chribonn
OnePlus does not support USB tethering
Fri Jun 11, 2021 12:16 pm
My OnePlus 8 is unable to do USB Tethering with my Mikrotik routers.
I created a video to demo this USB Tethering doesn't work on OnePlus Phones. In the same video, I demonstrate the correct behavior of a number of Samsung Phones.
If anyone figures out a solution please share.
rextended
Re: OnePlus does not support USB tethering
Fri Jun 11, 2021 2:40 pm
Use one of those Samsung Phones
w32pamela
Re: OnePlus does not support USB tethering  [SOLVED]
Fri Jun 11, 2021 2:46 pm
Have you tried updating your Mikrotik to the latest rOS7.1betaX. That worked for me with my motorola Gpower
rextended
Fri Jun 11, 2021 2:50 pm
put on the right place (not on RouterOS)
default,DUN,SUPL
literally as writed
rextended
Fri Jun 11, 2021 2:57 pm
"USB Tethering doesn't work on OnePlus Phones"
is so stupid video on youtube only for money
you are try if on other brand router work?
you know than at the world exist dozen of other competitor routers?
say than "USB Tethering doesn't work on OnePlus Phones" without specify on title or description "only on MikroTik 6.48 that is the only router I haved used"
is so stupid...
and again if "USB Tethering doesn't work on OnePlus Phones"
where are the other users than say the same? you arethe only one than have this problem?
probably the problem is not the MikroTik routerboard but you are unable to use your device
chribonn
Fri Jun 11, 2021 3:29 pm
I might end up having to do that actually or buy me a dongle :-)
Wouldn't it be simpler and better for everyone if OnePlus fixed the problem?
chribonn
Fri Jun 11, 2021 3:30 pm
Thanks - Will try and report back.
chribonn
Fri Jun 11, 2021 3:35 pm
is so stupid...
If it were for the money please tell me how to make it.
Why should I try another brand of router if I am happy with Mikrotik?
Other users with similar issues: https://forums.oneplus.com/threads/usb- ... ng.918730/
If you are associated with OnePlus in any way it would really help if you can contribute to help address the problem. IMO everyone stands to benefit. If you notice that I am doing something wrong please share the solution and I will, after having verified the suggestion, share an update so that others can benefit. Have a great day :-)
rextended
Fri Jun 11, 2021 3:45 pm
You do not catch the point of whai I want mean:
say than "USB Tethering doesn't work on OnePlus Phones" without specify on title or description [edit]of youtube video[/end edit] "only on MikroTik 6.48 that is the only router I haved used"
is so stupid...
chribonn
Fri Jun 11, 2021 4:04 pm
is so stupid...
We can speak Italian if you want :-)
The reason I need this solution is because I travel to Italy a lot and am planning to get illiad or ho-mobile (with their 120Gb per month).
My daily driver is this oneplus and I have a Mikrotik hAP ac lite at hand. Carrying another phone is a complication I would like to avoid (different chargers / sim sizes / inconvenience of multiple phones).
Well I am happy to report that after I updated to the beta firmware and my OnePlus is working.
Thank you to everyone who helped out. I will update the youtube thread accordingly.
Buona Giornata e bon weekend.
rextended
Fri Jun 11, 2021 4:09 pm
Buona giornata anche a te.
Users browsing this forum: No registered users and 67 guests
