Kruger99
VLAN Bridging - Multiple SSIDs/VLANS on Unifi AP
Mon Apr 12, 2021 9:51 pm
Hello everyone,
Can someone please help with the VLAN Bridging of the following setup?
Apologies if this is straight forward, I've spent the entire day reading about VLANS and Bridging, however I just don't understand it.
I have 1x RB2011 as my dialup router, 2x Unifi AP's, and 1x unmanaged switch.
My goal is to setup the APs to broadcast 3 different SSIDs, each on their own VLAN (10, 20 and 30).
The switch and all devices connected to it will be on VLAN10.
My current config is as follows:
ether2 goes to switch
ether 6,7 goes to ap's
add name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name="vlan10 - admin" vlan-id=10
add interface=bridge1 name="vlan20 - staff" vlan-id=20
add interface=bridge1 name="vlan30 - guest" vlan-id=30
add name=dhcp_pool0 ranges=192.168.10.50-192.168.10.254
add name=dhcp_pool1 ranges=192.168.20.2-192.168.20.254
add name=dhcp_pool2 ranges=192.168.30.2-192.168.30.254
add address-pool=dhcp_pool0 disabled=no interface="vlan10 - admin" name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface="vlan20 - staff" name=dhcp2
add address-pool=dhcp_pool2 disabled=no interface="vlan30 - guest" name=dhcp3
add bridge=bridge1 interface=ether2 multicast-router=disabled pvid=10
/interface bridge vlan
add bridge=bridge1 tagged=bridge1 vlan-ids=10
add address=192.168.10.1/24 comment="ADMIN DATA" interface="vlan10 - admin" \
    network=192.168.10.0
add address=192.168.11.1/24 comment="ADMIN VOIP" interface="vlan10 - admin" \
    network=192.168.11.0
add address=192.168.20.1/24 comment="STAFF WIFI" interface="vlan20 - staff" \
    network=192.168.20.0
add address=192.168.30.1/24 comment="GUEST WIFI" interface="vlan30 - guest" \
    network=192.168.30.0
/ip dhcp-client
add disabled=no interface=ether1
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.20.0/24 gateway=192.168.20.1
add address=192.168.30.0/24 gateway=192.168.30.1
Can someone please point me in the right direction?
Somewhere between the tagged and untagged interfaces I'm getting very confused and lost...
Kruger99
Re: VLAN Bridging - Multiple SSIDs/VLANS on Unifi AP
Tue Apr 13, 2021 10:14 am
I've managed to get the setup working now, however there is one red warning which concerns me - can anyone elaborate on what it means?
  • "port with pvid added to untagged group which might cause problems, consider adding a seperate VLAN entry"
Current config
/interface vlan
add name=dhcp_pool3 ranges=192.168.1.50-192.168.1.254
add name=dhcp_pool4 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool4 disabled=no interface=bridge1 name=dhcp4
add bridge=bridge1 interface=ether6 multicast-router=disabled
# port with pvid added to untagged group which might cause problems, consider adding a seperate VLAN entry
add bridge=bridge1 tagged=bridge1,ether6 vlan-ids=10,20,30
add address=192.168.1.1/24 comment=MGMNT interface=bridge1 network=192.168.1.0
/ip dhcp-client
set servers=8.8.8.8
anav
Tue Apr 13, 2021 2:34 pm
I would get rid of the management interface its not needed think of the vlan10 as your admin/management interface.
As for the error
From
TO
add bridge=bridge1 tagged=bridge1,ether6 vlan-ids=20,30
add bridge=bridge1 tagged=bridge1,ether6 untagged=ether2 vlan-ids=10
Kruger99
Tue Apr 13, 2021 7:10 pm
As for the error
From
TO
Hi Anav,
Thank you for your reply. Unfortunately with this setup I was unable to get my Controller to communicate with my APs. I've instead opted for the following config - it's not perfect, but it works. I'' add some firewall rules still to block traffic between the VLANs etc.
add name=bridge1
/interface vlan
add interface=bridge1 name="vlan30 - guests" vlan-id=30
add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=dhcp1
add address-pool=dhcp_pool2 disabled=no interface="vlan30 - guests" name=dhcp3
add address=192.168.10.1/24 comment="ADMIN / MGMNT" interface=bridge1 network=192.168.10.0
add address=192.168.20.1/24 comment=STAFF interface="vlan20 - staff" network=192.168.20.0
add address=192.168.30.1/24 comment=GUEST interface="vlan30 - guests" network=192.168.30.0
add address=192.168.11.1/24 comment=VOICE interface=bridge1 network=192.168.11.0
/ip dhcp-client
add address=192.168.10.0/24 dns-server=192.168.10.1,8.8.8.8 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=192.168.20.1,8.8.8.8 gateway=192.168.20.1
add address=192.168.30.0/24 dns-server=192.168.30.1,8.8.8.8 gateway=192.168.30.1
anav
Re: VLAN Bridging - Multiple SSIDs/VLANS on Unifi AP  [SOLVED]
Tue Apr 13, 2021 7:57 pm
Ah yes UNIFI is a weird beast.
They need it done differently from the rest of the worlds equipment. (hybrid port)
In this case this should work ,,,,,,,,,, Using vlan 10 as management..........
add bridge=bridge1 interface=ether2 multicast-router=disabled frame-types=only priority tagged and untagged frames allowed pvid=10
add bridge=bridge1 interface=ether6 multicast-router=disabled pvid=10
add bridge=bridge1 tagged=bridge1, untagged=ether2,ether6 vlan-ids=10
Kruger99
Sat Apr 17, 2021 1:44 pm
Epic! Thanks!
Users browsing this forum: davidvanrensburg and 69 guests
