musialny
Differences between RB with multiple switch chips
Mon May 10, 2021 10:26 pm
What is difference in configuration on these CRSes? Can I do switching and VLAN Filtering in the same way I'm doing on CRS with single switch chip (can I ignore fact, that some ports is on different switch chip than others)?
tdw
Re: Differences between CRS with multiple switch chips
Mon May 10, 2021 10:42 pm
I'm not aware of any CRS products which have multiple switch chips. There are other devices (RB1100/RB2011/RB3011/RB4011) which do - none of these support hardware offload with VLAN-aware bridges, and there are other limitations https://wiki.mikrotik.com/wiki/Manual:L ... itch_chips
musialny
Mon May 10, 2021 10:45 pm
You right, my mistake, that's not CRSes (I corrected the title).
When I writing about VLAN Filtering, I meant filtering in Switch Chip, not Bridge VLAN Filtering
mkx
Re: Differences between RB with multiple switch chips  [SOLVED]
Mon May 10, 2021 11:13 pm
Switch chip vlan filtering is obviously limited to single chip. Inter-chip communication passes CPU where one can use bridge (in it's non-vlan configuration) to merge multiple ports. However, making configuration on both switch chips consistent is router admin's responsibility, ROS doesn't enforce it in any (ever so slight) way.
Users browsing this forum: Kanzler, unhuzpt and 101 guests
