dzo
Access to Router in LAN2
Wed Jul 07, 2021 1:08 am
I have two (in fact 5) VLAN, and in both there are Mikrotiks and other devices, some of them I like to see in the other VLAN.
VLAN100: vlan100_Mitarbeiter, Network: 192.168.96.0/20 - There is my PC and the most Mikrotiks, like this one, I call it MainRouter here.
VLAN200: vlan200_Technik, Network: 192.168.112.0/20 - There are two devices I like to access from my PC: a "Mischpult" and another Mikrotik, I call it "AP-Router" here.
The device "Mischpult" in VLAN200 with IP 192.168.120.100 is accessable from the VLAN100 via IP 192.168.100.200
I thought I could made this for "AP-Router" in VLAN200 with IP 192.168.120.205 via IP 192.168.100.14 in VLAN100.
Why does the device "Mischpult" works, the device "AP-Router" not?!? You see me after hours of tries... now only remote connected, the afternoon direcly sitting in VLAN100...
First, a ping from the Mikrotik MainRouter, which does the masquerading, works: ping to 192.168.120.205 is ok, the connection is up and running.
If I change my PC to VLAN200, I can access the "AP-Router". But why am I not able to masquerade like the "Mischpult"?!?
The roules that works:
add action=dst-nat chain=dstnat comment=Fritz-Box dst-address=192.168.100.2 \
    log-prefix=Fritz-Box to-addresses=192.168.64.1
add action=dst-nat chain=dstnat comment="Mischer im Hauptnetz" dst-address=\
    192.168.100.200 to-addresses=192.168.120.100
first try:
    192.168.100.14 to-addresses=192.168.120.205
and here my last try:
add action=dst-nat chain=dstnat comment="Router Mischpult" dst-address=\
    192.168.100.14 log=yes log-prefix=DestNat to-addresses=192.168.120.205
add action=src-nat chain=srcnat comment="Router Mischpult" dst-address=\
    192.168.120.205 dst-port=8291 log=yes log-prefix=MasqWinbox protocol=tcp \
    src-address=192.168.200.0/24 to-addresses=192.168.120.1
    src-address=192.168.96.0/20 to-addresses=192.168.120.1
add action=src-nat chain=srcnat comment="Router Mischpult" out-interface=\
    ovpn-DirksLT src-address=192.168.120.205 to-addresses=192.168.201.1
I can see the packets, but it doesn't work:
22:44:43 firewall,info Test OldIP prerouting: in:ovpn-DirksLT out:(unknown 0), src-mac 00:ff:8b:58:a1:ed, proto ICMP (type 8, code 0), 192.168.201.1->192.168.100.14, NAT (192.168.201.1->192.168.100.3)->(192.168.100.14->192.168.120.205), len 60
22:44:43 firewall,info Test DestIP postrouting: in:(unknown 0) out:vlan200_Technik, src-mac 00:ff:8b:58:a1:ed, proto ICMP (type 8, code 0), 192.168.201.1->192.168.120.205, NAT (192.168.201.1->192.168.100.3)->(192.168.100.14->192.168.120.205), len 60
Thanks for your help, here is the whole configuration:
# jul/06/2021 22:43:50 by RouterOS 6.47.8
# software id = DYRD-6AIN
# model = RB4011iGS+5HacQ2HnD
# serial number = D43B0C0FC073
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled \
    frequency=2412,2432,2452,2472 name=2Gch1-5-9-13 save-selected=yes \
    tx-power=-7
add band=5ghz-n/ac extension-channel=disabled frequency=\
    5180,5200,5220,5240,5260,5280,5300,5320,5500,5520,5540,5560 name=5G \
    save-selected=yes
/caps-man datapath
add client-to-client-forwarding=yes local-forwarding=yes name=VLAN100 \
    vlan-id=100 vlan-mode=use-tag
add client-to-client-forwarding=no local-forwarding=yes name=VLAN200 vlan-id=\
    200 vlan-mode=use-tag
add client-to-client-forwarding=no local-forwarding=yes name=VLAN500 vlan-id=\
    500 vlan-mode=use-tag
add fast-forward=no frame-types=admit-only-vlan-tagged name=bridge_LAN \
    vlan-filtering=yes
/interface wireless
# managed by CAPsMAN
# channel: 2412/20/gn(-10dBm), SSID: WLAN_Mitarbeiter, local forwarding
set [ find default-name=wlan2 ] disabled=no name=wlan2G ssid=MikroTik
# channel: 5180/20/ac/P(20dBm), SSID: WLAN_Mitarbeiter, local forwarding
set [ find default-name=wlan1 ] disabled=no name=wlan5G ssid=MikroTik
set [ find default-name=sfp-sfpplus1 ] name=E0-sfp_Uplink
set [ find default-name=ether1 ] name=E1_Internet
set [ find default-name=ether2 ] name=E2_BUp_Room1
set [ find default-name=ether3 ] name=E3_BUp_Room1
set [ find default-name=ether4 ] name=E4_BUp_Switch
set [ find default-name=ether5 ] name=E5_BUp_Switch
set [ find default-name=ether6 ] name=E6_Room3
set [ find default-name=ether7 ] name=E7_Room3
set [ find default-name=ether8 ] name=E8_BUp_Kinder
set [ find default-name=ether9 ] name=E9_BUp_Kinder
set [ find default-name=ether10 ] name="E10_AP Gr Saal" poe-out=forced-on
/interface ovpn-server
add name=ovpn-DirksLT user=DirkLT
add name=ovpn-DirksPC user=DirkPC
add name=ovpn-Florian user=Florian
add name=ovpn-Ralf user=Ralf
/interface vlan
add interface=bridge_LAN name=vlan100_Mitarbeiter vlan-id=100
add interface=bridge_LAN name=vlan200_Technik vlan-id=200
add interface=bridge_LAN name=vlan500_Gast vlan-id=500
add interface=bridge_LAN name=vlan800_KlWg vlan-id=800
