Hi.
A couple of days ago I saw a YT video which recomended some routers for administration according to the size of the network and the traffic to handle, as follows.
RB750gr3 up to 250 hosts and 100 Mbps
RB760igs up to 500 hosts and 200 Mbps
RB4011 up to 1000 hosts and 500 Mbps
CCR Series 1000+ hosts and 500+ Mbps
However, when I compared specs at mikrotik website I found that RB750gr3 and RB760IGS are almost the same hardware excepting the sfp port at RB760IGS.
Both have the same cpu runnign at same frequency (MT7621A @ 800MHz), and the same core/thread count (2c/4t).
Both have the same amount of ram and internal storage: 256MB Ram and 16MB storage.
Both have the same amount of gigabit ports: 5
Both have the same numbers at test results, ethernet test results and IPsec test results are identical.
The only difference I saw is RB760IGS have a SFP port while RB750gr3 doesn't.
Inlcuding the block diagrams with disabled switching or enabled switching are pretty the same, except SFP port at RB760IGS is connected through XOR gate on first cpu line between cpu and ethernet ports.
If these routers are practically the same equipment, then... how they can suggest RB760IGS to handle a network twice the size of the first one.
Am I right? or I am missing something?
Thanks in advaced.-
