vester11
Can't access IP camera from Internet
Wed Aug 25, 2021 11:16 am
Hi everyone
I have connected IP camera in my local network and every think working fine.But I can"t access from internet(outside). I try meny tutorials how forward ports but not one of them working.My main router is RB450Gx4. I have static IP. Can enyone help me setup this??
[admin@MikroTik] > export hide-sensitive
# aug/25/2021 09:02:38 by RouterOS 6.47.9
# software id = 5V87-V0VA
# model = RB450Gx4
# serial number = B8D00BDDF2C5
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 use-peer-dns=yes user=exdxhm6@integra
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.200-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge lease-time=1d name=defconf
/system logging action
set 3 remote=192.168.1.10
/user group
add name=ftp policy=ftp,read,!local,!telnet,!ssh,!reboot,!write,!policy,!test,!winbox,!password,!web,!sniff,!sensitive,!api,!romon,!dude,!tikapp
set discover-interface-list=none
add address=192.168.1.1/24 comment=defconf interface=ether2 network=192.168.1.0
/ip arp
add address=192.168.1.2 comment=openwrt_tp-link interface=bridge mac-address=XX:XX:XX:XX:XX:XX
add address=192.168.1.3 comment=Q300_1 interface=bridge mac-address=XX:XX:XX:XX:XX:XX
add address=192.168.1.4 comment=Q300_2 interface=bridge mac-address=XX:XX:XX:XX:XX:XX
add address=192.168.1.10 comment=omv interface=bridge mac-address=XX:XX:XX:XX:XX:XX
add address=192.168.1.5 comment=TP-Link interface=bridge mac-address=XX:XX:XX:XX:XX:XX
add address=192.168.1.6 comment=toto_1 interface=bridge mac-address=XX:XX:XX:XX:XX:XX
add address=192.168.1.7 comment=toto_2 interface=bridge mac-address=XX:XX:XX:XX:XX:XX
add address=192.168.1.98 comment=kamerka interface=bridge mac-address=XX:XX:XX:XX:XX:XX
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.1.10 comment=omv mac-address=XX:XX:XX:XX:XX:XX server=defconf
add address=192.168.1.50 comment=PS4 mac-address=XX:XX:XX:XX:XX:XX server=defconf
add address=192.168.1.52 client-id=1:XX:XX:XX:XX:XX:XX comment=LGwebOSTV mac-address=XX:XX:XX:XX:XX:XX server=defconf
add address=192.168.1.51 client-id=1:XX:XX:XX:XX:XX:XX comment=sylwek-MS-7A71 mac-address=XX:XX:XX:XX:XX:XX server=defconf
add address=192.168.1.56 client-id=1:XX:XX:XX:XX:XX:XX comment="DIXONS-JVC TV" mac-address=XX:XX:XX:XX:XX:XX server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=1.1.1.1,1.0.0.1,8.8.8.8,8.8.4.4 gateway=192.168.1.1 netmask=24
set servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward connection-nat-state=dstnat
add action=dst-nat chain=dstnat dst-port=51413 protocol=tcp to-addresses=192.168.1.10 to-ports=51413
add action=dst-nat chain=dstnat dst-port=51413 protocol=udp to-addresses=192.168.1.10 to-ports=51413
/ip service
set telnet disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Warsaw
/system logging
add action=remote topics=error
add action=remote topics=info
add action=remote topics=warning
/system ntp client
set enabled=yes primary-ntp=159.253.242.123 secondary-ntp=162.159.200.123
/system package update
set channel=long-term
/system scheduler
add interval=1h name=schedulerUpdateHoleCertDomains on-event=scriptUpdateHoleCertDomains policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=mar/23/2020 start-time=00:55:00
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
anav
Re: Can't access IP camera from Internet
Wed Aug 25, 2021 4:03 pm
The ip address should relfect interface bridge
Are you trying to access the IP camera from behind the router (in which case you will need hairpin nat) if its simply from external locations,
then the right combination of firewall rules and dstnat should work.
/ip firewall nat (MODIFY CONFIG)
add action=dst-nat chain=dstnat dst-port=51413 protocol=tcp to-addresses=192.168.1.10 to-ports=51413 in-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=51413 protocol=udp to-addresses=192.168.1.10 to-ports=51413 in-interface-list=WAN
vester11
Wed Aug 25, 2021 8:46 pm
Thanks for answer
Yes, I trying to access the IP camera from my phone (mobile network LTE). I using for that my public Ip (static) my_public_ip:port
These two rules are not for my IP camera. it's for my bittorrent client.
So I need add two new rules. My camera have local IP adress 192.168.1.98:4321 So the rules should be like this?
add action=dst-nat chain=dstnat dst-port=4321 protocol=tcp to-addresses=192.168.1.98 to-ports=4321 in-interface-list=WAN
add action=dst-nat chain=dstnat dst-port=4321 protocol=udp to-addresses=192.168.1.98 to-ports=4321 in-interface-list=WAN
anav
Wed Aug 25, 2021 9:08 pm
yes that is correct.
The problem is anybody in the world can also view your IP camera!!
If you have it password protected that can be hacked very quickly.
