Huluziandal
Networking Strucutre
Thu Feb 04, 2021 12:55 pm
Hello Mikrotik User :)
just got a Mikrotik hex and iam really impressed with the capabilities of this small thing.
But i cant seem to figure out how to configure this for my use.
What i want is the following:
Ethernet1/Wan is connected to my firewall
Ethernet 1-4 should work like a switch
Ethernet5 should be connected to my webserver which runs on a diffrent network i want to reach this one from port 4088.
I hope what i wrote is somewhat understandable.
Thanks for any advice.
anav
Re: Networking Strucutre
Fri Feb 05, 2021 3:57 am
Yes,
please post your config to see what is currently attempted.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Huluziandal
Fri Feb 05, 2021 10:22 am
Think the Portforwarding should work like this i can test it next week.
I disabled the ports which should act like a switch.
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.214.10-192.168.214.254
add name=dhcp_pool1 ranges=192.168.214.2-192.168.214.254
add address-pool=dhcp_pool1 disabled=no interface=ether5 name=dhcp1
add comment=defconf interface=ether2
add comment=defconf interface=ether3
add comment=defconf interface=ether4
add comment=defconf interface=ether5
add comment=defconf list=LAN
add address=192.168.214.1/24 comment=defconf interface=ether5 network=\
    192.168.214.0
add address=10.38.25.31/16 interface=ether1 network=10.38.0.0
/ip dhcp-client
add address=192.168.214.0/24 comment=defconf gateway=192.168.214.1 netmask=24
set allow-remote-requests=yes servers=10.38.4.2
/ip dns static
add address=192.168.214.1 comment=defconf name=router.lan
add action=accept chain=forward in-interface-list=WAN out-interface-list=LAN
    established,related,untracked
    invalid disabled=yes
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=10.38.25.31 dst-port=4880 log=yes \
    protocol=tcp to-addresses=192.168.214.160 to-ports=4880
add action=masquerade chain=srcnat dst-address=192.168.214.160 dst-port=4880 \
    out-interface=ether5 protocol=tcp src-address=10.38.0.0/24
add action=dst-nat chain=dstnat dst-address=10.38.25.31 dst-port=4899 \
    protocol=tcp to-addresses=192.168.214.160 to-ports=0-65535
add distance=1 gateway=10.38.10.1
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=all memory-scroll=no only-headers=yes
Thanks for your help.
chuckt
Sun Feb 07, 2021 10:35 pm
I'm no expert but, I thought disabling those ports would turn them off completely.
Also, you have set disable=yes to several important firewall rules.
mkx
Mon Feb 08, 2021 12:36 am
Firewall is cripled beyond any usable protection simply because of first (top-most) rule allowing just any connection from WAN towards LAN.
BR,
Metod
anav
Mon Feb 08, 2021 2:50 am
Not impressed that you made changes not knowing what you are doing.
Reset back to defaults on the firewall and ask from help from there.
Huluziandal
Mon Feb 08, 2021 8:20 am
Okay i restored the default settings.
thats not really a problem because the WAN port is conected to a lokal network.
The lokal network is already protected by a sophos firewall.
I only need the hex for portforwarding and access to the lokal network.
That was my intention because i could not get these port to work like a switch i thought it would be best to disable them.
mkx
Re: Networking Strucutre  [SOLVED]
Mon Feb 08, 2021 1:45 pm
Well, I missed the fact you're using the device inside LAN.
To achieve what you want it would best to configure device from scratch like this:
  • Download winbox to your management PC
  • connect management PC to router using one of ether2-ether5, run winbox and click MAC address of router to connect to it
  • reset router with no defaults and reconnect by clicking MAC address
  • create bridge and add ports ether1-ether4 to it
  • set IP on bridge interface ... either run DHCP client or set static IP address. In the later case add default route and set IP address of a DNS server (these settings are only necessary to perform ROS upgrades. If you intend to upgrade it by uploading package files from management PC you can skip setting route and DNS)
  • if you want router to sync time, configure (S)NTP client ... you might need default route and DNS settings if you're going to use some internet time server
  • set IP address on ether5 interface (select IP address from server's subnet)
  • add NAT rule:
    add action=dst-nat chain=dstnat dst-port=4088 in-interface=<bridge> to-addresses=<WEB server address>
  • if web server doesn't use this router as default gateway, you'll have to add another NAT rule:
    add action=src-nat chain=srcnat in-interface=<bridge> dst-address=<WEB server address> to-addresses=<address of router in server's subnet>
There are additional tasks to be done if you want to restrict management access to router or if you want to restrict connections between both subnets.
BR,
Metod
Huluziandal
Tue Feb 09, 2021 9:28 am
  • add NAT rule:
Thanks alot this works.
aesmith
Tue Feb 09, 2021 6:29 pm
Why NAT to the web server from Inside? You should be able to simply route to it.
Huluziandal
Wed Feb 10, 2021 9:08 am
That came to my mind also so for exercise iam trying this approach too.
I still neet to get used to Mikrotik.
I configured a static route on my Sophos to route all requests for 192.168.214.xxx/24 to the Mikrotik hex on 10.38.25.31/16.
