SfieszaQ
Two gateways...How to?
Tue Jul 06, 2021 12:51 am
I need your help. I have 2 MT switches. One in UK and one in Poland. I am currently in Poland and I want use UK Netflix. I have problem how to set up my PL MT properly.
My MT consists with 5 ports. I set up so far:
- Bridge_PL with Port 1 & 2 & 3 with DHCP Client, Port 1 is connected to my Router providing access to internet (GW 192.168.1.1) (Works),
- Bridge UK with Port 4 & 5 and WiFi and DHCP Server (Works),
- SSTP_UK connected to my UK MT (Works).
Now cherry! How to set up in Routing? Gateway 192.168.1.1 from DHCP for Bridge_PL and in same time Gateway SSTP_UK for Bridge_UK?
Thanks a lot in advance
Ad
anav
Re: Two gateways...How to?
Tue Jul 06, 2021 4:10 pm
Configured as switches I dont believe MT devices can do what you want.
YOu need the Main Routers to be MT, or the switches configured as Router & Switch and in this case you will have a double NAT scenario to work through as well.
If so, I have done so with wireguard on the beta firmware.
SfieszaQ
Tue Jul 06, 2021 11:05 pm
Hmmm...I think there is solution but my experience is on low level. I believe the key is to add routs properly somehow :(
anav
Wed Jul 07, 2021 12:38 am
Routes where?? (which devices)?
Users browsing this forum: Google [Bot], Kanzler and 30 guests