add interface=bridge_LAN name=vlan900_GrWg vlan-id=900
/interface bonding
add link-monitoring=none mode=802.3ad name=bond_Room1 slaves=\
    E2_BUp_Room1,E3_BUp_Room1 transmit-hash-policy=layer-2-and-3
add link-monitoring=none mode=802.3ad name=bond_Kinder slaves=\
    E8_BUp_Kinder,E9_BUp_Kinder transmit-hash-policy=layer-2-and-3
add link-monitoring=none mode=802.3ad name=bond_Room3 slaves=\
    E6_Room3,E7_Room3 transmit-hash-policy=layer-2-and-3
add link-monitoring=none mode=802.3ad name=bond_Switch slaves=\
    E4_BUp_Switch,E5_BUp_Switch transmit-hash-policy=layer-2-and-3
/caps-man rates
add basic=12Mbps name=rate2G supported=\
    12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
/caps-man security
add authentication-types=wpa2-psk disable-pmkid=yes encryption=aes-ccm \
    group-encryption=aes-ccm group-key-update=5m name=Mitarbeiter
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm \
    group-key-update=5m name=Gast
add name=Free
    group-encryption=aes-ccm group-key-update=5m name=Technik
/caps-man configuration
add channel=2Gch1-5-9-13 country=germany datapath=VLAN200 mode=ap \
    multicast-helper=full name=Technik_2G rates=rate2G security=Technik ssid=\
    WLAN-Technik-2G
add channel=5G country=germany datapath=VLAN200 mode=ap multicast-helper=full \
    name=Technik_5G security=Technik ssid=WLAN-Technik-5G
add channel=2Gch1-5-9-13 country=germany datapath=VLAN100 mode=ap \
    multicast-helper=full name="Mitarbeiter 2G" rates=rate2G security=\
    Mitarbeiter ssid=WLAN_Mitarbeiter
add channel=5G country=germany datapath=VLAN100 mode=ap multicast-helper=full \
    name="Mitarbeiter 5G" security=Mitarbeiter ssid=WLAN_Mitarbeiter
add channel=2Gch1-5-9-13 country=germany datapath=VLAN500 mode=ap \
    multicast-helper=full name="Gast 2G" rates=rate2G security=Gast ssid=\
    EFG_Gast
add channel=5G country=germany datapath=VLAN500 mode=ap multicast-helper=full \
    name="Gast 5G" security=Gast ssid=EFG_Gast
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=pool100 ranges=192.168.102.1-192.168.110.253
add name=pool500 ranges=192.168.130.1-192.168.149.253
add name=pool800 ranges=192.168.181.1-192.168.183.253
add name=pool900 ranges=192.168.184.1-192.168.189.254
add name=pool201.64ovpnMaster ranges=192.168.201.253-192.168.201.254
add name=pool201.63ovpnMaster next-pool=pool201.64ovpnMaster ranges=\
    192.168.201.249-192.168.201.250
add name=pool201.62ovpnMaster next-pool=pool201.63ovpnMaster ranges=\
    192.168.201.245-192.168.201.246
add name=pool201.61ovpnMaster next-pool=pool201.62ovpnMaster ranges=\
    192.168.201.241-192.168.201.242
add name=pool201.60ovpnMaster next-pool=pool201.61ovpnMaster ranges=\
    192.168.201.237-192.168.201.238
add name=pool201.59ovpnMaster next-pool=pool201.60ovpnMaster ranges=\
    192.168.201.233-192.168.201.234
add name=pool201.58ovpnMaster next-pool=pool201.59ovpnMaster ranges=\
    192.168.201.229-192.168.201.230
add name=pool201.57ovpnMaster next-pool=pool201.58ovpnMaster ranges=\
    192.168.201.225-192.168.201.226
add name=pool201.56ovpnMaster next-pool=pool201.57ovpnMaster ranges=\
    192.168.201.221-192.168.201.222
add name=pool201.55ovpnMaster next-pool=pool201.56ovpnMaster ranges=\
    192.168.201.217-192.168.201.218
add name=pool201.54ovpnMaster next-pool=pool201.55ovpnMaster ranges=\
    192.168.201.213-192.168.201.214
add name=pool201.53ovpnMaster next-pool=pool201.54ovpnMaster ranges=\
    192.168.201.209-192.168.201.210
add name=pool201.52ovpnMaster next-pool=pool201.53ovpnMaster ranges=\
    192.168.201.205-192.168.201.206
add name=pool201.51ovpnMaster next-pool=pool201.52ovpnMaster ranges=\
    192.168.201.201-192.168.201.202
add name=pool201.50ovpnMaster next-pool=pool201.51ovpnMaster ranges=\
    192.168.201.197-192.168.201.198
add name=pool201.49ovpnMaster next-pool=pool201.50ovpnMaster ranges=\
    192.168.201.193-192.168.201.194
add name=pool201.48ovpnMaster next-pool=pool201.49ovpnMaster ranges=\
    192.168.201.189-192.168.201.190
add name=pool201.47ovpnMaster next-pool=pool201.48ovpnMaster ranges=\
    192.168.201.185-192.168.201.186
add name=pool201.46ovpnMaster next-pool=pool201.47ovpnMaster ranges=\
    192.168.201.181-192.168.201.182
add name=pool201.45ovpnMaster next-pool=pool201.46ovpnMaster ranges=\
    192.168.201.177-192.168.201.178
add name=pool201.44ovpnMaster next-pool=pool201.45ovpnMaster ranges=\
    192.168.201.173-192.168.201.174
add name=pool201.43ovpnMaster next-pool=pool201.44ovpnMaster ranges=\
    192.168.201.169-192.168.201.170
add name=pool201.42ovpnMaster next-pool=pool201.43ovpnMaster ranges=\
    192.168.201.165-192.168.201.166
add name=pool201.41ovpnMaster next-pool=pool201.42ovpnMaster ranges=\
    192.168.201.161-192.168.201.162
add name=pool201.40ovpnMaster next-pool=pool201.41ovpnMaster ranges=\
