millido
vlan'ing home lab network
Wed May 12, 2021 1:26 pm
I have recently gotten a hEX S (RB760iGS) that I want to use to segment my network into vlans. I have not finished all the vlans and stuff in the router config, but I cannot get this configuration to work either...
My problem right now is that I cannot get the DHCP on access ports to work (I don't have the switch and server here now, as I am studying elsewhere). But I have tried testing it in eve-ng with CHR, and it seems to work there with the same config. So I don't really understand what I am doing wrong here. I am guessing that my config will do a better job at explaining than me ':-P
If anyone does have any tips or ideas on how to make this work, it would be very much appreciated!
Thanks in advance!
This is how I have planned the network (probably not optimal, so suggestions are welcome :)), all vm's either have its own dedicated NIC, or have vlan aware virtual nics.
The current config on the router:
# jan/02/1970 03:52:42 by RouterOS 6.47.7
# software id = 6JIK-BB6Q
# model = RB760iGS
# serial number = D4500D910DB4
add admin-mac=08:55:31:85:A2:2E auto-mac=no comment=defconf name=bridge
add fast-forward=no name=vlan-bridge pvid=30 vlan-filtering=yes
/interface vlan
add comment=Management interface=vlan-bridge name=VLAN10 vlan-id=10
add comment=Management/BMC interface=vlan-bridge name=VLAN11 vlan-id=11
add comment="Remote Access" interface=vlan-bridge name=VLAN20 vlan-id=20
add comment=Devices interface=vlan-bridge name=VLAN30 vlan-id=30
add comment=Storage interface=vlan-bridge name=VLAN100 vlan-id=100
add comment=Auth interface=vlan-bridge name=VLAN110 vlan-id=110
add comment=DMZ interface=vlan-bridge name=VLAN120 vlan-id=120
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=VLAN30-POOL ranges=10.11.30.50-10.11.30.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=VLAN30-POOL disabled=no interface=VLAN30 name=VLAN30-DHCP
add bridge=vlan-bridge comment=defconf interface=ether4 pvid=30 tag-stacking=yes
add bridge=bridge comment=defconf interface=sfp1
add bridge=vlan-bridge comment=defconf hw=no interface=ether3 pvid=30 tag-stacking=yes
/interface bridge settings
set allow-fast-path=no
/interface bridge vlan
add bridge=vlan-bridge tagged=vlan-bridge untagged=ether3,ether4 vlan-ids=30
add interface=vlan-bridge list=LAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.11.30.1/24 interface=VLAN30 network=10.11.30.0
add address=10.11.10.1/24 interface=VLAN10 network=10.11.10.0
add address=10.11.11.1/24 interface=VLAN11 network=10.11.11.0
add address=10.11.20.1/24 interface=VLAN20 network=10.11.20.0
add address=10.11.100.1/24 interface=VLAN100 network=10.11.100.0
add address=10.11.110.1/24 interface=VLAN110 network=10.11.110.0
add address=10.11.120.1/24 interface=VLAN120 network=10.11.120.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes \
    dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=\
    !LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=\
    established,related
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new disabled=yes in-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
(Just tell me if I have explained something poorly ':-P )
mkx
Re: vlan'ing home lab network
Thu May 13, 2021 8:44 am
Don't set PVID on bridge:
You're using said bridge as tagged further down the config and PVID seting messes that.
BTW, you don't use vlan-bridge as interface (other than underlying interface for VLAN interfaces) and hence doesn't belong in any of interface lists. You should put VLAN interfaces (e.g. VLAN30) in appropriate interface lists.
anav
Thu May 13, 2021 7:46 pm
Please read this reference as a guide
viewtopic.php?f=23&t=143620
millido
Re: vlan'ing home lab network  [SOLVED]
Thu May 13, 2021 9:08 pm
Thanks for the replies!
I did this but it didn't seem to change anything.
However when I did reset the board, clear default configuration, and setup everything myself. It started working exactly as I wanted :D So I guess I misunderstood some of the default config...
But for later reference, I ended up with the same config above. Apart from using only one bridge (from that config, just deleting bridge).
That is a really good reference! I read it multiple times to end up with the config I had in my original post :P
anav
Fri May 14, 2021 3:22 pm
If you had then you wouldn't have made the mistakes pointed out... ;-P ;-)
Glad its up and running for you! Amazing little router!!
Users browsing this forum: Kanzler and 21 guests
