VLAN 20 is connected to my corporate network via OpenVPN tunnel and today I've noticed I couldn't connect to remote servers in corporate network.
This is part of my config relevant to the issue:
Code: Select all
add admin-mac=**:**:**:**:**:** auto-mac=no comment=defconf fast-forward=no name=bridge
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2
add bridge=bridge interface=wlan2_20
/interface vlan
add interface=bridge name=vlan20 vlan-id=20
add address=192.168.10.1/24 interface=bridge network=192.168.10.0
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add name=dhcp_pool10 ranges=192.168.10.100-192.168.10.254
add name=dhcp_pool20 ranges=192.168.20.100-192.168.20.254
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.20.0/24 gateway=192.168.20.1
add address-pool=dhcp_pool10 disabled=no interface=bridge name=dhcp10
add address-pool=dhcp_pool20 disabled=no interface=vlan20 name=dhcp20
set 1 vlan-mode=secure
set 2 vlan-mode=secure
set 3 default-vlan-id=20 vlan-mode=secure
set 4 vlan-mode=secure
set 5 vlan-mode=secure
add independent-learning=yes ports=switch1-cpu,ether2,ether3,ether5 switch=switch1 vlan-id=1
add independent-learning=yes ports=switch1-cpu,ether4 switch=switch1 vlan-id=20
/interface wireless
set [ find default-name=wlan2 ] wireless-protocol=802.11 (...)
add disabled=no master-interface=wlan2 name=wlan2_20 vlan-id=20 vlan-mode=use-tag (...)
Up until recently everything worked fine, I'm not sure when the issue began it might be something with v6.48.1 firmware because I think it worked before the upgrade.
Could you tell if my config above is good?
