lthasenhod
help: from Cisco to Mikrotik (vrf lite, vlan, vlan interface, lag)
Tue Jul 20, 2021 5:51 pm
Hi All,
I come from the world of Cisco and the likes, and now bought a MikroTik CRS317-1G-16S+, and so far i like how "Linux" it feels, but some of the functionality i cant quite wrap my head around, i want to make it a layer3 switch with some VRFs, VLANs and Bonds.
like:
vrf management
rd 10:10
route 0.0.0.0 0.0.0.0 192.168.1.254
vlan 10
name management
interface vlan 10
ip address 192.168.1.1 255.255.255.0
vrf management
and this "vlan interface" should also be the ip i manage the device on, if anyone is able to point me in the right direction i would be happy, also make use hardware offload switch chip as much as possible.
Kind Regards,
Lars Christian Thasenhod
lthasenhod
Re: help: from Cisco to Mikrotik (vrf lite, vlan, vlan interface, lag)
Sat Jul 24, 2021 9:34 pm
Here is my relevant Cisco Config:
ip vrf management
rd 100:100
ip vrf inside
rd 110:110
ip vrf guest
rd 200:200
ip vrf dmz
rd 250:250
ip vrf storage
rd 500:500
ip vrf vmotion
rd 600:600
vlan 100
name management
vlan 110
name server
vlan 120
name client
vlan 200
name guest
vlan 250
name client
vlan 500
name storage
vlan 600
name vmotion
vlan 998
name storage
interface vlan 100
ip address 172.22.100.1 255.255.255.0
ip vrf forwarding management
interface vlan 110
ip address 172.22.110.1 255.255.255.0
ip vrf forwarding inside
interface vlan 120
ip address 172.22.120.1 255.255.255.0
interface vlan 200
ip address 172.22.200.1 255.255.255.0
ip vrf forwarding guest
interface vlan 250
ip address 172.22.250.1 255.255.255.0
ip vrf forwarding dmz
interface vlan 500
ip address 172.22.50.1 255.255.255.0
ip vrf forwarding storage
interface vlan 600
ip address 172.22.60.1 255.255.255.0
ip vrf forwarding vmotion
interface vlan 998
interface port-channel10
switchport mode access
switchport access vlan 500
spanning-tree portfast
interface port-channel20
interface ethernet1
channel-group 10 mode active
speed 10000
interface ethernet2
speed 10000
interface ethernet3
channel-group 20 mode active
speed 2500
interface ethernet4
speed 2500
interface ethernet5
switchport mode trunk
switchport trunk vlan allowed 100,110,120,200,250,500,600,998
speed 10000
interface ethernet6
speed 10000
interface ethernet7
shutdown
interface ethernet8
shutdown
interface ethernet9
speed 10000
interface ethernet10
speed 10000
interface ethernet11
shutdown
interface ethernet12
shutdown
interface ethernet13
shutdown
interface ethernet14
shutdown
interface ethernet15
shutdown
interface ethernet16
switchport access vlan 120
speed 10000
interface mgmt0
ip route 0.0.0.0 0.0.0.0 null
ip route vrf management 0.0.0.0 0.0.0.0 172.22.100.4
ip route vrf inside 0.0.0.0 0.0.0.0 172.22.255.4
ip route vrf guest 0.0.0.0 0.0.0.0 172.22.200.4
ip route vrf dmz 0.0.0.0 0.0.0.0 172.22.250.4
ip route vrf storage 0.0.0.0 0.0.0.0 null
ip route vrf vmotion 0.0.0.0 0.0.0.0 null
Kind Regards,
DarkNate
Sat Jul 24, 2021 10:01 pm
lthasenhod
Sat Jul 24, 2021 10:11 pm
Here is my MicroTik configuration so far, all input is appreciated.