    192.168.201.157-192.168.201.158
add name=pool201.39ovpnMaster next-pool=pool201.40ovpnMaster ranges=\
    192.168.201.153-192.168.201.154
add name=pool201.38ovpnMaster next-pool=pool201.39ovpnMaster ranges=\
    192.168.201.149-192.168.201.150
add name=pool201.37ovpnMaster next-pool=pool201.38ovpnMaster ranges=\
    192.168.201.145-192.168.201.146
add name=pool201.36ovpnMaster next-pool=pool201.37ovpnMaster ranges=\
    192.168.201.141-192.168.201.142
add name=pool201.35ovpnMaster next-pool=pool201.36ovpnMaster ranges=\
    192.168.201.137-192.168.201.138
add name=pool201.34ovpnMaster next-pool=pool201.35ovpnMaster ranges=\
    192.168.201.133-192.168.201.134
add name=pool201.33ovpnMaster next-pool=pool201.34ovpnMaster ranges=\
    192.168.201.129-192.168.201.130
add name=pool201.32ovpnMaster next-pool=pool201.33ovpnMaster ranges=\
    192.168.201.125-192.168.201.126
add name=pool201.31ovpnMaster next-pool=pool201.32ovpnMaster ranges=\
    192.168.201.121-192.168.201.122
add name=pool201.30ovpnMaster next-pool=pool201.31ovpnMaster ranges=\
    192.168.201.117-192.168.201.118
add name=pool201.29ovpnMaster next-pool=pool201.30ovpnMaster ranges=\
    192.168.201.113-192.168.201.114
add name=pool201.28ovpnMaster next-pool=pool201.29ovpnMaster ranges=\
    192.168.201.109-192.168.201.110
add name=pool201.27ovpnMaster next-pool=pool201.28ovpnMaster ranges=\
    192.168.201.105-192.168.201.106
add name=pool201.26ovpnMaster next-pool=pool201.27ovpnMaster ranges=\
    192.168.201.101-192.168.201.102
add name=pool201.25ovpnMaster next-pool=pool201.26ovpnMaster ranges=\
    192.168.201.97-192.168.201.98
add name=pool201.24ovpnMaster next-pool=pool201.25ovpnMaster ranges=\
    192.168.201.93-192.168.201.94
add name=pool201.23ovpnMaster next-pool=pool201.24ovpnMaster ranges=\
    192.168.201.89-192.168.201.90
add name=pool201.22ovpnMaster next-pool=pool201.23ovpnMaster ranges=\
    192.168.201.85-192.168.201.86
add name=pool201.21ovpnMaster next-pool=pool201.22ovpnMaster ranges=\
    192.168.201.81-192.168.201.82
add name=pool201.20ovpnMaster next-pool=pool201.21ovpnMaster ranges=\
    192.168.201.77-192.168.201.78
add name=pool201.19ovpnMaster next-pool=pool201.20ovpnMaster ranges=\
    192.168.201.73-192.168.201.74
add name=pool201.18ovpnMaster next-pool=pool201.19ovpnMaster ranges=\
    192.168.201.69-192.168.201.70
add name=pool201.17ovpnMaster next-pool=pool201.18ovpnMaster ranges=\
    192.168.201.65-192.168.201.66
add name=pool201.16ovpnMaster next-pool=pool201.17ovpnMaster ranges=\
    192.168.201.61-192.168.201.62
add name=pool201.15ovpnMaster next-pool=pool201.16ovpnMaster ranges=\
    192.168.201.57-192.168.201.58
add name=pool201.14ovpnMaster next-pool=pool201.15ovpnMaster ranges=\
    192.168.201.53-192.168.201.54
add name=pool201.13ovpnMaster next-pool=pool201.14ovpnMaster ranges=\
    192.168.201.49-192.168.201.50
add name=pool201.12ovpnMaster next-pool=pool201.13ovpnMaster ranges=\
    192.168.201.45-192.168.201.46
add name=pool201.11ovpnMaster next-pool=pool201.12ovpnMaster ranges=\
    192.168.201.41-192.168.201.42
add name=pool201.10ovpnMaster next-pool=pool201.11ovpnMaster ranges=\
    192.168.201.37-192.168.201.38
add name=pool201.09ovpnMaster next-pool=pool201.10ovpnMaster ranges=\
    192.168.201.33-192.168.201.34
add name=pool201.08ovpnMaster next-pool=pool201.09ovpnMaster ranges=\
    192.168.201.29-192.168.201.30
add name=pool201.07ovpnMaster next-pool=pool201.08ovpnMaster ranges=\
    192.168.201.25-192.168.201.26
add name=pool201.06ovpnMaster next-pool=pool201.07ovpnMaster ranges=\
    192.168.201.21-192.168.201.22
add name=pool201.05ovpnMaster next-pool=pool201.06ovpnMaster ranges=\
    192.168.201.17-192.168.201.18
add name=pool201.04ovpnMaster next-pool=pool201.05ovpnMaster ranges=\
    192.168.201.13-192.168.201.14
add name=pool201.03ovpnMaster next-pool=pool201.04ovpnMaster ranges=\
    192.168.201.9-192.168.201.10
add name=pool201.02ovpnMaster next-pool=pool201.03ovpnMaster ranges=\
    192.168.201.5-192.168.201.6
add comment=Master-OpenVPN-Port name=pool201.01ovpnMaster next-pool=\
    pool201.02ovpnMaster ranges=192.168.201.1-192.168.201.2
add name=pool202.64ovpnTechnik ranges=192.168.202.253-192.168.202.254
add name=pool202.63ovpnTechnik next-pool=pool202.64ovpnTechnik ranges=\
    192.168.202.249-192.168.202.250
add name=pool202.62ovpnTechnik next-pool=pool202.63ovpnTechnik ranges=\
    192.168.202.245-192.168.202.246
add name=pool202.61ovpnTechnik next-pool=pool202.62ovpnTechnik ranges=\
    192.168.202.241-192.168.202.242
add name=pool202.60ovpnTechnik next-pool=pool202.61ovpnTechnik ranges=\
    192.168.202.237-192.168.202.238
add name=pool202.59ovpnTechnik next-pool=pool202.60ovpnTechnik ranges=\
    192.168.202.233-192.168.202.234
add name=pool202.58ovpnTechnik next-pool=pool202.59ovpnTechnik ranges=\
