drjanson
hAP Lite: How to connect ethernet/LAN device to WLAN subnet?
Tue Feb 23, 2021 12:47 pm
Hi everybody!
Sorry, I'm completely new to networks and even struggle with the search, as I don't know what the name is for what I'm trying to do.
But I belive it must be quite a simple task, so maybe someone here is willing to help me.
Situation:
I'm running a hAP lite ass WLAN Access Point, have set up different WLAN subnets in the router OS, all working fine.
Now I want to connect an ethernet device (IKEA Tradfri Gateway) to the router.
The device must be in the same network as one of my WLANs so that the device can be "found" by the smartphone app that is connected to that WLAN.
How do I achieve that?
(And: is it called something like a "LAN/WLAN BRIDGE" ? Or whats the right term??)
Thanks a lot!
drjanson
Re: hAP Lite: How to connect ethernet/LAN device to WLAN subnet?
Sun Feb 28, 2021 6:53 pm
Really nobody out there who could help?
k6ccc
Sun Feb 28, 2021 8:46 pm
It will involve setting up a bridge, but I don't use any bridges in my routers, so I can't help you much. The Ethernet port and the WLAN need to be in a bridge, but that's about my limit on bridges.
anav
Sun Feb 28, 2021 10:35 pm
Yes create a bridge.
Put the wlan on the bridge and the physical port on the hap lite on the bridge.
How does the lan device supposed go get dhcp etc. (wehre does it get it now??)
You really need to draw a network diagram and post your config
drjanson
Mon Mar 01, 2021 10:02 pm
Thanks to both of you.
Especially for for the "hide-sensitive". I didnt know that.. :-)))
After knowing that it must be done with a Bridge, I was able to focus on what I did wrong when I tried to set up the bridge before.
So here is my solution:
1. Create the Bridge
2. Plug the two Ports (ethernet2 and WLAN) into that bridge
3. Set IP Adress(es) for the Network/Subnet
4. Create IP Pool for the Subnet
5. Run DHCP Server on the Bridge (which is the most important part I did wrong firts, so the "dumb" device did not get its IP correctly)
Here's my config, maybe helpfull for anybody else:
# mar/01/2021 20:19:52 by RouterOS 6.44.5
# software id = RUV1-KN06
# model = RB941-2nD
add name=HOME-BRIDGE
add authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    management-protection=allowed mode=dynamic-keys name=HOME \
    supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] default-authentication=no default-forwarding=\
    no disabled=no hide-ssid=yes mode=ap-bridge security-profile=\
    "MikroTik wlan1" ssid="MikroTik WLAN" wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=AC:AB:74:AB:28:28 \
    master-interface=wlan1 multicast-buffering=disabled name=HOME \
    security-profile=HOME ssid=home wds-cost-range=0 wds-default-cost=0 \
    wps-mode=disabled
add name="HOME Pool" ranges=192.168.80.2-192.168.80.254
add add-arp=yes address-pool="HOME Pool" disabled=no interface=HOME-BRIDGE \
    name=HOME
add bridge=HOME-BRIDGE interface=ether2
add bridge=HOME-BRIDGE interface=HOME
/interface wireless access-list
add interface=HOME vlan-mode=no-tag
/interface wireless connect-list
add interface=HOME security-profile=default
add address=XXX.XXX.XXX.100/24 comment="UPLINK to SWITCH" interface=ether1 \
    network=XXX.XXX.XXX.0
add address=192.168.80.1/24 interface=HOME-BRIDGE network=192.168.80.0
/ip dhcp-server config
set store-leases-disk=immediately
add address=192.168.80.0/24 comment="HOME (w)LAN" dns-server=192.168.80.1 \
    gateway=192.168.80.1 netmask=24
set allow-remote-requests=yes servers=XXX.XXX.XXX.1
add action=masquerade chain=srcnat comment="HOME wLAN TRAFFIC RAUS" \
    src-address=192.168.80.0/24
add comment="GATEWAY (wLan hAP > SWITCH)" distance=1 gateway=XXX.XXX.XXX.1
/ip service
/ip traffic-flow
set enabled=yes interfaces=*7
/system clock
Sorry for beeing paranoid about IPs and feel free to comment, if there's utter nonsense in there!
Users browsing this forum: No registered users and 105 guests
