ITmedigateio
Using a MikroTik Router to manage downport MikroTik Switches
Sun Sep 05, 2021 8:16 am
Hello, i recently started working for a company that has a MikroTik router and a few MikroTik switches, and I was wondering if it's possible to manage the switches (assign vlans and the sorts) from the router interface giving me a one-stop-shop for network management.
I've worked with other routers in the past that had this ability, and I could not find any material on this in the documentation for this router.
thanks and have a great day!
anav
Re: Using a MikroTik Router to manage downport MikroTik Switches
Tue Sep 07, 2021 3:55 pm
Not that I am aware of, a function called capsman is for controlling several APs but nothing for switches.
One can see all their devices on a network through winbox.
I am sure there are others here who have mulitiple switches and have sorted away to manage them efficiently hopefully one will stop by with some sage advice.
Rian
Tue Sep 07, 2021 4:08 pm
Just to extend the whole thing here mentally...
Figuratively speaking, and if the devices fit, this would probably be the right one for your purposes (note the limits): https://help.mikrotik.com/docs/display/ ... t+Extender
k6ccc
Tue Sep 07, 2021 6:05 pm
Does not apply to SwitchOS devices.
ITmedigateio
Thu Sep 09, 2021 8:00 am
when you say "see" you mean just find them on the network and display their details, not manage.
if that's the case I don't see a reason to keep this old router, and not upgrade to something a bit more robust.
mkx
Thu Sep 09, 2021 9:14 am
If ability to manage downstream switches from "master router" is vital to you, then yes, you'll have to switch network gear vendor. Be prepared for "enhanced" gear prices.
mada3k
Long time Member
Long time Member
Fri Sep 10, 2021 7:03 pm
If you are talking about stacking or virtual chassis - then no. There is no such concept in RouterOS. However, CRS3xx has some EEE 802.1br support.
Users browsing this forum: CGGXANNX, VMX and 80 guests