    192.168.202.229-192.168.202.230
add name=pool202.57ovpnTechnik next-pool=pool202.58ovpnTechnik ranges=\
    192.168.202.225-192.168.202.226
add name=pool202.56ovpnTechnik next-pool=pool202.57ovpnTechnik ranges=\
    192.168.202.221-192.168.202.222
add name=pool202.55ovpnTechnik next-pool=pool202.56ovpnTechnik ranges=\
    192.168.202.217-192.168.202.218
add name=pool202.54ovpnTechnik next-pool=pool202.55ovpnTechnik ranges=\
    192.168.202.213-192.168.202.214
add name=pool202.53ovpnTechnik next-pool=pool202.54ovpnTechnik ranges=\
    192.168.202.209-192.168.202.210
add name=pool202.52ovpnTechnik next-pool=pool202.53ovpnTechnik ranges=\
    192.168.202.205-192.168.202.206
add name=pool202.51ovpnTechnik next-pool=pool202.52ovpnTechnik ranges=\
    192.168.202.201-192.168.202.202
add name=pool202.50ovpnTechnik next-pool=pool202.51ovpnTechnik ranges=\
    192.168.202.197-192.168.202.198
add name=pool202.49ovpnTechnik next-pool=pool202.50ovpnTechnik ranges=\
    192.168.202.193-192.168.202.194
add name=pool202.48ovpnTechnik next-pool=pool202.49ovpnTechnik ranges=\
    192.168.202.189-192.168.202.190
add name=pool202.47ovpnTechnik next-pool=pool202.48ovpnTechnik ranges=\
    192.168.202.185-192.168.202.186
add name=pool202.46ovpnTechnik next-pool=pool202.47ovpnTechnik ranges=\
    192.168.202.181-192.168.202.182
add name=pool202.45ovpnTechnik next-pool=pool202.46ovpnTechnik ranges=\
    192.168.202.177-192.168.202.178
add name=pool202.44ovpnTechnik next-pool=pool202.45ovpnTechnik ranges=\
    192.168.202.173-192.168.202.174
add name=pool202.43ovpnTechnik next-pool=pool202.44ovpnTechnik ranges=\
    192.168.202.169-192.168.202.170
add name=pool202.42ovpnTechnik next-pool=pool202.43ovpnTechnik ranges=\
    192.168.202.165-192.168.202.166
add name=pool202.41ovpnTechnik next-pool=pool202.42ovpnTechnik ranges=\
    192.168.202.161-192.168.202.162
add name=pool202.40ovpnTechnik next-pool=pool202.41ovpnTechnik ranges=\
    192.168.202.157-192.168.202.158
add name=pool202.39ovpnTechnik next-pool=pool202.40ovpnTechnik ranges=\
    192.168.202.153-192.168.202.154
add name=pool202.38ovpnTechnik next-pool=pool202.39ovpnTechnik ranges=\
    192.168.202.149-192.168.202.150
add name=pool202.37ovpnTechnik next-pool=pool202.38ovpnTechnik ranges=\
    192.168.202.145-192.168.202.146
add name=pool202.36ovpnTechnik next-pool=pool202.37ovpnTechnik ranges=\
    192.168.202.141-192.168.202.142
add name=pool202.35ovpnTechnik next-pool=pool202.36ovpnTechnik ranges=\
    192.168.202.137-192.168.202.138
add name=pool202.34ovpnTechnik next-pool=pool202.35ovpnTechnik ranges=\
    192.168.202.133-192.168.202.134
add name=pool202.33ovpnTechnik next-pool=pool202.34ovpnTechnik ranges=\
    192.168.202.129-192.168.202.130
add name=pool202.32ovpnTechnik next-pool=pool202.33ovpnTechnik ranges=\
    192.168.202.125-192.168.202.126
add name=pool202.31ovpnTechnik next-pool=pool202.32ovpnTechnik ranges=\
    192.168.202.121-192.168.202.122
add name=pool202.30ovpnTechnik next-pool=pool202.31ovpnTechnik ranges=\
    192.168.202.117-192.168.202.118
add name=pool202.29ovpnTechnik next-pool=pool202.30ovpnTechnik ranges=\
    192.168.202.113-192.168.202.114
add name=pool202.28ovpnTechnik next-pool=pool202.29ovpnTechnik ranges=\
    192.168.202.109-192.168.202.110
add name=pool202.27ovpnTechnik next-pool=pool202.28ovpnTechnik ranges=\
    192.168.202.105-192.168.202.106
add name=pool202.26ovpnTechnik next-pool=pool202.27ovpnTechnik ranges=\
    192.168.202.101-192.168.202.102
add name=pool202.25ovpnTechnik next-pool=pool202.26ovpnTechnik ranges=\
    192.168.202.97-192.168.202.98
add name=pool202.24ovpnTechnik next-pool=pool202.25ovpnTechnik ranges=\
    192.168.202.93-192.168.202.94
add name=pool202.23ovpnTechnik next-pool=pool202.24ovpnTechnik ranges=\
    192.168.202.89-192.168.202.90
add name=pool202.22ovpnTechnik next-pool=pool202.23ovpnTechnik ranges=\
    192.168.202.85-192.168.202.86
add name=pool202.21ovpnTechnik next-pool=pool202.22ovpnTechnik ranges=\
    192.168.202.81-192.168.202.82
add name=pool202.20ovpnTechnik next-pool=pool202.21ovpnTechnik ranges=\
    192.168.202.77-192.168.202.78
add name=pool202.19ovpnTechnik next-pool=pool202.20ovpnTechnik ranges=\
    192.168.202.73-192.168.202.74
add name=pool202.18ovpnTechnik next-pool=pool202.19ovpnTechnik ranges=\
    192.168.202.69-192.168.202.70
add name=pool202.17ovpnTechnik next-pool=pool202.18ovpnTechnik ranges=\
    192.168.202.65-192.168.202.66
add name=pool202.16ovpnTechnik next-pool=pool202.17ovpnTechnik ranges=\
    192.168.202.61-192.168.202.62
add name=pool202.15ovpnTechnik next-pool=pool202.16ovpnTechnik ranges=\
    192.168.202.57-192.168.202.58
add name=pool202.14ovpnTechnik next-pool=pool202.15ovpnTechnik ranges=\
    192.168.202.53-192.168.202.54
add name=pool202.13ovpnTechnik next-pool=pool202.14ovpnTechnik ranges=\
