forsquirel
Hex s + CSS326. Just want a working vlan config!
Mon Aug 23, 2021 5:53 am
First and foremost, I'm brand new to the ecosystem. Also, I know its been asked a million times before and believe me I've read and read till my eyes have crossed. I'm still a bit confused.
I'm in the process of upgrading my home networking equipment to a better level. Right now I have everything up and running with a completely flat topology. Everything is in the same subnet. Unfortunately I'd like to split that up into vlans.
Everything falls into 1 of 3 categories
  • Guests
  • Cameras
  • Everything else
Now I spent 2 weeks just getting everything working with vlans only to find out that once I hooked it up to the internet I could get no traffic.
Can be found here
# aug/23/2021 02:38:54 by RouterOS 6.47.10
# software id =
add admin-mac=2C:C8:1B:17:A5:D7 auto-mac=no name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] name=ether6
/interface vlan
add name=cameras vlan-id=30
add name=guest vlan-id=10
add name=WAN
add name=LAN
/ip dhcp-server option
add code=6 name=LocalDNS value="'192.168.0.13''192.168.0.14'"
/ip hotspot profile
add name=pool_guest ranges=192.168.10.2-192.168.10.14
add name=pool_cameras ranges=192.168.10.17-192.168.10.30
add name=pool_lan ranges=192.168.0.2-192.168.0.125
add address-pool=pool_cameras disabled=no interface=cameras name=dhcp_cameras
add add-arp=yes address-pool=pool_lan disabled=no interface=bridge name=\
    dhcp_lan
add address-pool=pool_guest disabled=no interface=guest name=dhcp_guest
/system logging action
set 1 disk-file-name=flash/log
add bridge=bridge interface=*2
add bridge=bridge interface=*3
add bridge=bridge interface=*4
add bridge=bridge interface=*5
add bridge=bridge interface=*6
/interface bridge vlan
add bridge=bridge tagged=*5 untagged=bridge,*2 vlan-ids=1
add bridge=bridge tagged=*5 untagged=bridge,*2 vlan-ids=10
add bridge=bridge tagged=*5 untagged=bridge,*2 vlan-ids=30
/interface detect-internet
set detect-interface-list=WAN wan-interface-list=WAN
add interface=bridge list=LAN
add list=WAN
add address=192.168.0.1/25 interface=bridge network=192.168.0.0
add address=192.168.10.16/25 interface=cameras network=192.168.10.0
add address=192.168.10.1/25 interface=guest network=192.168.10.0
/ip dhcp-client
add disabled=no
add address=192.168.0.0/25 dhcp-option=LocalDNS dns-server=\
    192.168.0.13,192.168.0.14,192.168.0.15 gateway=192.168.0.1 netmask=25
add address=192.168.10.0/28 gateway=192.168.10.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip service
set telnet disabled=yes
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/system identity
set name=Morehead
/system leds
add leds="" type=interface-activity
/tool mac-server
/tool mac-server mac-winbox
this is roughly my current working config (sanitized a bit)
# aug/22/2021 20:50:57 by RouterOS 6.48.3
# software id = d33d-b33f
# model = RB760iGS
# serial number = 8675309JNY
add admin-mac=xxxxxxxxx auto-mac=no comment=defconf name=bridge
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add code=6 name=HollyDNS value="'192.168.1.1''192.168.1.13''192.168.1.14'"
add code=6 name=EverlyDNS value="'192.168.1.1''192.168.1.14''192.168.1.13'"
add code=6 name=LocalDNS value="'192.168.1.1'"
/ip hotspot profile
add name=dhcp ranges=192.168.1.100-192.168.1.125
add address-pool=dhcp disabled=no interface=bridge name=dhcp_lan
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.1.1/25 interface=bridge network=192.168.1.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.1.0/25 dhcp-option=HollyDNS dns-server=\
    192.168.1.13,192.168.1.14,192.168.1.15 gateway=192.168.1.1 netmask=25
/ip dns static
add address=192.168.1.1 name=router.lan
    invalid
/system clock
set time-zone-name=America/California
/system identity
set name=Morehead
/system ntp client
set enabled=yes primary-ntp=192.168.1.16
/tool mac-server
All I'm looking for is to get 1 port, ether5, to connect to the switch to route traffic as needed. I had all this done in a OpenWRT setup just prior to switching over.
Can I do this with the hEX s or would the hEX PoE be a better choice? or something like the RB2011? I just need some segregation on the lan.
thanks,
edit: Solved. Managed to get a working setup through a trunk between the two.
Users browsing this forum: Bing [Bot] and 84 guests
