niyaza93
VLAN on L2 switches and Communication between VLANs Via Mikrotik
Wed Mar 03, 2021 5:14 pm
Hello Dears,
in a project i have 3 (L2 switches Planet GS-4210-8P2S), I have configured VLANs on each as per the requirements.
Here we need some PCs in the project to have access to some other VLANs.
so how can I do this configuration inside Mikrotik RB951Ui-2HnD
VLAN information on Switches
I have:
VLAN101
VLAN102
VLAN1
SW1:
Port Mode Administrative VLANs
GE1 Access 101UP
GE2 Access 102UP
GE3 Access 1UP
GE4 Trunk 101T, 102T, 103T
GE5 Trunk 101T, 102T, 103T | Connected to Mikrotik Ether4 and set up the same VLANs on Mikrotik
GE6 Trunk 1UP, 101T, 102T, 103T
GE7 Trunk 1UP, 101T, 102T, 103T
GE8 Trunk 1UP, 101T, 102T, 103T
SW2
PortModeAdministrative VLANs
GE1 Access 101UP
GE2 Access 101UP
GE3 Access 102UP
GE4 Access 102UP
GE5 Access 1UP
GE6 Access 1UP
SW3
GE1 Access 101UP VLAN 101
GE2 Access 101UP VLAN 101
GE3 Access 102UP VLAN 102
GE4 Access 102UP VLAN 102
GE5 Access 1UP VLAN 1
GE6 Access 1UP VLAN 1
GE5 Trunk 101T, 102T, 103T | Connected to Mikrotik Ether4 and set up the same VLANs on Mikrotik.
What I need is if I connect a PC on SW3 port GE2 which is on VLAN 101 Untagged Port i would like to communicate with the devices on VLAN102 as well or any other wanted VLANs.
So how can I do this
I am using Winbox, and not familiar with coding.
Thanks For your Help
niyaza93
Re: VLAN on L2 switches and Communication between VLANs Via Mikrotik
Tue Mar 09, 2021 10:00 am
isn't there anyone to answer me?
erlinden
Tue Mar 09, 2021 10:04 am
This topic is a great tutorial on how to implement VLAN with MikroTik:
viewtopic.php?t=143620
niyaza93
Tue Mar 09, 2021 5:15 pm
Thanks, But i have already watched this topic, and I can't find what I need, I need someone who has experience in these cases to help me and tell me what to do and how to do it.
anav
Tue Mar 09, 2021 5:38 pm
Well, assuming its a school project, our job is not to do your homework for you.
Deciding the network structure is your job.
You have two choices, do DHCP serving on the switches OR the router.
You have two choices for Vlans on the router, vlan bridge method or switch chip method.
For vlans on switches you have two basic choices Port Vlans or 802.1q vlans.
Enjoy!!
When you have specific issues about the MT config, that demonstrates you have a network in mind and have tried to config it, then perhaps we an help.
Users browsing this forum: No registered users and 26 guests
