MaaS10
DELETE THIS TICKET
Mon Feb 22, 2021 7:01 am
DELETE THIS TICKET
DELETE THIS TICKET
satman1w
Re: see device on separate network
Mon Feb 22, 2021 8:24 am
1. connect server to ether1, set IP address to 192.168.39.254, set def.gateway on your server accordingly
2. connect pc to ether2, set IP address 192.168.41.254, set def gateway on your pc accordingly
try ping to each other....
that's it
MaaS10
Mon Feb 22, 2021 8:40 am
These networks must be isolated and I can't change device IPs.
satman1w
Mon Feb 22, 2021 8:53 am
how exactly is the "network isolated by mikrotik"??
MaaS10
Mon Feb 22, 2021 8:59 am
DELETE THIS TICKET
DELETE THIS TICKET
DELETE THIS TICKET
anav
Mon Feb 22, 2021 1:22 pm
What you have to do is ask the Hospital IT staff to make the necessary changes. If it is required to get work done, it will be addressed.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
MaaS10
Mon Feb 22, 2021 1:23 pm
DELETE THIS TICKET
DELETE THIS TICKET
DELETE THIS TICKET
mkx
Mon Feb 22, 2021 5:33 pm
There's one major trouble: hospital network (192.168.0.0/16) "contains" pharmacy's network (192.168.41.0/24). If those are really network addresses in use, you'll have to perform NAT on mikrotik and for that you need to know details about communication between server and PC.
The other problem is probably (you didn't describe high-level network setup) the following: each of networks (hospital and pharmacy) has its own router/gateway. As there's a direct path between the networks (your Mikrotik), main routers should be configured to use it. If this is not possible/desirable, then particular hosts (server in hospital and client in pharmacy) could be configured explicitly to use it. But that would only work if the first paragraph is non-issue.
The third possibility is that both networks actually use same router as gateway, in that case that router has be configured to allow that particular communication.
BR,
Metod
MaaS10
Mon Feb 22, 2021 6:35 pm
Actually yes, both networks use IP 192.168.0.1 as gateway.
anav
Mon Feb 22, 2021 6:57 pm
Sorry I must have been confused by this statement
"I'm asking for your advice as beginner."
If you are a beginner on MT equipment WTF are you doing trying to configure Hospital IT??
Get a consultant STAT, or you will bleed all over your current and future employment prospects.
Is this like a hospital for pets, in some backwater country using Windows ME computers and 33.6k modems???
mkx
Mon Feb 22, 2021 7:04 pm
Apart from suggestion by @anay (which is not out of place at all) ... so you have single Mikrotik router separating (at least) two LAN subnets and WAN? If you don't want to follow anav's advice, then you'll have to post current config of router or else nobody can give you any usable advice how to adapt config to allow wanted communication.
BR,
Metod
MaaS10
Mon Feb 22, 2021 7:12 pm
DELETE THIS TICKET
DELETE THIS TICKET
anav
Mon Feb 22, 2021 7:44 pm
Egads,,,,,,,,,, mkx, do you want to be named in a lawsuit, for giving a guy advice that leads to patients deaths, getting wrong medications and the list goes on.
Run while you can!
Seriously dude, configuration as in.
/export hide-sensitive file=anynameyouwish.
satman1w
Re: see device on separate network  [SOLVED]
Mon Feb 22, 2021 9:28 pm
I'm working in hospital, isolated part is public pharmacy. They are isolated so that they do not see the rest of the network.
:-) This is miles away from your initial question, and if you, as member oh hospitals IT staff, have to ask for forum advice, this is going completely the wrong way.
ASAP hire somebody who understands what "/16" means, who knows why your "isolated network" should not be a part of your "main" network, and so on.
This is a friendly advice...
Users browsing this forum: icttech, tdw, xman and 26 guests
