zayidhs
Mikrotik Routerboard configuration behind Cisco 2900 router  [SOLVED]
Sun Jan 03, 2021 7:51 am
Hello everyone
Hope the festive season and new year ushers in beautiful things.
I'm sorry it's a bit of a long one and i had to mask some information.
With that said, I am in a conundrum and need help. Our network guy left and I've been tasked with getting the house in order.
I do have a bit of background in networking but that's well over a decade ago.
Key Details:
*About 2,000 workforce mostly conntected via omnidirectional & sectoral WLAN
*A Cisco 2900 router and a Mikrotik RouterBoard were purchased
*DIA via microwave
*Connection should be ISP Minilink IDU, to Cisco Router, to Mikrotik RouterBoard and to end-users via LAN & WLAN
*Mikrotik is basically needed for Hotspot & user bandwidth-controlled logins.
ISP given addresses:
IP 1xx.xx.x.162
NM 255.255.255.252
GW 1xx.xx.x.161
ISP given DNS:
xxx.xxx.xxx.1
xxx.xxx.xxx.2
Summarily, I configured the Cisco thus:
#GE0/0 - 1xx.xx.x.162 255.255.255.252
#GE0/1 - 192.168.xx.1 255.255.255.0
#DHCP pool 192.168.xx.0 255.255.255.0
#Default Route 1xx.xx.x.162
#dns-server xxx.xxx.xxx.1 xxx.xxx.xxx.2
#excluded 192.168.xx.1 192.168.xx.10
#GE0/0 nat outside
#GE0/1 nat inside (also source list & overloaded)
#ip route 0.0.0.0 0.0.0.0 1xx.xx.x.161
It's been a while since I did this but I believe it's ok (corrections will be appreciated if otherwise)
My challenge is Mikrotik.
I've gotten a refresher and i believe setting up hotspot, profiles and users won't be an issue rather IP addressing, DHCP and NAT as there may be a double/conflict with Cisco.
So, I configured the Mikrotik thus:
eth1: 192.168.xx.2
eth2: 192.168.1. 1/24
DHCP client: eth1
Routes:
Destination 0.0.0.0/0
Gateway 192.168.xx.1 i.e., IP of GE0/1
NAT:
Source 192.168.1.0/24
Destination 0.0.0.0/0, Action Masquerade
DHCP Server Using Dhcp setup:
Int 2
Address 192.168.1.0/24
Gateway 192.168.1.1(IP of Mikrotik)
Address to give out (192.168.1.2, 192.168.1.254)
DNS servers (192,168.1.1, xxx.xxx.xxx.1, xxx,xxx,xxx,2)
NAT:
port-forwarding using netmap on port 80.
END
That's it with Mikrotik and like i said, hotspot, profiles and users won't be an issue But I really need help on the others.
zayidhs
Re: Mikrotik Routerboard configuration behind Cisco 2900 router
Mon Jan 04, 2021 10:57 am
Really need this help please.
Thank you
SiB
Sat Jan 09, 2021 1:07 am
We write at Telegram and problem is solved.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
At vacation until 15.jan.2021
zayidhs
Sat Jan 09, 2021 8:01 am
Yes, thanks so much for your help.
Settings were in order but had to change my pool from a class 24 to class 16
Users browsing this forum: Bing [Bot], memelchenkov and 68 guests
