hebaky
how can i protect the customers and the router from "net cu
Thu Jul 26, 2007 4:23 pm
how can i protect the customers and the router-os from "net cut" ...
thanks
Viroslash
Re: how can i protect the customers and the router from "net cu
Fri Sep 28, 2007 7:07 pm
what is "net-cut"?? :shock:
hebaky
Sat Sep 29, 2007 4:50 pm
net cut is a program make control on the Lan and cut off the internet .. , there are several programs do that like :
switch sniffer - big boss , ....
ashish
Long time Member
Long time Member
Sat Sep 29, 2007 6:35 pm
There is a Program called Anti netcut. I think you need to install it.
//ASHISH
hebaky
Wed Oct 03, 2007 12:26 am
Mr. ashish
thank u very much , i know that , but i want to protect my server and my customers from the " net cut"
andreacoppini
Trainer
Trainer
Wed Oct 03, 2007 1:01 am
Mr. ashish
From what I could find on the net, NetCut is a form of ARP poisoning. You can protect your network using a combination of Static ARP, Routing instead of bridging design, putting your client-facing network interface set to "Reply-Only" or "disabled" and using DHCP to create ARP entries.
normis
Wed Oct 03, 2007 11:03 am
I think you need a better operating system on the PC and proper firewall on the router :)
Viroslash
Wed Oct 03, 2007 3:45 pm
Like Linux :lol:
madher
Fri Oct 05, 2007 11:42 am
Mr andreacoppini
kindly
can you explane further more with details
madher
andreacoppini
Trainer
Trainer
Fri Oct 05, 2007 9:07 pm
Mr andreacoppini
kindly
madher
I'll try...
basically, don't use bridging as much as you can. with bridging comes ARP poisoning, ARP DOS attacks and all sorts of attacks which can be stopped simply by changing your network design. Route, route, route.
Then, on your access point which has clients connecting to it, change the ARP setting to "Reply Only" (not "Enabled"). This way, the access point will ignore ARP messages from clients, it will only send a reply to clients when it is asked for its own IP address.
But your access point needs to be able to communicate with your legitimate clients, so -on the access point- you need to set the DHCP server to "add arp for leases".
Finally, in order to stop your clients from poisoning (netCut'ing) each other, you need to disable 'Default Forwarding' on the wireless interface, and disable the 'Forwarding' option on any wireless clients you have listed in your wireless Access List.
If most/all of the above is not making sense to you, you need to get yourself on a MikroTik training class... :D
ahmedsaffar76
Tue Apr 15, 2008 3:33 am
Hi ;
if the bridging doing problems why MikroTik not delete it from the OS ? , could you put further details about how to use the route process ?
it seems that you deeply recommend it .
sorry this will not stop netcut .
with best regards .
hulk-bd
Tue Apr 15, 2008 9:43 pm
ahmedsaffar76:
Hi ;
Dude please be sure what are you asking for. Delete bridge from MT OS!! How funny. :shock:
ahmedsaffar76
Tue Apr 15, 2008 10:23 pm
ahmedsaffar76:
Hi ;
Hi ;
what do you mean ???
i replied to a person say that the arp poisoning increase with the bridging .
with best regards .
andreacoppini
Trainer
Trainer
Wed Apr 16, 2008 2:18 am
with best regards .
he means that it is a bit like saying "cars should be removed from the road because they can be used by bad people to kill pedestrians"
Bridging is a very useful (indispensable?) feature in a product like RouterOS, but just like marriage, sex and money, it has its drawbacks. :D
andreacoppini
Trainer
Trainer
Wed Apr 16, 2008 2:21 am
lol, sorry, i forgot that $EX is a big issue with techies :)
ahmedsaffar76
Wed Apr 16, 2008 3:09 am
ahmedsaffar76 -
Well part of the problem right now is your bridge.
If you do the suggested items then there should be no interruption of service.
Q & A;
i think the DNS will make a problem , which DNS you are going to use ? for ISP1 or ISP2 ? You can use ANY dns server you want - as long as it works. You could use for speed - one DNS server from each provider.
will you make a static dns server and enable remote requests ? No static, but you can enable the remote requests. Later you'll set up a proxy DNS.
R/
this was a reply to me in another topic " Load balancing with conn mark cannot work "
you see , Galaxynet say " Well part of the problem right now is your bridge. "
most of the replies refer the problems to bridging , thus i said if all these problems come from the bridge why MikroTik not remove it ?
am i clear now ?
with best regards
pedja
Long time Member
Long time Member
Wed Apr 16, 2008 11:09 am
Bridging is good only for small networks and novice users. Option is available because it is sometimes needed.
In general, when you make decisions, You should know what are drawbacks of that decisions.
That works for bridging too. It has drawbacks, many of them, and it has some advantages, few of them. So, if you want to use advantages of bridging, be prepared to deal with drawbacks.
MT just provides an option, it is up to you if You would use it.
ahmedsaffar76
Wed Apr 16, 2008 3:13 pm
Hi ;
this is acceptable and practical reply not like who compairing MT with cars or whatever .
so we all need others expirments with bridging to know all what are the benefits and the drawbacks .
when we all know that maybe each one could help the other to pass over this problem by using another method .
the forume here for this purpose .
with best regards .
Users browsing this forum: kevinds and 96 guests