    192.168.202.49-192.168.202.50
add name=pool202.12ovpnTechnik next-pool=pool202.13ovpnTechnik ranges=\
    192.168.202.45-192.168.202.46
add name=pool202.11ovpnTechnik next-pool=pool202.12ovpnTechnik ranges=\
    192.168.202.41-192.168.202.42
add name=pool202.10ovpnTechnik next-pool=pool202.11ovpnTechnik ranges=\
    192.168.202.37-192.168.202.38
add name=pool202.09ovpnTechnik next-pool=pool202.10ovpnTechnik ranges=\
    192.168.202.33-192.168.202.34
add name=pool202.08ovpnTechnik next-pool=pool202.09ovpnTechnik ranges=\
    192.168.202.29-192.168.202.30
add name=pool202.07ovpnTechnik next-pool=pool202.08ovpnTechnik ranges=\
    192.168.202.25-192.168.202.26
add name=pool202.06ovpnTechnik next-pool=pool202.07ovpnTechnik ranges=\
    192.168.202.21-192.168.202.22
add name=pool202.05ovpnTechnik next-pool=pool202.06ovpnTechnik ranges=\
    192.168.202.17-192.168.202.18
add name=pool202.04ovpnTechnik next-pool=pool202.05ovpnTechnik ranges=\
    192.168.202.13-192.168.202.14
add name=pool202.03ovpnTechnik next-pool=pool202.04ovpnTechnik ranges=\
    192.168.202.9-192.168.202.10
add name=pool202.02ovpnTechnik next-pool=pool202.03ovpnTechnik ranges=\
    192.168.202.5-192.168.202.6
add comment=Techniker-OpenVPN-Port name=pool202.01ovpnTechnik next-pool=\
    pool202.02ovpnTechnik ranges=192.168.202.1-192.168.202.2
add name=pool200b ranges=192.168.127.0-192.168.127.254
add address-pool=pool100 disabled=no interface=vlan100_Mitarbeiter name=\
    dhcp100
add address-pool=pool500 disabled=no interface=vlan500_Gast lease-time=30m \
    name=dhcp500
add address-pool=pool800 disabled=no interface=vlan800_KlWg name=dhcp800
add address-pool=pool900 disabled=no interface=vlan900_GrWg name=dhcp900
add name=pool200 next-pool=pool200b ranges=192.168.121.1-192.168.126.255
add address-pool=pool200 disabled=no interface=vlan200_Technik \
    lease-time=1h name=dhcp200
/ppp profile
add dns-server=192.168.100.1 local-address=pool201.01ovpnMaster name=\
    RoadWarrior remote-address=pool201.01ovpnMaster use-compression=no \
    use-encryption=required wins-server=192.168.100.1
add dns-server=192.168.200.1 local-address=pool202.01ovpnTechnik name=\
    RoadWarriorTechnik remote-address=pool202.01ovpnTechnik use-compression=\
    no use-encryption=required wins-server=192.168.200.1
/queue type
add kind=pcq name=pcq-dwn-Gast pcq-burst-rate=50M pcq-burst-time=30s \
    pcq-classifier=dst-address pcq-limit=1000KiB pcq-rate=10M \
    pcq-total-limit=200000KiB
add kind=pcq name=pcq-upl-Gast pcq-burst-rate=30M pcq-burst-time=30s \
    pcq-classifier=src-address pcq-limit=1000KiB pcq-rate=10M \
add kind=pcq name=pcq-dwn-Hold pcq-classifier=dst-address pcq-limit=5000KiB \
add kind=pcq name=pcq-upl-hold pcq-classifier=src-address pcq-limit=5000KiB \
add kind=pcq name=pcq-dwn-big pcq-classifier=dst-address pcq-limit=10000KiB \
    pcq-total-limit=300000KiB
add kind=pcq name=pcq-upl-big pcq-classifier=src-address pcq-limit=10000KiB \
/queue simple
add max-limit=53M/115M name=Internet queue=pcq-upl-big/pcq-dwn-big target=\
    192.168.0.0/16 time=0s-1d,sun,mon,tue,wed,thu,fri,sat
add limit-at=20M/20M max-limit=53M/115M name=Technik parent=Internet \
    priority=1/1 queue=pcq-upl-hold/pcq-dwn-Hold target=192.168.112.0/20
add limit-at=10M/10M max-limit=53M/115M name="KlWG" parent=Internet \
    priority=3/3 target=192.168.176.0/21
add limit-at=1M/1M max-limit=30M/60M name=Gast parent=Internet queue=\
    pcq-upl-Gast/pcq-dwn-Gast target=192.168.128.0/19
add limit-at=10M/10M max-limit=53M/115M name=GrosseWG parent=Internet \
    priority=3/3 target=192.168.190.0/23
add limit-at=5M/5M max-limit=53M/115M name=Mitarbeiter parent=Internet \
    priority=2/2 queue=pcq-upl-hold/pcq-dwn-Hold target=192.168.96.0/20
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes package-path=UpdatesROS \
    upgrade-policy=suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
    "Mitarbeiter 5G" name-format=prefix-identity name-prefix=cap5G \
    slave-configurations="Technik_5G,Gast 5G"
add action=create-dynamic-enabled hw-supported-modes=gn identity-regexp=\
    .*Rest.* master-configuration="Mitarbeiter 2G" name-format=\
    prefix-identity name-prefix=capR2G slave-configurations="Gast 2G"
    .*Technik.* master-configuration=Technik_2G name-format=prefix-identity \
    name-prefix=capT2G
add action=create-dynamic-enabled hw-supported-modes=g,gn identity-regexp=\
    .*All.* master-configuration="Mitarbeiter 2G" name-format=prefix-identity \
    name-prefix=cap2G slave-configurations="Technik_2G,Gast 2G"
add action=create-dynamic-enabled disabled=yes hw-supported-modes=gn \
add bridge=bridge_LAN frame-types=admit-only-vlan-tagged ingress-filtering=\
    yes interface="E10_AP Gr Saal" pvid=100
    yes interface=E0-sfp_Uplink
    yes interface=bond_Room1 pvid=100
