hiphap91
Opening firewall ports
Fri Feb 05, 2021 12:49 pm
Hi there.
Pretty new to MikroTik, though I am very happy with my teeny tiny HAP2 router. I have a couple of questions, a specific one and a more general one.
First, how do I open (in a... *good* way) my ssh port, so I can ssh from a different network into my home network?
Second: How good are the default firewall settings, and should I do something to make it better?
Thank you for your time.
anav
Re: Opening firewall ports
Tue Feb 16, 2021 4:09 pm
What do you mean SSH from a different network into my home network.
Do you mean from an external location (not behind the same router)?
If so recommend using VPN not SSH.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
own3r1138
Wed Feb 17, 2021 4:14 pm
use custom port for SSH set a private key for access and use some Bruteforce rule in firewall you can also restrict the remote IPs.
https://wiki.mikrotik.com/wiki/Brutefor ... prevention
atifivacy
Thu Feb 18, 2021 6:28 am
What you're asking isn't quite clear. What are you referring to by 'open'? Do you mean that that port is listening to some server? Or do you mean the system firewall allows it? Or what?
k6ccc
Long time Member
Long time Member
Thu Feb 18, 2021 5:47 pm
And to answer part two of your original question, yes the default firewall rules are fairly good for most purposes. If you are replacing a consumer grade router with a Mikrotik, the default configuration will work just fine. When you want to allow other stuff (such as your SSH question) is where the Mikrotik will shine.
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Warning: I know enough to be dangerous...
Jim
Users browsing this forum: Bing [Bot], Google [Bot], yegorovp and 65 guests
