malas
EOIP over IPSEC tunnel connection is unstable
Wed Feb 17, 2021 3:40 am
Hi, everyone.
I'm trying to site-to-site VPN with EOIP over IPSEC tunnel between a CCR2004 and a CCR1009.
Just after reboot both CCR devices, a EOIP over IPSEC tunneling connection works fine.
But, after repeat enable and disable few times the EOIP interface, tunneling doesn't work anymore.
It report "<ip> parsing packet failed, possible cause: wrong password" and
"phase1 negotiation failed due to time up <ip> blahblah".
When I remove the ipsec-secret attribute on the EOIP interface, it work's very well.
The GRE over IPSEC tunneling has same problem.
It seems that a ipsec negotiation is unstable.
I ask for help.
[admin@site2] > /interface eoip print
 0  R ;;; EOIP Tunnel Interface between HO and BO
      name="eoip-tunnel1-to-site1" mtu=auto actual-mtu=1458 l2mtu=65535
      mac-address=<mac> arp=enabled arp-timeout=auto
      loop-protect=default loop-protect-status=off
      loop-protect-send-interval=5s loop-protect-disable-time=5m
      local-address=<site2 static public ip> remote-address=<site1 static public ip> tunnel-id=100
      keepalive=10s,10 dscp=inherit clamp-tcp-mss=yes dont-fragment=no
      ipsec-secret="<secret pwd>" allow-fast-path=no
[admin@site2] > /ip ipsec proposal print
Flags: X - disabled, * - default
 0  * name="default" auth-algorithms=sha1
      enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m
      pfs-group=modp1024
[admin@site2] > /ip ipsec profile print
Flags: * - default
 0 * name="default" hash-algorithm=sha1 enc-algorithm=aes-128
     dh-group=modp2048,modp1024 lifetime=1d proposal-check=obey
     nat-traversal=yes dpd-interval=2m dpd-maximum-failures=5
[admin@site1] > /interface eoip print
 0    ;;; EOIP Tunnel Interface between HO and BO
      name="eoip-tunnel1-to-site2" mtu=auto actual-mtu=1458 l2mtu=65535
      local-address=<site1 static public ip> remote-address=<site2 static public ip> tunnel-id=100
[admin@site1] > /ip ipsec proposal print
      pfs-group=modp1024
[admin@site1] > /ip ipsec profile print
Flags: * - default
malas
Re: EOIP over IPSEC tunnel connection is unstable
Thu Feb 18, 2021 10:46 am
this is site1's ipsec debug log.
17:39:55 ipsec,debug ===== received 76 bytes from <site2 ip addr>[500] to <site1 ipaddr>[500]
17:39:55 ipsec,debug,packet 18fb156d 760d9cf9 6abfae28 89b48f9d 05100201 00000000 0000004c 557b31d3
17:39:55 ipsec,debug,packet ace10aa2 9023620d 46558029 c21b6bd5 b9e5c8a5 3d75da9b 3a9c08b1 cfbbaf8d
17:39:55 ipsec,debug,packet d059824d 1007300a 7d03da8d
17:39:55 ipsec,debug,packet encryption(aes)
17:39:55 ipsec,debug,packet IV was saved for next processing:
17:39:55 ipsec,debug,packet cfbbaf8d d059824d 1007300a 7d03da8d
17:39:55 ipsec,debug,packet with key:
17:39:55 ipsec,debug,packet 89c10f71 81f06938 366bbba8 d47965e9
17:39:55 ipsec,debug,packet decrypted payload by IV:
17:39:55 ipsec,debug,packet 3a516d71 385d2046 8e78cf4e f31ef1df
17:39:55 ipsec,debug,packet decrypted payload, but not trimed.
17:39:55 ipsec,debug,packet c6809192 2aa3fa16 46908c8c 015629b3 0b75a1c8 6dab5c84 729a76a7 e25d643a
17:39:55 ipsec,debug,packet 0ab77184 5e0e73f4 3fc7a2ac deb45f09
17:39:55 ipsec,debug,packet padding len=10
17:39:55 ipsec,debug,packet skip to trim padding.
17:39:55 ipsec,debug,packet decrypted.
17:39:55 ipsec,debug,packet 18fb156d 760d9cf9 6abfae28 89b48f9d 05100201 00000000 0000004c c6809192
17:39:55 ipsec,debug,packet 2aa3fa16 46908c8c 015629b3 0b75a1c8 6dab5c84 729a76a7 e25d643a 0ab77184
17:39:55 ipsec,debug,packet 5e0e73f4 3fc7a2ac deb45f09
17:39:55 ipsec,debug begin.
