Pizgu
[Orange][PL] Use RB750Gr3 as router to LAN & IPTV, rest by another router for WiFi
Thu Jun 10, 2021 8:10 am
As in title I've already describe maybe next I'll show my configuration.
# jun/1/2021 18:41:08 by RouterOS 6.49beta27
# model =RB750Gr3
add name=local-network
add igmp-snooping=yes name=orange-iptv
set [ find default-name=ether1 ] name=eth1-WAN
set [ find default-name=ether2 ] name=eth2-TV
set [ find default-name=ether3 ] name=eth3-AX11000
/interface vlan
add interface=eth1-WAN mtu=1492 name=vlan-orange vlan-id=35
add interface=eth1-WAN name=vlan-orange-tv vlan-id=839
add interface=eth1-WAN name=vlan-orange-vod vlan-id=838
add interface=eth2-TV name=vlan-orange-tv-local vlan-id=100
/interface pppoe-client
add name=pppoe-orange add-default-route=yes disabled=no interface=vlan-orange keepalive-timeout=disabled max-mtu=1492 use-peer-dns=yes user="X@neostrada.pl" password="X"
add name=WAN
add name=LAN
add name=IPTV
/ip dhcp-client option
add code=60 name=vendor-class-identifier value="'sagemcom'"
add code=61 name=dhcp-client-identifier value="'X'"
add code=77 name=user-class value="0x2546535644534c5f66756e626f782e4d4c54562e736f66746174686f6d652e46756e626f7836"
add name=dhcp ranges=192.168.1.100-192.168.1.254
add name=orange-tv ranges=192.168.2.1-192.168.2.10
add add-arp=yes address-pool=dhcp always-broadcast=yes disabled=no interface=local-network lease-time=3h name=defconf
add address-pool=orange-tv disabled=no interface=vlan-orange-tv-local lease-time=3h name=dhcp-iptv
/interface bridge filter
add action=set-priority chain=output new-priority=4 out-interface=vlan-orange-tv passthrough=yes
add action=set-priority chain=output new-priority=4 out-interface=vlan-orange-vod passthrough=yes
add bridge=local-network comment=defconf interface=eth2-TV
add bridge=local-network comment=defconf interface=eth3-AX11000
add bridge=orange-iptv interface=vlan-orange-tv
add bridge=orange-iptv interface=vlan-orange-vod
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
add interface=local-network list=LAN
add interface=eth1-WAN list=WAN
add interface=pppoe-orange list=WAN
add interface=orange-iptv list=IPTV
add interface=vlan-orange-tv-local list=IPTV
add address=192.168.1.1/24 comment=defconf interface=eth3-AX11000 network=192.168.1.0
add address=192.168.2.1/24 interface=eth2-TV network=192.168.2.0
/ip dhcp-client
add add-default-route=special-classless default-route-distance=210 dhcp-options=hostname,dhcp-client-identifier,vendor-class-identifier,user-class disabled=no interface=orange-iptv use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.1.2 comment="TP-Link Archer AX11000" mac-address=X server=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
add address=192.168.2.0/24 gateway=192.168.2.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.1.1 name=MikroTik-RB750Gr3
/ip firewall address-list
add address=192.168.1.0/24 list=internal
add address=192.168.2.0/24 list=guest
add action=accept chain=input comment="Accept incoming IPTV" in-interface-list=IPTV
add action=drop chain=forward dst-address-list=internal src-address-list=guest
add action=accept chain=forward in-interface=vlan-orange-tv-local out-interface=pppoe-orange
add action=accept chain=forward disabled=yes in-interface=vlan-orange-tv-local out-interface=orange-iptv
add action=accept chain=forward in-interface=orange-iptv out-interface=vlan-orange-tv-local
add action=accept chain=forward connection-state=established,related disabled=yes in-interface=orange-iptv
add action=drop chain=forward in-interface-list=IPTV
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat out-interface=orange-iptv
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/routing igmp-proxy
set quick-leave=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=orange-iptv upstream=yes
add alternative-subnets=0.0.0.0/0 interface=eth2-TV
So, I've Your router as main to configure WAN & IPTV. Next router is TP-Link Archer AX11000, this should be used for WiFi as AP.
But, within this configuration all imports are fine, PPPoE connection are fine & establisted. But main problem is that DHCP client didn't receive IP address.
What should I change to fix my configuration? Maybe now I explain how to I want to set it in my home.
Light -> ONT (Huawei) -> MikroTik RB750Gr3:
  • eth1 - WAN
  • eth2 - LAN -> Samsung ICU100 (IPTV, 192.168.2.1-192.168.2.10)
  • eth3 - LAN -> AX11000 (DHCP, dynamic for unsecure (192.168.1.100-192.168.1.254), static for secure(192.168.1.2-192.168.1.99)
This is possible? Other person from Polish boards said it's works, but he use LAN instead on WAN to propagate connection.
Best regards from Poland,
Gregory
Pizgu
Re: [Orange][PL] Use RB750Gr3 as router to LAN & IPTV, rest by another router for WiFi
Fri Jun 11, 2021 7:19 am
No one has idea how to solve it? :)
AnonimeK
Fri Nov 24, 2023 9:35 pm
Maybe it will help you:
add code=61 name=dhcp-client-identifier value=0x01xxxxxxxxxxxxx
add code=77 name=user-class value=0x2546535644534c5f66756e626f782e4d4c54562e736f66746174686f6d652e46756e626f7836
Best regards
Users browsing this forum: netmas, pfturner and 104 guests