A tracert from 10.38.x.x/16 to 192.168.214.x shows the redirection to the Mikrotik hex works.
I can ping everything from the Mikrotik subnet but can't ping the Computer from my Sophos network.
Do i need some kind of Masquarade on the Mikrotik?
mkx
Wed Feb 10, 2021 9:16 am
Check firewall on the Computer ... some OSes (Windows most notably) consider anything but it's own subnet to be evil internet and block pings originating from other networks.
BR,
Metod
Huluziandal
Wed Feb 10, 2021 9:29 am
I turned the Firewall on the Computer off completly still no response.
There are no acive FW rules only a Masquarade on th WAN port
mkx
Wed Feb 10, 2021 10:10 am
What is server's default gateway IP address? You can only route traffic from Sophos network via MT is either server or its default gateway know to use RB as gateway towards Sophos network.
BR,
Metod
Huluziandal
Wed Feb 10, 2021 10:24 am
I want to route from Sophos network to Mk network.
Mikrotik bridge IP: 10.38.25.31
MIkrotik bridge GW: 10.38.10.1/16
Mikrotik ethernet 5 DHCP server: 192.168.214.1
Server IP: 192.168.214.20
GW:192.168.214.1
Huluziandal
Wed Feb 10, 2021 12:10 pm
GW:192.168.214.1
I found this. https://wiki.mikrotik.com/wiki/Manual:S ... ic_Routing
this is basically what iam trying to do.
Router 1 is my Sophos Network.
Router 2 is MT Network.
I can ping Client LAN1 from Client1 Lan2
but can the other way around
mkx
Wed Feb 10, 2021 12:30 pm
In the linked page, note the "routing subnet" between router1 and router2 ... it is important and makes life of both routers easier. The thing is that in usual SOHO networks router1 runs a stateful firewall as well ... and this firewall can trip if it doesn't see traffic in both directions. Which happens if router2 "WAN" address is directly part of router1 "LAN" subnet.
The other thing is (potential) firewall running on router2 ... so please post actual running config of mikrotik again (run /export file=anynameyouwish and copy-paste contents of that file).
BR,
Metod
Huluziandal
Fri Feb 12, 2021 11:03 am
# jan/01/2002 02:28:45 by RouterOS 6.47.9
# software id = LVL6-6NB9
# model = RB750Gr3
# serial number = CC210CD3A5AF
add comment=192.168.214.x name=LAN2
add comment=10.38.x.x name=LAN1
/lora servers
add address=eu.mikrotik.thethings.industries down-port=1700 name=TTN-EU \
    up-port=1700
add address=us.mikrotik.thethings.industries down-port=1700 name=TTN-US \
    up-port=1700
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
/ip settings
set accept-redirects=yes accept-source-route=yes
add interface=ether1 list=LAN1
add interface=ether5 list=LAN2
add address=192.168.214.1/24 interface=ether5 network=192.168.214.0
add address=10.38.25.31 interface=ether1 network=10.38.25.31
add address=192.168.214.1/24 interface=ether2 network=192.168.214.0
set servers=10.38.4.2
add check-gateway=ping distance=1 dst-address=10.38.0.0/16 gateway=ether1
add distance=1 dst-address=10.38.10.1/32 gateway=ether1
/tool user-manager database
set db-path=flash/user-manager
Huluziandal
Fri Feb 12, 2021 2:01 pm
# model = RB750Gr3
/lora servers
    up-port=1700
    up-port=1700
set admin access=\
/ip settings
After this i created a masquarading srcnat rule on ether 1.
Now i can ping the 10.38.x.x network from the 192.168.214.x
but not the other way around
mkx
Fri Feb 12, 2021 7:56 pm
There are a few errors in your configuration:
# The following two lines should be removed
# Routes are both wrong
# Use this one instead ... not needed for connections between both subnets but it is needed for subnet 192.168.214.0/24 to be able to reach network beyond sophos LAN
add gateway=10.38.10.1
The last error (routing) was probably not a show stopper for your particular problem.
Regarding your last change (adding NAT): it may or may not be necessary, but that entirely depends on settings of sophos router/firewall:
  • If you can configure sophos to use MT as gateway towards subnet 192.168.214.0/24 and configure its firewall not to track connections between both subnets, then no NAT on MT is necesary (well, this depends also on firewalls on end devices, they might trip on connections from the other subnet).
  • If you can setup sophos with static route but you can't change firewall settings, then use of "routing subnet" between sophos and MT solves this problem, again no NAT needed.
  • if you can't change any settings on sophos, then you'll need to do both src-nat and dst-nat on MT. If this is the case and you don't know what particular kind of NAT rules are needed, come back with good description of requirements. Beware that using NAT comes with constraints and limitations so you should avoid this type of solution if possible
BR,
Metod
Huluziandal
Mon Feb 15, 2021 9:16 am
Thank you alot mkx.
After you said that the problem has to be on the sophos side i looked into it again and saw that there was a static route set to but no Firewall rule which allowd connection from 10.38.x.x to 192.168.214.x.
Users browsing this forum: itplus, Traveler382 and 58 guests
