gutekpl
Can't set slave wireless interfaces on wAP AC (works ok on cAP AC)
Tue Apr 27, 2021 11:05 am
Few words of HW setup - hAP AC^2 as mother device running CAPsMAN. Two cAP AC's running in CAP mode, all works perfectly.
Few words of configuration - master radios are used for home 2.4/5 networks, both of them have their slaves - 2.4ghz is for iot devices, 5ghz is for guests.
Bought wAP AC to garden and once I added slave networks configuration it immidiately drops all connected devices and can't get handshake anymore. I disable iot/guests configuration and both home2.4/5 are starting to work fine and gets connection from clients. I have different configuration profiles per each device (different channel) and I thought maybe I picked wrong/unsupported channel, but when I apply one of cAP configuration profiles into wAP it still doesn't work.
What may be wrong there? Does wAP AC radio/hw differs from cAP AC's and somehow that configuration is unsupported?
To be honest iot/guests networks are not something I need in garden, but I just wonder where the problem is.
gutekpl
Re: Can't set slave wireless interfaces on wAP AC (works ok on cAP AC)
Thu Apr 29, 2021 11:40 am
Noone?
anav
Thu Apr 29, 2021 1:29 pm
I would love to help but allergic to capsman. Get rid of that and I will be glad to take a look at the config.
In addition its a sexist functionality, should be capsperson!!
erlinden
Thu Apr 29, 2021 1:35 pm
Can you please share your config:
/caps-man export hide-sensitive
gutekpl
Fri Apr 30, 2021 1:11 pm
WIFI Frequencies may not match channel number specified in name, I was playing with them lately and didnt update names.
# apr/30/2021 12:11:23 by RouterOS 6.48.2
# software id = S87N-E2ZU
# model = RBD52G-5HacD2HnD
# serial number = B4A00AE5300B
/caps-man channel
add band=2ghz-b/g/n comment=hAP frequency=2412 name=channel1
add band=2ghz-b/g/n comment=cAP_2 frequency=2457 name=channel10
add band=5ghz-n/ac comment=hAP control-channel-width=20mhz frequency=5180 name=channel36 tx-power=40
add band=5ghz-n/ac comment=cAP_2 control-channel-width=20mhz extension-channel=eeCe frequency=5300 name=channel44 tx-power=40
add band=2ghz-b/g/n comment=cAP_1 frequency=2427 name=channel4
add band=5ghz-n/ac comment=cAP_1 control-channel-width=20mhz extension-channel=eCee frequency=5240 name=channel40 tx-power=40
add band=2ghz-b/g/n comment="wAP AC" extension-channel=eC frequency=2467 name=channel13 tx-power=40
add band=5ghz-n/ac comment="wAP AC" control-channel-width=20mhz extension-channel=Ceee frequency=5500 name=channel48 tx-power=40
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-key-update=1h name=security_home
add authentication-types=wpa2-psk encryption=aes-ccm group-key-update=1h name=security_iot
add authentication-types=wpa2-psk encryption=aes-ccm group-key-update=1h name=security_guest
/caps-man configuration
add datapath=dp_home mode=ap name=cfg_home_2g rx-chains=0,1,2,3 security=security_home ssid=Domek tx-chains=0,1,2,3
add country=poland datapath=dp_home mode=ap name=cfg_home_5g rx-chains=0,1,2,3 security=security_home ssid=Domek tx-chains=0,1,2,3
add datapath=dp_iot name=cfg_iot rx-chains=0,1,2,3 security=security_iot ssid=IoT tx-chains=0,1,2,3
add datapath=dp_guest mode=ap name=cfg_guest rx-chains=0,1,2,3 security=security_guest ssid=Goscie tx-chains=0,1,2,3
/caps-man datapath
add bridge=bridge_vlan100 client-to-client-forwarding=no name=dp_guest
add bridge=bridge client-to-client-forwarding=yes name=dp_home
add bridge=bridge_vlan10 client-to-client-forwarding=yes name=dp_iot
/caps-man interface
add configuration=cfg_guest disabled=no l2mtu=1600 mac-address=76:4D:28:12:A3:F9 master-interface="cAP AC 1_home5" name="cAP AC 1_guest" radio-mac=00:00:00:00:00:00 radio-name=764D2812A3F9
add channel=channel4 configuration=cfg_home_2g disabled=no l2mtu=1600 mac-address=74:4D:28:12:A3:F8 master-interface=none name="cAP AC 1_home2" radio-mac=74:4D:28:12:A3:F8 radio-name=744D2812A3F8
add channel=channel40 configuration=cfg_home_5g disabled=no l2mtu=1600 mac-address=74:4D:28:12:A3:F9 master-interface=none name="cAP AC 1_home5" radio-mac=74:4D:28:12:A3:F9 radio-name=744D2812A3F9
add configuration=cfg_iot disabled=no l2mtu=1600 mac-address=76:4D:28:12:A3:F8 master-interface="cAP AC 1_home2" name="cAP AC 1_iot" radio-mac=00:00:00:00:00:00 radio-name=764D2812A3F8
add configuration=cfg_guest disabled=no l2mtu=1600 mac-address=76:4D:28:46:AC:19 master-interface="cAP AC 2_home5" name="cAP AC 2_guest" radio-mac=00:00:00:00:00:00 radio-name=764D2846AC19
