BoogieNites
Carrier Aggregation
Fri Feb 12, 2021 5:29 pm
Hi everyone,
All new to me but slowly getting there. I need some help if you can? I can get internet on both Bands 3 & 20. When I select both bands it chooses Band 3 as primary but nothing in CA. I find this connection to be unstable but can get reasonable speeds when it is working well. The SINR appears to fluctuate quite a lot & I think this affecting the overall result. When I select Band 20 only my result is a lot more stable although at a considerably lower speed. So, my question, should I be able to get CA? Is there anyway I can use the command line to get it to work? I have attached the details of both the band 3 & 20 in the hope that someone can help. Also, from what i've attached am I getting signal from different towers??
Many Thanks
P
Users browsing this forum: erlinden, Google [Bot], mommish, rodpp, yegorovp and 67 guests
