done411
QOS - Queue Tree (prioritization)
Wed Jul 07, 2021 4:01 pm
i am having some issued regarding QOS on several vlans.
My ISP is providing 500/150 and my idea was to balance the bandwith between 3 vlans.
vlan10 - Private vlan (should have unlimited bandwith and highest priority, in case guests are using 400 i would like to take bandwith from them if i need it) or do i need to set a Max Limit for my private vlan?
vlan20 - Guest vlan (should be on PCQ0 and limited to max 400/100
vlan 30 - TV vlan (should be on PCQ0 and limited to max 100/20
I dont want to use pcq 0 on private network due to a lot of different hubs for smart home which are using very low bandwith. (could i keep on "default small"?)
Does my priotiry and queue type for my private network make sense ? (screenshot attached)
Thanks for your help!
StubArea51
Trainer
Trainer
Re: QOS - Queue Tree (prioritization)
Wed Jul 07, 2021 4:03 pm
Start here :)
Most likely the example config you're looking for and answer is in this thread:
viewtopic.php?f=23&t=73214
done411
Wed Jul 07, 2021 9:19 pm
Thanks!
Will give it a try :)
Users browsing this forum: jookraw and 47 guests
