mindaugasstun
Why I have no internet with static WAN option
Mon Aug 23, 2021 3:56 pm
When I choosing Dynamic IP, on WAN / Quick set menu - internet working fine.
If choosing Static WAN - with the same ip/mask/gw/dns entries - no internet.
Why?
loloski
Re: Why I have no internet with static WAN option
Mon Aug 23, 2021 4:50 pm
Without seeing the config, i can only guess that natting/masquerade rules is not present when you don't use the quickset function, can you ping outside your network in the mikrotik terminal if you don't do configure your router using quickset feature?
anav
Mon Aug 23, 2021 7:42 pm
Dont use quickset, reset to default and start again.
sutrus
Tue Aug 24, 2021 11:58 am
Without DHCP client it is necessary to set the routes.
Users browsing this forum: lubara, raiser and 55 guests
