Mellivice
Confused how to do VLAN Firewall filters?
Tue Feb 09, 2021 1:45 pm
Hi all, I am new overall and I am trying to see what I am doing wrong here for using filters to block access between my VLANs.
Router Config
# model = RB760iGS
My interface config
/interface vlan
add interface=ether3 name=DMZ_VLAN vlan-id=100
add interface=ether2 name=LAN_VLAN vlan-id=10
My Firewall config
/ip firewall address-list
add address=192.168.10.0/24 list=LAN_ADDRESS_VLAN
add address=192.168.100.0/24 list=DMZ_ADDRESS_VLAN
add action=drop chain=input comment="Drop all packets from outside" in-interface=ether1
add action=accept chain=forward disabled=yes dst-address-list=DMZ_ADDRESS_VLAN src-address-list=LAN_ADDRESS_VLAN
add action=drop chain=forward disabled=yes dst-address-list=LAN_ADDRESS_VLAN log=yes src-address-list=DMZ_ADDRESS_VLAN
My goals are quite simple
  • I want full communication from my LAN_VLAN to DMZ_VLAN
  • I do not want my DMZ_VLAN to access my LAN_VLAN
I was thinking if I enabled those two rules it would work, but when I enable the drop rule all packets seem to drop from LAN to DMZ.
What am I doing wrong?
Mellivice
Re: Confused how to do VLAN Firewall filters?
Thu Feb 11, 2021 11:19 am
bump one more time.
Maybe I need to do my vlans differently?
erlinden
Long time Member
Long time Member
Thu Feb 11, 2021 11:58 am
Volgens mij volstaat het om de volgende regel aan te maken:
add action=drop chain=forward comment="Block guest network except WAN" in-interface=GUEST_VLAN out-interface-list=!WAN
Herewith my guest network is blocked from any other network (VLAN), WAN is allowed
First the problem, then the solution
Mellivice
Thu Feb 11, 2021 1:23 pm
Dit zorgt ervoor dat mijn gastennetwerk (op basis van de VLAN) alleen naar WAN mag.
Thanks I tried this as well with again it dropping all packets from LAN to the DMZ. I feel like I am doing something wrong but can't figure it out
tdw
Forum Veteran
Forum Veteran
Thu Feb 11, 2021 1:37 pm
To have a conversation between LAN and DMZ after the initial packet from LAN to DMZ there will be a reply packet from DMZ to LAN and your drop DMZ to LAN rule will drop these too, typically you have an allow established/related/untracked rule as the first item in the forward chain to permit the ongoing conversation.
Similarly the drop input rule without an allow input established/related/untracked rule will prevent the Mikrotik itself from communicating with the outside world - no DNS, no timesync, etc.
The default rules are a good starting point, then add/adjust as necessary.
Mellivice
Thu Feb 11, 2021 4:02 pm
Can you give me an example how that would look? Just trying to understand why this would need to be this explicit with rules.
tdw
Forum Veteran
Forum Veteran
Re: Confused how to do VLAN Firewall filters?  [SOLVED]
Thu Feb 11, 2021 5:07 pm
For input you should allow established/related/untracked connections, drop invalid connections, allow ICMP as blocking it breaks things such as PMTU detection, then have your drop from outside rule:
add action=accept chain=input comment="Allow input 'established', 'related' and 'untracked' connections" connection-state=established,related,untracked
add action=drop chain=input comment="Drop input 'invalid' connections" connection-state=invalid
add action=accept chain=input comment="Allow input ICMP" protocol=icmp
add action=drop chain=input comment="Drop input all from outside" in-interface=ether1
For forward you should again allow established/related/untracked connections and drop invalid connections, then allow what you wish to and drop everything else:
add action=accept chain=forward comment="Allow forward 'established', 'related' and 'untracked' connections" connection-state=established,related,untracked
add action=drop chain=forward comment="Drop forward 'invalid' connections" connection-state=invalid
add action=accept chain=forward comment="Allow forward all to outside" out-interface=ether1
add action=accept chain=forward comment="Allow forward LAN to DMZ" dst-address-list=DMZ_ADDRESS_VLAN src-address-list=LAN_ADDRESS_VLAN
add action=drop chain=forward comment="Drop forward all else"
Mellivice
Thu Feb 11, 2021 8:52 pm
Thank you very much that actually solved my issue.
I am going to spend some time looking at this.
anav
Fri Feb 12, 2021 4:53 pm
What I end up doing is modifying my input chain and forward chain with a last DROP all rule.
add action=drop chain=input or forward comment="drop all else"
What this does is basically drop any traffic that you, as an admin, have not explicitly allowed.
So in the input chain BEFORE you do this you need a
add action=accept chain=input source-address-list=AdminAccessList in-interface-list=LAN
Basically stating the IP addresses (your desktop, laptop, ipad etc) that are allowed access from the LAN to access the router.
Note this stops any wan to router traffic and stops any LAN to router traffic automatically.
So if your users on the LAN need any router services such as DNS or NTP, you will have to add this in
as ALLOW rules prior to the last drop all rule.
As for the forward chain.
You only need besides the defaults and the last new rule of drop all,
add LAN to WAN traffic for the most part as a rule.
The rest, is all blocked Vlan to Vlan traffic for example.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
Users browsing this forum: Bing [Bot], Cliff007, Google [Bot], HMHackMaster, mixig and 65 guests