add bridge=bridge_LAN interface=bond_Room3
add bridge=bridge_LAN interface=bond_Switch
    yes interface=bond_Kinder
/interface bridge settings
set allow-fast-path=no use-ip-firewall=yes
/ip settings
/interface bridge vlan
add bridge=bridge_LAN tagged="bridge_LAN,bond_Room3,bond_Switch,bond_Kinder\
    ,bond_Room1,E0-sfp_Uplink,E10_AP Gr Saal" vlan-ids=100
add bridge=bridge_LAN tagged="bridge_LAN,E10_AP Gr Saal,bond_Room1,bond_Pastora\
    t,bond_Switch,bond_Kinder,E0-sfp_Uplink" vlan-ids=200
    t,bond_Switch,bond_Kinder,E0-sfp_Uplink" vlan-ids=500
add bridge=bridge_LAN tagged=\
    bridge_LAN,bond_Room3,bond_Switch,E0-sfp_Uplink vlan-ids=800
    bridge_LAN,bond_Switch,bond_Room3,E0-sfp_Uplink vlan-ids=900
add interface=E1_Internet list=WAN
/interface ovpn-server server
set auth=sha1 certificate=efggoslar_Server.crt_0 cipher=aes256 \
    default-profile=RoadWarrior enabled=yes mode=ethernet netmask=20 \
    require-client-certificate=yes
/interface wireless cap
set bridge=bridge_LAN certificate=request discovery-interfaces=\
    vlan200_Technik enabled=yes interfaces=wlan2G,wlan5G
add address=192.168.100.1/20 comment="Router im Hauptnetz: Router selber" \
    interface=vlan100_Mitarbeiter network=192.168.96.0
add address=192.168.120.1/20 comment=Technik interface=\
    vlan200_Technik network=192.168.112.0
add address=192.168.150.1/19 comment="Gastnetz Offen" interface=vlan500_Gast \
    network=192.168.128.0
add address=192.168.180.1/21 comment="Kleine WG" interface=vlan800_KlWg \
    network=192.168.176.0
add address=192.168.190.1/23 comment="Gro\DFe WG" interface=vlan900_GrWg \
    network=192.168.190.0
add address=192.168.100.2/20 comment="Router im Hauptnetz: FritzBox-MASQ" \
add address=192.168.64.2/24 comment="Router im Fritznetz" interface=\
    E1_Internet network=192.168.64.0
add address=192.168.100.14/20 comment="Router im Hauptnetz: Router Mischpult" \
add address=192.168.120.110/20 interface=vlan200_Technik \
add address=192.168.120.111/20 interface=vlan200_Technik \
add address=192.168.120.200/20 interface=vlan200_Technik \
add address=192.168.100.200/20 comment="Router im Hauptnetz: Mischpult" \
/ip dhcp-server lease
add address=192.168.100.100 client-id=1:5c:f4:ab:e4:c0:8f comment=\
    "Server" mac-address=5C:F4:AB:E4:C0:8F server=dhcp100
add address=192.168.120.101 client-id=1:94:db:56:2a:ae:29 comment=\
    "Tec TV Kl. Saal" mac-address=94:DB:56:2A:AE:29 server=dhcp200
add address=192.168.120.102 client-id=1:94:db:56:9a:cf:c5 comment=\
    "Tec TV Kinder" mac-address=94:DB:56:9A:CF:C5 server=dhcp200
add address=192.168.100.110 client-id=1:ec:9a:74:35:d8:bf comment=\
    "Drucker" mac-address=EC:9A:74:35:D8:BF server=dhcp100
add address=192.168.100.111 client-id=1:0:1b:a9:54:bb:8f mac-address=\
    00:1B:A9:54:BB:8F server=dhcp100
add address=192.168.120.120 client-id=1:dc:a6:32:d8:2b:39 comment=\
    Videomischer mac-address=DC:A6:32:D8:2B:39 server=dhcp200
add address=192.168.120.150 client-id=1:bc:5f:f4:f8:d4:b1 comment="Video PC" \
    mac-address=BC:5F:F4:F8:D4:B1 server=dhcp200
add address=192.168.96.0/20 comment=Mitarbeiter dns-server=192.168.100.1 \
    gateway=192.168.100.1
add address=192.168.112.0/20 comment=Technik dns-server=\
    192.168.120.1 gateway=192.168.120.1
add address=192.168.128.0/19 comment=Gast dns-server=192.168.150.1 gateway=\
    192.168.150.1
add address=192.168.176.0/21 comment="Kleine WG" dns-server=\
    192.168.180.1 gateway=192.168.180.1
add address=192.168.190.0/23 comment="Gro\DFe WG" dns-server=\
    192.168.190.1 gateway=192.168.190.1
set allow-remote-requests=yes servers=192.168.100.2,192.168.64.1
add action=fasttrack-connection chain=forward comment="Grund: fasttrack" \
    connection-state=established,related disabled=yes
    "Grund: Acc Forw established,related, untracked" connection-state=\
    established,related,untracked
add action=accept chain=forward comment="Winbox ist ok" dst-address=\
    224.0.0.0/4 log-prefix=Multicast
add action=drop chain=forward comment="Grund: Drop Forw invalid" \
    connection-state=invalid
add action=accept chain=forward port=8291 protocol=tcp
add action=accept chain=forward comment="Nur eigene Netze im Netz" \
    dst-address=192.168.96.0/20 log=yes log-prefix=MA-Netz src-address=\
    192.168.96.0/20
add action=accept chain=forward dst-address=192.168.112.0/20 log-prefix=\
    Veranst.-Netz src-address=192.168.112.0/20
add action=accept chain=forward dst-address=192.168.176.0/21 log-prefix=\
    Kl.WG-Netz src-address=192.168.176.0/21
add action=accept chain=forward dst-address=192.168.190.0/23 log-prefix=\
    GrWG-Netz src-address=192.168.190.0/23
add action=accept chain=forward dst-address=192.168.120.1 log-prefix=\
    "Gastnetz nur zum Router erlaubt" src-address=192.168.128.0/19
add action=accept chain=forward comment="Eigene Netze ins Internet" \
