XYZuser
CRS312-4C+8XG-RM Slow Speed / can’t change to SWOs
Mon Jan 11, 2021 10:07 pm
Hello Guys,
i hope someone can help me.
I have a CRS312-4C+8XG-RM Switch for 2 days and i had some Problems.
The Switch has the default Settings as Bridge but the Performance Is not very Good.
This Is the main Problem.
The Speeds Is like 5gigabit.
I have tried to set the mtu to 9000 (Jumbo Frames) on the Interfaces but this did not help.
The Switch is for the Connection of my nas to my Other 10 gbe devices
I have one cable direct attached with icsci to my Server and there i had 10 gb Full but the Connection from the Switch is under the half
I think it Is the Bridge function which makes it slow.
I read in a Other Thread i should change to the SWOS
Correct me if i‘m wrong.
The bridge Function makes to much overhead
to be so fast as the Switch.
So i Look How to change the Router to Switch os but i had not the opinion under System -> Routerboard > Settings
Then i try the command:
/system routerboard settings set boot-os=swos
The system recognize the Command but nothing happend
I Boots to the Router os like before.
the product Page says i can Use a Router os or a Switch os
On the end of this SWOS wiki are some serial commands
Should i buy a usb to serial cable to change the Router os to SWOS ?
https://wiki.mikrotik.com/wiki/SwOS/CRS3xx
Did anyone have a idea ?
zelthian
Re: CRS312-4C+8XG-RM Slow Speed / can’t change to SWOs
Thu Jan 14, 2021 5:44 pm
It's a bug in the software/firmware. Contact support.
MTCNA, MTCRE, MTCINE, MTCSE
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe." -Albert Einstein
XYZuser
Thu Jan 14, 2021 5:52 pm
ok Thank You.
I will try to reach the support.
I tried to reinstall several older versions of the router OS, but that didn't help.
I used the netinstall tool.
Maybe this tool has a bug too.
zelthian
Thu Jan 14, 2021 5:56 pm
No, it's the software/firmware. For some reason the released version doesn't recognize the dual-boot nature of the switch, apparently.
Support supplied me with updated beta software. After updating the software and firmware, the options appeared in Winbox and the CLI to change the boot OS, and I'm running my switch in SwOS now.
XYZuser
Thu Jan 14, 2021 6:07 pm
OK Thank you for your help
I will write the Mikrotik Support directly because my my local seller can't help me.
XYZuser
Thu Jan 14, 2021 6:11 pm
Did you call the technical or Hardware Support ?
zelthian
Thu Jan 14, 2021 6:21 pm
Submit a ticket online through your Mikortik account.
XYZuser
Thu Jan 14, 2021 7:30 pm
I made a Ticket
I hope they'll averring me because i bought the switch by a local dealer (Reichelt Elektronik Germany).
Thank you for your help.
In Case they refuse my Ticket.
Could you upload the file in a zip ?
That would be nice
zelthian
Thu Jan 14, 2021 7:49 pm
They won't refuse it. It doesn't matter where you bought the switch.
I will not upload the software. It isn't publicly available, and I believe they have the right to control how it gets distributed. It sets a bad precedent.
XYZuser
Thu Jan 14, 2021 8:10 pm
I Hope so.
i really like that Switch and the Switch OS can in increase my Network Speed instead of the bridge mode which is default configured.
It should be faster when he Acts as Layer 2 Device.
No Problem
I don't want you to have any legal problems because of that either.
zelthian
Thu Jan 14, 2021 8:13 pm
I've discovered something else after a little experimentation. It seems the specific issue is with the firmware. I left the firmware at the version provided by support but downgraded the software back to 6.47.8, and the "Boot OS" menu appears in the RouterBoard settings again.
XYZuser
Thu Jan 14, 2021 9:59 pm
Very Interesting.
I will do some Experiments when i get the Firmware too.
Are you happy with the Performance of the Switch with the swos.
I can't wait to test the speed with the Switch Os.
zelthian
Thu Jan 14, 2021 10:45 pm
As it turns out, though the Boot OS selection is available with current software and updated firmware, it doesn't function. Rats. You have to have the sw and firmware both at the beta version for it to function.
That said, I'm not really pushing this switch very hard, so I can't really comment on the speed. It's always performed well for me for what I use it for.
Users browsing this forum: Bing [Bot] and 58 guests
