notilous
L2tp problem
Fri Jan 08, 2021 7:02 pm
I try to create an l2tp client. I configured the tunnel and it works but when I try to reach a devise on the other side I keep getting errors.
The connection works and also I manually added a route to the LAN subnet using VPN as gateway on the remote computer, telling it: "to reach 192.168.x.x you have to use VPN tunnel remote IP as gateway".
What could be the problem?
sleerf
Re: L2tp problem
Sun Jan 10, 2021 6:08 pm
It would help if you could be a little more specific about the errors you get, especially since you say that it works, but yet it apparently doesn't.
With that said, I had a lot of trouble with Win10's firewall and default VPN adapter configuration.
notilous
Re: L2tp problem
Sun Jan 10, 2021 7:32 pm
The l2tp interface is marked as running, but when I try to ping any lan devices I get a network unreachable from the other side of the tunnel. I try to ping directly via my router
notilous
Re: L2tp problem
Mon Jan 11, 2021 5:52 pm
The problem basically is that on the other side of the tunnel there is a firewall rule blocking everything that's not cumming from my local ip. Can I change the ip shown in the other side of the tunnel?
Users browsing this forum: No registered users and 95 guests