    in-interface=vlan100_Mitarbeiter log-prefix=MA-Netz out-interface=\
    E1_Internet src-address=192.168.96.0/20
add action=accept chain=forward in-interface=vlan200_Technik \
    log-prefix=Gaeste out-interface=E1_Internet src-address=192.168.112.0/20
add action=accept chain=forward in-interface=vlan500_Gast log-prefix=Gaeste \
    out-interface=E1_Internet src-address=192.168.128.0/19
add action=accept chain=forward in-interface=vlan800_KlWg log-prefix=\
    KlWohnung out-interface=E1_Internet src-address=192.168.176.0/21
add action=accept chain=forward in-interface=vlan900_GrWg log-prefix=\
    GrWohnung out-interface=E1_Internet src-address=192.168.190.0/23
add action=accept chain=forward comment="Router d\FCrfen alles" log-prefix=\
    "Router in alles" src-address=192.168.100.0/24
add action=accept chain=input log-prefix="Technik auf Router" src-address=\
    192.168.112.0/20
add action=accept chain=output dst-address=192.168.112.0/20 log-prefix=\
    "Technik von Router"
    "Grund: Acc Input established,related,untracked" connection-state=\
add action=accept chain=input comment="Winbox Firewall" dst-port=8291 \
    protocol=tcp
add action=accept chain=output log-prefix=Winbox->DirksLT protocol=tcp \
    src-port=8291
add action=accept chain=input comment=OpenVPNZugang dst-port=1194 log-prefix=\
    "VPN In" protocol=tcp
add action=accept chain=output log-prefix="VPN Out" protocol=tcp src-port=\
    1194
add action=accept chain=forward comment="Mikrotik Discovery" log-prefix=\
    "Mikrotik Discovery erlauben" port=5678 protocol=udp src-address=\
    192.168.96.0/20
add action=accept chain=forward log-prefix="Mikrotik Discovery erlauben" \
    port=5678 protocol=udp src-address=192.168.112.0/20
add action=accept chain=forward dst-address=192.168.96.0/20 log-prefix=\
add action=accept chain=forward log-prefix="Mikrotik Diskover all" port=5678 \
    protocol=udp
# ovpn-DirksPC not ready
add action=accept chain=forward comment="OVPN darf alles" in-interface=\
    ovpn-DirksPC log-prefix="OVPN Darf alles" src-address=192.168.201.0/24
add action=accept chain=forward in-interface=ovpn-DirksLT log-prefix=\
# ovpn-Ralf not ready
add action=accept chain=forward in-interface=ovpn-Ralf log-prefix=\
# ovpn-Florian not ready
add action=accept chain=forward in-interface=ovpn-Florian log-prefix=\
    "OVPN Darf alles" src-address=192.168.202.0/24
add action=accept chain=forward comment="Ins OVPN_Netz erlauben" dst-address=\
    192.168.201.0/24 log-prefix="Ins OVPN-Netz"
    192.168.202.0/24 log-prefix="Ins OVPN-Netz"
add action=drop chain=input comment="Grund: Drop Input invalid" \
add action=accept chain=input comment="Grund: Acc ICMP" protocol=icmp
add action=accept chain=input comment="Grund: Acc loopback (z.B. CAPsMAN)" \
    dst-address=127.0.0.1
add action=drop chain=input comment="Grund: Drop alles nicht im LAN" \
    disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="Grund: Acc ipsec-in" ipsec-policy=\
    in,ipsec
add action=accept chain=forward comment="Grund: Acc ipsec-out" ipsec-policy=\
    out,ipsec
add action=accept chain=forward connection-nat-state=srcnat,dstnat log=yes \
    log-prefix="NAT erlauben"
    "Grund: Drop WAN von aussen ohne Anfrage innen" connection-nat-state=\
    !dstnat connection-state=new in-interface=E1_Internet
    "Alles was nicht erlaubt ist ist verboten" log=yes log-prefix=\
    "Nicht erlaubt"
/ip firewall mangle
add action=log chain=prerouting log-prefix="Test Backroute" protocol=icmp \
add action=log chain=postrouting log=yes log-prefix="Test Backroute" \
    protocol=icmp src-address=192.168.120.205
add action=log chain=prerouting dst-address=192.168.100.14 log=yes \
    log-prefix="Test OldIP" protocol=icmp
add action=log chain=postrouting dst-address=192.168.100.14 log=yes \
    log-prefix="Test OrgIP" protocol=icmp
add action=log chain=postrouting dst-address=192.168.120.205 log=yes \
    log-prefix="Test DestIP" protocol=icmp
add action=mark-packet chain=prerouting disabled=yes dst-address=\
    192.168.112.0/20 log-prefix=Test new-packet-mark=Technik \
    passthrough=yes
add action=mark-packet chain=prerouting disabled=yes new-packet-mark=\
    Technik passthrough=yes src-address=192.168.112.0/20
    192.168.128.0/20 new-packet-mark=Gaeste passthrough=yes
add action=mark-packet chain=prerouting disabled=yes new-packet-mark=Gaeste \
    passthrough=yes src-address=192.168.128.0/20
add action=masquerade chain=srcnat comment="Masq nach aussen" ipsec-policy=\
    out,none log-prefix=Internet out-interface=E1_Internet
add action=dst-nat chain=dstnat comment=BeamPC dst-address=192.168.100.201 \
    to-addresses=192.168.120.150
add action=dst-nat chain=dstnat comment=\
    "Geraete ins Techniknetz: NAS, Drucker" dst-address=192.168.120.200 \
    to-addresses=192.168.100.100
