Knee
RBmAPL-2nD (mAP lite) initial config
Tue Mar 16, 2021 10:10 pm
Hi folks. I got myself RBmAPL-2nD (mAP lite) and followed the quick guide - while I see 'new' wifi and connect to it, I don't get IP so I can't connect to default 192.168.88.1.
Troubleshooting steps:
* I've registered new router with my provider (with new MAC)
* Once connected to eth0, per provider device is connected (there are packets flowing)
* WinBox, connected to new router and set config to a) automatic IP (per provider) - again, can't connect via wifi; b) static IP - same issue
* resetted config as per https://wiki.mikrotik.com/wiki/Manual:R ... m_RouterOS
* new and old ones are not running at the same time (as both have 192.168.88.1 default (also tried to change mAP to 192.168.89.1)
In the long term, I want to have my old router 951G-2HnD, use eth5 to connect mAP lite and on mAP create new wifi to cover area with weak 951G-2HnD. I'm pretty sure there's better way, but for now I'm stuck with 'quick' guide for few hours.
Any ideas are so much welcomed.
Users browsing this forum: 0xAA55 and 45 guests
