gogotha
Rouge DHCP Detection and Alert help
Sun Aug 15, 2021 12:18 am
I am building a default import that our technicians can use on new installs and would like to add a rouge DHCP detection and alert when detected. I tried the code below from the website of a guy that trained me but its appears broken when I import via terminal. I tried to leave a post on his site to ask him but posting replies fail. With the terminal error in image, will this still work?
/ip dhcp-server alert
add disabled=no interface=bridge on-alert=":local sysname [/system identity get name];\r\
    \n/tool e-mail send to=alerts@mydomain.com subject=\"Rouge DHCP Server Detected\" body=\"An unknown DHCP server was\
    \_detected on \$interface of \$sysname with a ip address of \$address\""
Terminal showing error-
Script gets imported-
pe1chl
Re: Rouge DHCP Detection and Alert help
Sun Aug 15, 2021 12:00 pm
There can be problems like this when pasting /export'ed config in a winbox terminal.
Use an external telnet/ssh client instead.
It looks like your script was correctly imported but it is difficult to be sure unless you widen the window so there is no more automatic line wrapping.
And of course: you always should test such things. Connect a second device with DHCP server on the same network and see if it is being detected and your mail is sent correctly.
rextended
Sun Aug 15, 2021 5:39 pm
Except than Rouge on english have another mean (lipstick / from Française rouge for Red), and the right word is "Rogue" (also change on title please)
this is a "fixed" script for do not make appear the "cosmetic" :mrgreen: error on winbox.
add disabled=no interface=bridge on-alert=\
    \n/tool e-mail send to=alerts@mydomain.com subject=\"Rogue DHCP Server Detected\" body=\"An unknown DHCP server was detected \
Users browsing this forum: Ralfu, Snooops and 45 guests
