Sun Jan 31, 2021 3:34 pm
Here is where you should start!!!!!!!
Default rules.........
established,related,untracked
invalid
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 (if not using capsman this rule can be removed)
disabled=yes in-interface-list=!LAN
Now you want to add own rules.
1. admin access to the router
2. users access to services if required (DNS,NTP)
3. drop all other traffic (and remove not all coming from LAN rule above as it will be covered by the drop rule),
Ex.
invalid
add action=accept chain=input comment="allow admin access" \
in-interface-list=LAN src-address-list=adminaccess
add action=accept chain=input comment="Allow LAN DNS queries - TCP" \
connection-state=new dst-port=53 in-interface-list=LAN protocol=tcp
add action=accept chain=input comment="Allow LAN DNS queries-UDP" \
connection-state=new dst-port=53 in-interface-list=LAN protocol=udp
{ ADD back your VPN rules here }
add action=drop chain=input comment="Drop All Else"
NOTES:
You do not need to detail the ports in the input chain for winbox access.
Also why would you want FTP (21) to have anything to do with external access to the router it is not a secure protocol, not winbox direct (only from within the LAN).
Add back in whatever you need for IPSEC (VPN).
But hold on!!
What is the purpose of this rule........ ????? What does it accomplish??? Are you allowing anyone trying to connect on a certain port access to the router???
add action=add-src-to-address-list address-list=Connection address-list-timeout=none-dynamic chain=input comment=OpenVPN dst-port=1194 protocol=tcp
This seems inherently wrong and dangerous. Typically VPN connection allows one to connect to an internal network and then and only then do you allow that connection access to the router (From behind the router) what you are doing may be a huge security risk.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