add name=bridge-dmz vlan-filtering=yes
add name=bridge-guest vlan-filtering=yes
add name=bridge-inside vlan-filtering=yes
add name=bridge-management vlan-filtering=yes
add name=bridge-storage vlan-filtering=yes
add name=bridge-vmotion vlan-filtering=yes
set [ find default-name=sfp-sfpplus1 ] name=ethernet1
set [ find default-name=sfp-sfpplus2 ] name=ethernet2
set [ find default-name=sfp-sfpplus3 ] name=ethernet3
set [ find default-name=sfp-sfpplus4 ] name=ethernet4
set [ find default-name=sfp-sfpplus5 ] name=ethernet5
set [ find default-name=sfp-sfpplus6 ] name=ethernet6
set [ find default-name=sfp-sfpplus7 ] name=ethernet7
set [ find default-name=sfp-sfpplus8 ] name=ethernet8
set [ find default-name=sfp-sfpplus9 ] name=ethernet9
set [ find default-name=sfp-sfpplus10 ] name=ethernet10
set [ find default-name=sfp-sfpplus11 ] name=ethernet11
set [ find default-name=sfp-sfpplus12 ] name=ethernet12
set [ find default-name=sfp-sfpplus13 ] name=ethernet13
set [ find default-name=sfp-sfpplus14 ] name=ethernet14
set [ find default-name=sfp-sfpplus15 ] name=ethernet15
set [ find default-name=sfp-sfpplus16 ] name=ethernet16
set [ find default-name=ether1 ] name=mgmt0
/interface vlan
add name=vlan-client vlan-id=120
add name=vlan-dmz vlan-id=250
add name=vlan-guest vlan-id=200
add name=vlan-management vlan-id=100
add name=vlan-server vlan-id=110
add name=vlan-storage vlan-id=500
add name=vlan-transit vlan-id=998
add name=vlan-vmotion vlan-id=600
/interface bonding
add mode=802.3ad name=port-channel10 slaves=ethernet1,ethernet2 transmit-hash-policy=layer-2-and-3
add mode=802.3ad name=port-channel20 slaves=ethernet3,ethernet4 transmit-hash-policy=layer-2-and-3
add interface=port-channel10 pvid=500
add interface=port-channel20 pvid=110
add interface=mgmt0
add interface=ethernet5
add interface=ethernet6
add interface=ethernet7
add interface=ethernet8
add interface=ethernet9
add interface=ethernet10
add interface=ethernet11
add interface=ethernet12
add interface=ethernet13
add interface=ethernet14
add interface=ethernet15
add interface=ethernet16 pvid=120
/interface bridge vlan
add bridge=bridge-management tagged=bridge-management,mgmt0,ethernet5,ethernet6,ethernet9,ethernet10 vlan-ids=100
add bridge=bridge-inside tagged=bridge-inside,mgmt0,ethernet5,ethernet6,ethernet9,ethernet10 untagged=port-channel20 \
vlan-ids=110
add bridge=bridge-inside tagged=bridge-inside,mgmt0,ethernet5,ethernet6,ethernet9,ethernet10 untagged=ethernet16 vlan-ids=\
120
add bridge=bridge-guest tagged=bridge-guest,mgmt0,ethernet5,ethernet6,ethernet9,ethernet10 vlan-ids=200
add bridge=bridge-dmz tagged=bridge-dmz,mgmt0,ethernet5,ethernet6,ethernet9,ethernet10 vlan-ids=250
add bridge=bridge-storage tagged=bridge-storage,mgmt0,ethernet5,ethernet6,ethernet9,ethernet10 untagged=port-channel10 \
vlan-ids=500
add bridge=bridge-vmotion tagged=bridge-vmotion,mgmt0,ethernet5,ethernet6,ethernet9,ethernet10 vlan-ids=600
add bridge=bridge-inside tagged=bridge-inside,mgmt0,ethernet5,ethernet6,ethernet9,ethernet10 vlan-ids=998
add address=172.22.100.3/24 interface=vlan-management network=172.22.100.0
add address=172.22.110.1/24 interface=vlan-server network=172.22.110.0
add address=172.22.120.1/24 interface=vlan-client network=172.22.120.0
add address=172.22.200.1/24 interface=vlan-guest network=172.22.200.0
add address=172.22.250.1/24 interface=vlan-dmz network=172.22.250.0
add address=172.22.255.2/24 interface=vlan-transit network=172.22.255.0
add address=172.22.50.1/24 interface=vlan-storage network=172.22.50.0
add address=172.22.60.1/24 interface=vlan-vmotion network=172.22.60.0
add distance=1 gateway=172.22.100.4 routing-mark=vrf-management
add distance=1 gateway=172.22.255.4 routing-mark=vrf-inside
add distance=1 gateway=172.22.200.4 routing-mark=vrf-guest
add distance=1 gateway=172.22.250.4 routing-mark=vrf-dmz
/ip route vrf
add interfaces=bridge-management route-distinguisher=100:100 routing-mark=vrf-management
add interfaces=bridge-inside route-distinguisher=110:110 routing-mark=vrf-inside
add interfaces=bridge-guest route-distinguisher=200:200 routing-mark=vrf-guest
add interfaces=bridge-dmz route-distinguisher=250:250 routing-mark=vrf-dmz
add interfaces=bridge-storage route-distinguisher=500:500 routing-mark=vrf-storage
add interfaces=bridge-vmotion route-distinguisher=600:600 routing-mark=vrf-vmotion
Kind Regards,
lthasenhod
Re: help: from Cisco to Mikrotik (vrf lite, vlan, vlan interface, lag)  [SOLVED]
Sat Jul 24, 2021 10:29 pm
Dear All,
Thanks for the suggestions, after talking with Support it seems MikroTik can not do this, and i unfortunatly have to revert to my Cisco 3650X switch.
Kind Regards,
chanchan
Sat Sep 25, 2021 8:23 pm
Any references on this setup. Cisco trunk port going to mikrotik trunk port going to mikrtok. Please help me. Thanks. My setup is on attached file
Users browsing this forum: StokkiesA and 95 guests
