https://wiki.mikrotik.com/wiki/Manual:I ... e/Wireless
The ap access-list is used one of two ways, depending on the "default-authentication" setting in "/interface wireless".
(1) Access List is a DENY List
If default-authentication=yes, then you can block connections from certain mac addresses by using "authentication=no" in the access-list.
(2) Access List is an Allow List
If default-authentication=no, you can allow connections from certain mac addresses by using "authentication=yes" in the access-list.
The station connect-list will allow that station to connect only to the aps listed there.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