add action=dst-nat chain=dstnat dst-address=192.168.120.110 to-addresses=\
    192.168.100.110
add action=dst-nat chain=dstnat dst-address=192.168.120.111 to-addresses=\
    192.168.100.111
add action=src-nat chain=srcnat comment="Road Warrior" src-address=\
    192.168.201.0/24 to-addresses=192.168.100.3
add action=src-nat chain=srcnat comment="Road Warrior Technik" src-address=\
    192.168.202.0/24 to-addresses=192.168.200.3
add distance=1 gateway=192.168.64.1
add distance=1 dst-address=10.10.1.0/24 gateway=192.168.100.21
add distance=1 dst-address=192.168.1.0/24 gateway=192.168.100.20
add distance=1 dst-address=192.168.88.0/24 gateway=192.168.100.20
/ppp secret
add name=DirkLT profile=RoadWarrior
add name=Florian profile=RoadWarriorTechnik service=ovpn
add name=DirkPC profile=RoadWarrior
add name=Ralf profile=RoadWarrior
add name=David profile=RoadWarriorTechnik service=ovpn
add name=Benjamin profile=RoadWarriorTechnik service=ovpn
/radius
add address=192.168.100.1 service=hotspot,wireless
/radius incoming
set accept=yes
/routing pim bsr-candidates
add disabled=yes interface=vlan200_Technik
/routing pim interface
add alternative-subnets=192.168.112.0/20,192.168.96.0/20,192.168.128.0/19 \
/routing pim rp
/system clock
/system identity
set name=Router_Serverschrank_All
/system leds
add interface=wlan2G leds="wlan2G_signal1-led,wlan2G_signal2-led,wlan2G_signal\
    3-led,wlan2G_signal4-led,wlan2G_signal5-led" type=\
    wireless-signal-strength
add interface=wlan2G leds=wlan2G_tx-led type=interface-transmit
add interface=wlan2G leds=wlan2G_rx-led type=interface-receive
/system logging
add disabled=yes topics=debug,!ntp
/system ntp client
set enabled=yes primary-ntp=192.53.103.108 secondary-ntp=192.53.103.104 \
    server-dns-names=192.168.100.1
/tool graphing interface
add allow-address=192.168.96.0/20
add allow-address=192.168.112.0/20
add allow-address=192.168.100.0/24
/tool graphing queue
/tool graphing resource
I can't help myself, maybe I see nothing because I am to close to it,
Good night,
Dirk
k6ccc
Re: Access to Router in LAN2
Wed Jul 07, 2021 6:04 pm
Can you provide a drawing of how all this is hooked up?
dzo
Thu Jul 08, 2021 10:29 pm
Here is my plan, I hope you can see what you wanted - I never learned drawing network-plans...
The point is, I want to see the devices, mainly the Routerboard from my PC when they are connected to the rest of the network.
AND I think, I have one point not understood from masquerading so this behavior happends.
k6ccc
Thu Jul 08, 2021 11:30 pm
Please tell me that all the various routers EXCEPT the RB4011 are only being used as managed switches and not routers.
Unless I am badly missing something, if you are doing ANY routing function in the rest of the routers, you are only making your life more complex.
And I can't help you much on the configuration of routers being used only as a managed switch - as I don't do that anywhere. Routers are used as routers and switches are used as switches.
dzo
Sat Jul 10, 2021 5:11 pm
Of course, they are only used as managed switches, no routing on them.
Most of them as WLAN-APs, managed by CAPsMAN in RB4011, and dividing the VLANs for the ports. Mostly just one route:
/ip route print
 0 ADC  192.168.96.0/20    192.168.100.12  vlan100                   0
because of their IP-Address.
And because the RB2011 was not in use, I put it to my place so I can use his display to see what happenings on his ports. Sometimes I change the port my PC uses so I can put him into different VLANs.
But I wonder:
I can Ping the Mobile-Part-Router with IP 192.168.120.205 from RB4011, and I can connect him from my PC if I plug my PC in VLAN200 (RB2011 as managed Switch, just a Port who sends Packets from VLAN200 without VLAN-Tag, and gives incoming Packets the VLAN-Tag of VLAN200).
And I can get a connection to "Mischer" with IP192.168.120.100 via Dst-Nat
;;; Mischer im Hauptnetz
chain=dstnat action=dst-nat to-addresses=192.168.120.100 dst-address=192.168.100.200 log=no log-prefix=""
But I get no connection via Nat-Roules in RB4011, as shown in the first Topic.
dzo
Mon Jul 19, 2021 1:38 pm
The problem is, if you want to use CAPsMAN for the APs, you mostly need to buy mikrotik-routers as all wireless solutions of mikrotik are shipped with routerOS, see Mikrotiks product pages (Wireless for home and office or Wireless systems - just the licence level differs (only very rare devices).
The switches with WLAN are more expensive (Switches with WLAN) and on the product page is written: Operating System: RouterOS L5.
I use e.g. RBD52G-5HacD2HnD as an AP and a small switch. Vlan functionality is build within the bridge - all ports are bridged with vlan (tagged/untagged outgoing as needed, incoming all ports tagged), no firewall or anything else on these routers.
Users browsing this forum: GoogleOther [Bot] and 39 guests