17:39:55 ipsec,debug seen nptype=5(id) len=37266
17:39:55 ipsec invalid length of payload
17:39:55 ipsec,error <site1 ip addr>parsing packet failed, possible cause: wrong password
17:40:05 ipsec,debug 236 bytes from <site2 ip addr>[500] to <site1 ip addr>[500]
17:40:05 ipsec,debug 1 times of 236 bytes message will be sent to <site1 ip addr>[500]
17:40:05 ipsec,debug,packet 18fb156d 760d9cf9 6abfae28 89b48f9d 04100200 00000000 000000ec 0a000084
17:40:05 ipsec,debug,packet fd56343f c7531f4b 5972c0c6 4ba28e41 3cf3f904 3e5e32f7 c13f363c f432651f
17:40:05 ipsec,debug,packet 49b44295 94ae1ea2 f160a8ab f1a1baf4 720ec81a 96e62e9b a09bc529 cb410577
17:40:05 ipsec,debug,packet f7d9ce4a a412f3a4 558650a0 07af7716 e2e913ba 7d2d3824 1d530ffa 050563e8
17:40:05 ipsec,debug,packet fb5c1ab1 b9a2d62e 1df10416 16f053d2 cf1bfc2f 3db65f1a 30582c71 ac653ca0
17:40:05 ipsec,debug,packet 1400001c 9a52dd1f 2f6f3c09 ae96d4ab 3d94d9c3 3928a29e 958120c2 14000018
17:40:05 ipsec,debug,packet 3cbda84e 85de0a7d 97f3cba3 5a7bc09c 3ecaedb1 00000018 e99e5e5c e9bdba64
17:40:05 ipsec,debug,packet 8ef45600 43c0f3ef 75caa07a
17:40:05 ipsec resent phase1 packet <site1 ip addr>[500]<=><site2 ip addr>[500] 18fb156d760d9cf9:6abfae2889b48f9d
17:40:05 ipsec,debug ===== received 76 bytes from <site2 ip addr>[500] to <site1 ip addr>[500]
17:40:05 ipsec,debug,packet 18fb156d 760d9cf9 6abfae28 89b48f9d 05100201 00000000 0000004c 557b31d3
17:40:05 ipsec,debug,packet ace10aa2 9023620d 46558029 c21b6bd5 b9e5c8a5 3d75da9b 3a9c08b1 cfbbaf8d
17:40:05 ipsec,debug,packet d059824d 1007300a 7d03da8d
17:40:05 ipsec,debug,packet encryption(aes)
17:40:05 ipsec,debug,packet IV was saved for next processing:
17:40:05 ipsec,debug,packet cfbbaf8d d059824d 1007300a 7d03da8d
17:40:05 ipsec,debug,packet with key:
17:40:05 ipsec,debug,packet 89c10f71 81f06938 366bbba8 d47965e9
17:40:05 ipsec,debug,packet decrypted payload by IV:
17:40:05 ipsec,debug,packet 3a516d71 385d2046 8e78cf4e f31ef1df
17:40:05 ipsec,debug,packet decrypted payload, but not trimed.
17:40:05 ipsec,debug,packet c6809192 2aa3fa16 46908c8c 015629b3 0b75a1c8 6dab5c84 729a76a7 e25d643a
17:40:05 ipsec,debug,packet 0ab77184 5e0e73f4 3fc7a2ac deb45f09
17:40:05 ipsec,debug,packet padding len=10
17:40:05 ipsec,debug,packet skip to trim padding.
17:40:05 ipsec,debug,packet decrypted.
17:40:05 ipsec,debug,packet 18fb156d 760d9cf9 6abfae28 89b48f9d 05100201 00000000 0000004c c6809192
17:40:05 ipsec,debug,packet 2aa3fa16 46908c8c 015629b3 0b75a1c8 6dab5c84 729a76a7 e25d643a 0ab77184
17:40:05 ipsec,debug,packet 5e0e73f4 3fc7a2ac deb45f09
17:40:05 ipsec,debug begin.
17:40:05 ipsec,debug seen nptype=5(id) len=37266
17:40:05 ipsec invalid length of payload
17:40:05 ipsec,error <site2 ip addr> parsing packet failed, possible cause: wrong password
erkexzcx
Tue Feb 23, 2021 10:18 am
Did you check this? viewtopic.php?f=23&t=169538 I've got it working perfectly fine.
Users browsing this forum: erkexzcx and 64 guests