Access should only be via https or FTPs or some sort of encrypted means.
vester11
Wed Aug 25, 2021 9:22 pm
I try that rules but still not working.
anav
Wed Aug 25, 2021 11:41 pm
Please repost your latest config......
vester11
Thu Aug 26, 2021 10:38 am
Here you have my last config:
# aug/26/2021 09:27:48 by RouterOS 6.47.9
# model = RB450Gx4
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
/user group
add name=ftp policy="ftp,read,!local,!telnet,!ssh,!reboot,!write,!policy,!test\
    ,!winbox,!password,!web,!sniff,!sensitive,!api,!romon,!dude,!tikapp"
add address=192.168.1.1/24 comment=defconf interface=ether2 network=\
    192.168.1.0
/ip arp
add address=192.168.1.2 comment=openwrt_tp-link interface=bridge mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.1.3 comment=Q300_1 interface=bridge mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.1.4 comment=Q300_2 interface=bridge mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.1.10 comment=omv interface=bridge mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.1.5 comment=TP-Link interface=bridge mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.1.6 comment=toto_1 interface=bridge mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.1.7 comment=toto_2 interface=bridge mac-address=\
    XX:XX:XX:XX:XX:XX
add address=192.168.1.98 comment=kamerka interface=bridge mac-address=\
    XX:XX:XX:XX:XX:XX
/ip cloud
set update-time=no
/ip dhcp-client
add address=192.168.1.10 comment=omv mac-address=XX:XX:XX:XX:XX:XX server=\
    defconf
add address=192.168.1.50 comment=PS4 mac-address=XX:XX:XX:XX:XX:XX server=\
    defconf
add address=192.168.1.52 client-id=1:XX:XX:XX:XX:XX:XX comment=LGwebOSTV \
add address=192.168.1.51 client-id=1:XX:XX:XX:XX:XX:XX comment=sylwek-MS-7A71 \
add address=192.168.1.56 client-id=1:XX:XX:XX:XX:XX:XX comment=\
add address=192.168.1.0/24 comment=defconf dns-server=\
/ip dns static
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat dst-port=51413 protocol=tcp to-addresses=\
add action=dst-nat chain=dstnat dst-port=51413 protocol=udp to-addresses=\
add action=dst-nat chain=dstnat dst-port=4321 in-interface-list=WAN protocol=\
/ip service
/system clock
/system logging
/system ntp client
/system scheduler
add interval=1h name=schedulerUpdateHoleCertDomains on-event=\
    scriptUpdateHoleCertDomains policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
set enabled=no
/tool mac-server
I can say only when I try to access camera from outside my_public_ip:4321 i get time out. Then I go to IP>Firewal>NAT and first rule tcp are receiving some packages . udp rule nothing.
anav
Thu Aug 26, 2021 2:11 pm
You have not made the corrections yet ?????????????
(1) The interface is wrong here, it should be bridge
192.168.1.0
(2) Not that it will likely make a difference but suggest change NONE to LAN.
The two rules for port forwarding for bitorrent also require in-interface-list=WAN
but other than the above I dont see anything wrong with the config.
Suggest you look at the PC that your server is on and suggest maybe a firewall blocking traffic
or the software of the device has a feature that blocks traffic????
If you access the IP camera from the LAN directly via the LANIIP address, can you access the feed??
vester11
Thu Aug 26, 2021 4:08 pm
192.168.1.0
Oh Sorry. Now all changes is done.
Sorry but I don't understand, my English isn't very good.
Yes you have right configuration RB450x4 is fine. I install IP Webcam app on second phone (LANIP 192.168.1.205:12345) and after add new rules I can login via my_local_ip:12345.
It's something wrong with my network configuration. Can You help with this????
My network diagram
download/file.php?mode=view&id=48277
anav
Thu Aug 26, 2021 5:42 pm
Okay now I am very confused by your diagram.
What are you trying to do ???
I thought you were using your cell phone to connect to your router on the internet and then accessing an IP camera on your home network.
cellphone -----> DATA -----> Cellphone company-------> Internet --------> ISP modem ----------> Your router---------> LAN subnet ------> IP camera
Is this the process??
Now you are introducing a whole hockey sock of other wifi devices not mentioned.......................... of course nothing works if you dont tell the WHOLE truth. :-)
vester11
Thu Aug 26, 2021 9:55 pm
And You have right. I'm using two cell phones.
One of them for login from outside. cellphone -----> DATA -----> Cellphone company-------> Internet --------> ISP modem ----------> Your router---------> LAN subnet ------> IP camera
and this not working.
So I install IP Webcam app (your phone is working like a IP Camera) on second cell phone connected via wifi to TP-link TL-WR841N/ND (add new rules to RB450x4
add action=dst-nat chain=dstnat dst-port=12345 in-interface-list=WAN protocol=tcp to-addresses=192.168.1.205 to-ports=12345
add action=dst-nat chain=dstnat dst-port=12345 in-interface-list=WAN protocol=udp to-addresses=192.168.1.205 to-ports=12345
) for just make sure rules really don't work and after I try access from first phone by mobile network to second phone( this one with IP Webcam)and I get access. So I knew that rules a good. like you say.
I don't see anything wrong with the config
So I go to my neighbor, connect cell phone (this one with IP Webcam) via wifi to his router TP-link TD-W9970 and I still have access from outside via mobile network but don't have access to IP camera.
Then connect cell phone (this one with IP Webcam) via wifi to Toto link N151RT (this one in workshop) and again I have access from outside but don't have access to IP camera
So I think the problem must be with camera configuration. So I reset to factory default , configured again. And check configuration RB450x4 again. And I find in IP>ARP. I have address reservation for IP camera with wrong mac address so i disabled. After that every think working fine. I get access from outside to ip camera. But now I don't knew what was problem bad camera configuration or wrong mac address :D
I hope you understand anything I wrote :lol:
Sorry. My English is poor :lol: :lol: :lol:
And almost forgot ,Thank You Very Much for Your Help.
Users browsing this forum: unhuzpt and 118 guests