add channel=channel10 configuration=cfg_home_2g disabled=no l2mtu=1600 mac-address=74:4D:28:46:AC:18 master-interface=none name="cAP AC 2_home2" radio-mac=74:4D:28:46:AC:18 radio-name=744D2846AC18
add channel=channel44 configuration=cfg_home_5g disabled=no l2mtu=1600 mac-address=74:4D:28:46:AC:19 master-interface=none name="cAP AC 2_home5" radio-mac=74:4D:28:46:AC:19 radio-name=744D2846AC19
add configuration=cfg_iot disabled=no l2mtu=1600 mac-address=76:4D:28:46:AC:18 master-interface="cAP AC 2_home2" name="cAP AC 2_iot" radio-mac=00:00:00:00:00:00 radio-name=764D2846AC18
add configuration=cfg_guest disabled=no l2mtu=1600 mac-address=76:4D:28:1E:2C:C0 master-interface="hAP AC_home5" name="hAP AC_guest" radio-mac=00:00:00:00:00:00 radio-name=764D281E2CC0
add channel=channel1 configuration=cfg_home_2g disabled=no l2mtu=1600 mac-address=74:4D:28:1E:2C:BF master-interface=none name="hAP AC_home2" radio-mac=74:4D:28:1E:2C:BF radio-name=744D281E2CBF
add channel=channel36 configuration=cfg_home_5g disabled=no l2mtu=1600 mac-address=74:4D:28:1E:2C:C0 master-interface=none name="hAP AC_home5" radio-mac=74:4D:28:1E:2C:C0 radio-name=744D281E2CC0
add configuration=cfg_iot disabled=no l2mtu=1600 mac-address=76:4D:28:1E:2C:BF master-interface="hAP AC_home2" name="hAP AC_iot" radio-mac=00:00:00:00:00:00 radio-name=764D281E2CBF
add configuration=cfg_guest disabled=yes l2mtu=1600 mac-address=48:8F:5A:DE:2E:8B master-interface="wAP AC_home5" name="wAP AC_guest" radio-mac=00:00:00:00:00:00 radio-name=488F5ADE2E8B
add channel=channel13 configuration=cfg_home_2g configuration.country=poland disabled=no l2mtu=1600 mac-address=48:8F:5A:DE:2E:8A master-interface=none name="wAP AC_home2" radio-mac=48:8F:5A:DE:2E:8A radio-name=488F5ADE2E8A
add channel=channel48 configuration=cfg_home_5g configuration.country=poland configuration.installation=outdoor disabled=no l2mtu=1600 mac-address=48:8F:5A:DE:2E:8B master-interface=none name="wAP AC_home5" radio-mac=48:8F:5A:DE:2E:8B radio-name=\
    488F5ADE2E8B
add configuration=cfg_iot disabled=yes l2mtu=1600 mac-address=48:8F:5A:DE:2E:8A master-interface="wAP AC_home2" name="wAP AC_iot" radio-mac=00:00:00:00:00:00 radio-name=488F5ADE2E8A
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge_vlan10
add disabled=no interface=bridge_vlan100
/caps-man provisioning
add action=create-dynamic-enabled comment="cAP 1_2.4" master-configuration=cfg_home_2g name-format=identity radio-mac=74:4D:28:12:A3:F8 slave-configurations=cfg_iot
add action=create-dynamic-enabled comment="cAP 1_5" master-configuration=cfg_home_5g name-format=identity radio-mac=74:4D:28:12:A3:F9 slave-configurations=cfg_guest
add action=create-dynamic-enabled comment="hAP 2.4" master-configuration=cfg_home_2g name-format=identity radio-mac=74:4D:28:1E:2C:BF slave-configurations=cfg_iot
add action=create-dynamic-enabled comment="hAP 5" master-configuration=cfg_home_5g name-format=identity radio-mac=74:4D:28:1E:2C:C0 slave-configurations=cfg_guest
add action=create-dynamic-enabled comment="cAP 2_2.4" master-configuration=cfg_home_2g name-format=identity radio-mac=74:4D:28:46:AC:18 slave-configurations=cfg_iot
add action=create-dynamic-enabled comment="cAP 2_5" master-configuration=cfg_home_5g name-format=identity radio-mac=74:4D:28:46:AC:19 slave-configurations=cfg_guest
add action=create-dynamic-enabled comment="wAP AC_2.4" master-configuration=cfg_home_2g name-format=identity radio-mac=48:8F:5A:DE:2E:8A slave-configurations=cfg_iot
add action=create-dynamic-enabled comment="wAP AC_5" master-configuration=cfg_home_5g name-format=identity radio-mac=48:8F:5A:DE:2E:8B slave-configurations=cfg_guest
gutekpl
Wed May 05, 2021 2:30 pm
Anything that may indicate the problem?
erlinden
Wed May 05, 2021 3:05 pm
At least this is a bit worrying:
tx-power=40
Gladly the radios are limited in transmission power, either set them to auto (for testing purposes) or 20 at most.
My best guess would be the configuration part...it looks a bit messy
gutekpl
Wed May 05, 2021 8:35 pm
This was some leftover from testing, I have this field back on default.
Configuration is messy I know, because there are 4 devices with 4 presets which gives 16 different configs. However as I wrote, when I switch config from working cAP to wAP it still doesn't work, so that bring us to my original question if cAP and wAP HW is simmilar or same. Maybe wAP have greater power. but doesn't like slave wireless interfaces in exchange?
Users browsing this forum: No registered users and 107 guests
