Ixman
Mikro Tik Cap AC Lite + Cap Lite Setup for Capsman
Mon Jul 05, 2021 12:57 am
Hello Everyone,
I have the following Network Setup: WAN router from provider (also DHCP server of the network) - Switch (TP Link) CAP AC Lite and Cap Lite are linked to the switch.
I like to set up the AC as Capsman and the CAP lite as CAP.
I also like to have a guest wlan based on the caps.
I like to set up firewall that guest cannot reach the lan only to reach the internet.
On top id like to set up new DHCP server just for all Wifi connections / devices - working on the caps. (if possible with current hardware setup / wiring)
With proper firewall setup and second DHCP im strugling.
In addition i have the current issue that after power loss both CAP interfaces are not activated. I think this is an firwall issue, it seems like firewall stops caps from connnecting to capsman.
Attached you can find config file of CAP AC lite (capsman)
Thanks in advance for your support.
Greeting Ixman!
ConnyMercier
Forum Veteran
Forum Veteran
Re: Mikro Tik Cap AC Lite + Cap Lite Setup for Capsman
Tue Aug 17, 2021 1:46 pm
Good Morning,
The simple Solution could be to use VLAN-Tagging for your WIFI-Clients
Your ISP-Router or Mikrotik can Provide on the VLAN all needed Services like DHCP, DNS, Routing and Firewall
Could that be a Solution for you ?
Users browsing this forum: No registered users and 112 guests
