060a05",7
06:19:59 lte,debug lte1: network access technology: Evolved 3G (LTE)
06:19:59 lte,info lte1: registered home
06:19:59 lte,async,raw lte1: +CGREG: 0
06:19:59 lte,async,event lte1: +CIREPI: 1
06:19:59 lte,async,event lte1: +CPAS: 0
06:19:59 lte,async,raw lte1: +CREG: 6,"a065","00060a05",7
06:19:59 lte,async,raw lte1: $CREG: 6,"a065","00060a05",7,"170"
06:19:59 lte,async,event lte1: +CEN1: 1, 419, 02
06:19:59 lte,async,event lte1: +CGEV: EPS PDN ACT 5
06:19:59 lte,async,event lte1: *COPN:0,Zain KW
06:19:59 lte,async,event lte1: *COPN:1,Zain KW
06:20:00 lte,async,event lte1: +ZNITZ: 2020,12,30,30,19,58,32,0
06:20:00 lte,async,event lte1: +NITZ: 0,+12,20/12/31,03:19:58
06:20:00 lte,async,raw lte1: +CREG: 6,"a065","00060a05",9
06:20:00 lte,async,raw lte1: $CREG: 6,"a065","00060a05",9,"170"
06:20:00 lte,async,raw lte1: +CEREG: 1,"a065","00060a05",9
06:20:01 lte,async,raw lte1: sent AT+CFUN?
06:20:01 lte,async,raw lte1: rcvd +CFUN: 1
06:20:01 lte,async,raw lte1: sent AT+COPS?
06:20:01 lte,async,raw lte1: rcvd +COPS: 0,0,"Zain KW",9
06:20:04 lte,async lte1: sent AT+ZGACT=1,5
06:20:04 lte,async lte1: rcvd OK
06:20:07 lte,async,event lte1: +ZCONSTAT: 1,5
06:20:07 lte,async,event lte1: +ZGIPDNS: 5,"IP","37.34.183.193","37.34.183.193","212.43.17.11","95.66.17.12","","","",""
06:20:07 interface,info lte1 link up
