RajaMani
WAN & LAN Speed Difference
Tue Feb 16, 2021 9:56 pm
Hello
My WAN bandwidth is showing 10-15 mbps more than LAN interface bandwidth in my Mikrotik. I already have drop rule of dns from WAN port. But the problem is still. Difference between LAN and WAN port is more than 10 mbps. Anyone can help me to solve this issue.
Thank you
vecernik87
Forum Veteran
Forum Veteran
Re: WAN & LAN Speed Difference
Wed Feb 17, 2021 3:11 am
I would start with Tools->Torch:
If that is not sufficient, you may also go to IP->Firewall->Connections:
that should give you enough overview about your WAN connections. From there on, hard to say what you need to do - depends what kind of connections you find
RajaMani
Thu Feb 18, 2021 7:20 pm
I checked in details but i did not found anything
both things screenshot is attached you can also check. when i disabled lan all traffic is gone to normal and wan does not use any traffic but if i start olt (lan) traffic its goes up and difference is gone up.
RajaMani
Sat Feb 20, 2021 6:50 pm
Any one?
ingdaka
Sat Feb 20, 2021 6:58 pm
Do you have Queue for you "LAN" users?
Ilir Daka
Electronic & Network Engineer
E-mail: ilirdaka@live.com
Mob: +355692982151
WhatsApp: +355692982151
Mikrotik Official Consultant
CCNA | Fortinet NSE3 | MTCRE | MTCSE | MTCWE | RIPE NCC Certified Professional
RajaMani
Mon Feb 22, 2021 10:24 pm
Yes and for pppoe its created automatically.
RajaMani
Sat Feb 27, 2021 7:01 pm
Still problem is there. i changed the ip as well but wan and lan difference is still there.
Users browsing this forum: Baidu [Spider], etegan, xman and 63 guests
