MOZZCHOPS
Help please!
Tue Feb 02, 2021 11:40 pm
I've bought a LHG LTE6 and am having trouble getting anything to work.
I thought this might be easy.
I can't even do an update even though I'm doing what the instructions tell me to do! in Quick set it comes up with ERROR: could not resolve dns name
Can anyone give my some starting points please.
I've downloaded WinBox and I can't update in that either at the moment it's 6.45.9, but I guess I've other issues on why it won't connect to the internet.
Any help will be appreciated. Tia.
MOZZCHOPS
Re: Help please!
Wed Feb 03, 2021 12:45 pm
Can anyone offer advice please?
erlinden
Long time Member
Long time Member
Re: Help please!
Wed Feb 03, 2021 1:00 pm
Could not resolve DNS name...that means that there is a problem with DNS. Is the device connected to a network? Did it get a proper IP address? Does it have Internet access?
Welcome to MikroTik ;-)
Tip: Instead of a cry for help, please use a proper description as title (like: "Problem updating RB" or "Basic configuration question for the LHG LTE6").
First the problem, then the solution
MOZZCHOPS
Re: Help please!
Wed Feb 03, 2021 1:27 pm
Thanks for the reply, at least I know someone is out there.
I am in the Beginners basics as I know a little but definitely in the basic mode.
I have managed to netinstall the update so it is now running version 6.48
I have no internet but it does say I'm connected to my EE supplier. I have left the router with the 192.168.88.1 IP address.
How do I change the internet ip address? do you think that is the issue?
erlinden
Long time Member
Long time Member
Re: Help please!
Wed Feb 03, 2021 1:45 pm
Can you please first share your configuration (via terminal):
/export hide-sensitive file=anynameyoulike
MOZZCHOPS
Re: Help please!
Wed Feb 03, 2021 3:28 pm
I'm not sure if this is what you asked for? If its wrong please let me know what to put in terminal.
Thanks.
[admin@MikroTik] > /export
# jan/02/1970 00:30:10 by RouterOS 6.48
# software id = UGG9-MQGL
# model = RBLHGR
# serial number = D6B80DCF0EB5
/interface lte
set [ find ] name=lte1
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=ether1 name=defconf
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=ether1 network=192.168.88.0
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
anav
Re: Help please!
Wed Feb 03, 2021 5:17 pm
Looks pretty basic default ish, which is fine!
I dont see any dhcp client settings though,
Have a look at that part of the winbox menu IP DHCP CLIENT and see if you have established a public IP on your dhcp client AKA Status --> its BOUND!!
By double clicking on the client you can also see the status of the client (gateway, assigned IP etc).
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
MOZZCHOPS
Re: Help please!
Wed Feb 03, 2021 11:12 pm
I got some help from a facebook group.
"Everywhere" needed writing in the APN setting instead of Default or Internet.
Thanks for the replies.
Users browsing this forum: robertschutter and 68 guests
