PackElend
what is the shortest masquerade rule possible?
Fri Jul 30, 2021 5:23 pm
Hi there,
this a split-off of NAT: Masquerade can leak private IP, why&how?
Src-IP masqueraded packet is always the IP of the interface, of course, it makes sense and you have to define the IP of an interface otherwise you don't have a route so the routing table is incomplete.
Where else is shall take it from when not defining it:
	add address=xxx.xxx.xxx.xxx/yy interface=....
Assuming that be correct the shortest rule for Source NAT is:
	add chain=srcnat
That would cause the src-IP in a packet flowing in through an interface (could be even a WAN-Interface) to be replaced by the interface's IP.
If the interface has more than one IP it is probably the first IP, isn't it?
rextended
Re: what is the shortest masquerade rule possible?
Fri Jul 30, 2021 5:29 pm
This rule pasted on the terminal
/ip firewall nat add chain=srcnat
add a useless NAT rule.
It has no effect on the packets, because what you want to do with this packets is omitted/missing (action parameter)
then
pass the packets to the next rule on srcnat chain
On CLI is visible this detail because "/ip fire nat export" export how the rule is wroted,
but on WinBox this detail is not viewable because the field "action" can't be omitted, and each time WinBox puts "accept" because is the first value on dropdown list.
see this
viewtopic.php?f=2&t=177229&p=870212
PackElend
Fri Jul 30, 2021 10:22 pm
so the shortest (reasonable) rule is
	add chain=srcnat out-interface=wan
anav
Fri Jul 30, 2021 10:51 pm
Seems incomplete (no action) unless without direction the router provides a default action??
andriys
Sat Jul 31, 2021 10:57 am
Ah, I now see where the rextended's question on "useless NAT rules" came from!
The default NAT action is "accept", so that "shortest rule" will NOT do masquerading. Rather the opposite, it will exempt all traffic from NAT.
PackElend
Sat Jul 31, 2021 11:00 am
"Action", my bad, no idea why I missed that, apparently I was blind in that eye :(.
that is the shortest rule, statement in the OP applies.
PackElend
Sat Jul 31, 2021 11:06 am
thx for this reply, we replied simultaneously so I missed your answer.
Good hint, things like this I'm seeking for, what happens if rules are reduced to a minimum, things are get forgotten, what defaults kick in etc.
rextended
Sat Jul 31, 2021 7:20 pm
Very thanks for notice it! :lol:
Users browsing this forum: No registered users and 65 guests
