lucasrmt
hEX Lite Failover Troubles
Thu Feb 04, 2021 4:00 pm
Hey everyone, iam new on this forum i wonder if i can get any help with this config iam doing atm.
Trying to make a 2 WANs DHCP and Failover between them. When i unplugg the cable from Ether1 or 2 its ok the failover works sweet, but when the link stay on and the ISP is down, netwatch tell me about Host 8.8.8.8 or 8.8.4.4 is down but dont switch to the other client.
Thx in advance and sorry for my english.
# feb/04/2021 10:37:19 by RouterOS 6.47.6
# software id = PVKU-6DLX
# model = RB750r2
# serial number = XXXXXXXXXX
set [ find default-name=ether1 ] name=ether1-WAN1
set [ find default-name=ether2 ] name=ether2-WAN2
set [ find default-name=ether3 ] name=ether3-LAN
set [ find default-name=ether4 ] disabled=yes name=ether4-LAN
set [ find default-name=ether5 ] disabled=yes
add name=WANs
add name=dhcp_pool0 ranges=192.168.128.100-192.168.128.230
add address-pool=dhcp_pool0 disabled=no interface=ether3-LAN name=dhcp1
add interface=ether1-WAN1 list=WANs
add interface=ether2-WAN2 list=WANs
add address=192.168.128.1/24 interface=ether3-LAN network=192.168.128.0
/ip dhcp-client
add comment=WAN1-FIBER !dhcp-options disabled=no interface=ether1-WAN1 \
script="{\r\
\n :local rmark \"WAN1\"\r\
\n :local count [/ip route print count-only where comment=\"WAN1-FIBER\
\"]\r\
\n :if (\$bound=1) do={\r\
\n :if (\$count = 0) do={\r\
\n /ip route add dst-address=8.8.8.8 gateway=\$\"gateway-addres\
s\" comment=\"WAN1-FIBER\"\r\
\n } else={\r\
\n :if (\$count = 1) do={\r\
\n :local test [/ip route find where comment=\"WAN1-FIBER\"\
]\r\
\n :if ([/ip route get \$test gateway] != \$\"gateway-addre\
ss\") do={\r\
\n /ip route set \$test gateway=\$\"gateway-address\"\r\
\n }\r\
\n } else={\r\
\n :error \"Multiple routes found\"\r\
\n }\r\
\n }\r\
\n } else={\r\
\n /ip route remove [find comment=\"WAN1-FIBER\"]\r\
\n }\r\
\n}" use-peer-dns=no use-peer-ntp=no
add comment=WAN2-WILTEL default-route-distance=2 !dhcp-options disabled=no \
interface=ether2-WAN2 script="{\r\
\n :local rmark \"WAN2\"\r\
\n :local count [/ip route print count-only where comment=\"WAN2-WILTEL\
\"]\r\
\n /ip route add dst-address=8.8.4.4 gateway=\$\"gateway-addres\
s\" comment=\"WAN2-WILTEL\"\r\
\n } else={\r\
\n :local test [/ip route find where comment=\"WAN2-WILTEL\
\"]\r\
ss\") do={\r\
\n }\r\
\n } else={\r\
\n }\r\
\n }\r\
\n } else={\r\
\n /ip route remove [find comment=\"WAN2-WILTEL\"]\r\
\n }\r\
add address=192.168.128.0/24 dns-server=8.8.8.8 gateway=192.168.128.1
set servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat out-interface-list=WANs
add comment=WAN2-WILTEL distance=1 dst-address=8.8.4.4/32 gateway=\
192.168.27.1
add comment=WAN1-FIBER distance=1 dst-address=8.8.8.8/32 gateway=192.168.1.1
/system clock
set time-zone-autodetect=no time-zone-name=America/Argentina/Buenos_Aires
/system clock manual
set time-zone=-03:00
/tool e-mail
set address=imap.gmail.com from=<RouterMikrotikRR> password=XXXXXX port=993 \
start-tls=yes user=xxxxxx@gmail.com
/tool netwatch
add comment=WAN1 down-script="log error \"WAN-1 fall\"\r\
\n/ip dhcp-cl set add-def=no [find comment=\"WAN1-FIBER\"] \r\
\n/tool e-mail send to=\"xxxxxxx@xxxxxxxx.com\" subject=\"El\
\_Link del IPS Ver FIBER\"\r\
\n" host=8.8.8.8 interval=30s up-script="log error \"WAN-1 Came back\"\r\
\n/ip dhcp-cl set add-def=yes [find comment=\"WAN1-FIBER\"] \r\
\n/tool e-mail send to=\"xxxxxxx@xxxxxxxx.com.com\" subject=\
\"El Link del ISP1 FIBER Came back\""
add comment=WAN2 down-script="log error \"WAN2 cayo\"\r\
\n/ip dhcp-cl set add-def=no [find comment=\"WAN2-WILTEL\"] \r\
\n/tool e-mail send to=\"xxxxxxx@xxxxxxxx.com.com\" subject=\"El\
\_Link de WILTEL fall\"" host=8.8.4.4 interval=30s up-script="log error \"\
WAN-2 fall\"\r\
\n/ip dhcp-cl set add-def=yes [find comment=\"WAN2-WILTEL\"] \r\
\n/tool e-mail send to=\"xxxxxxx@xxxxxxxx.com.com\" subject=\"E\
l Link de WILTEL Came back\""
Users browsing this forum: Joe1962, yegorovp and 46 guests
