CrazyFin
Port forward setup wrong OR I might have a NATed IP address from my mobile broadband provider (Telia)? [SOLVED]
Thu Sep 09, 2021 4:54 pm
I recently bought the really nice Mikrotik Chateau LTE12.
I am using it with mobile broadband from Swedish operator Telia and my speed is excellent (150Mbit/s down and about 100Mbit/s up) so that part works just fine.
However, I am not able to access my surveillance cameras or my fileserver from outside my local lan.
I can access my router locally via webpage as well as via Winbox.
I am not able to access my router externally from outside my local net when using Winbox.
I am suspecting 2 issues:
1. I have a public IP address from my ISP that is NATed (most likely)
(I just realized that my "Public" IP when using for example whatismyip.org is for example 217.213.yyy.xx and when I look in the router interface for the modem I see an IP-address that is completely different: 100.99.yyyy.xxx?!)
2. I have done wrong when configuring port forward. I used the quick config page to "open" / port forward port 6601 to my local IP address.
However, I am not able to access the fileserver and I get "Connection timed out".
My config below. I used the command
export hide-sensitive file=mikrotik
but it shows for example MAC-addresses which I thought it would hide?
# sep/09/2021 15:45:10 by RouterOS 7.0.2
# software id = PJ8R-F8ZN
# model = D53G-5HacD2HnD
# serial number = <I have removed the serial no>
add admin-mac=2C:C8:1B:9B:35:C2 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=sweden disabled=no distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid=MikroTik-9B35C7 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX country=sweden disabled=no distance=indoors frequency=\
    auto installation=indoor mode=ap-bridge ssid=MikroTik-9B35C8 \
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=public
add apn=static.telenor.se
add apn=services.telenor.se
add apn=internet.telenor.se
add apn=public.telenor.se
add apn=online.telia.se name=Telia
/interface lte
set [ find ] allow-roaming=no apn-profiles=Telia name=lte1
add name=dhcp ranges=192.168.10.10-192.168.10.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
/interface detect-internet
set detect-interface-list=all
add comment=defconf interface=lte1 list=WAN
add address=192.168.10.1/24 comment=defconf interface=bridge network=\
    192.168.10.0
/ip arp
add address=192.168.10.99 interface=bridge mac-address=68:05:CA:36:94:FF
add address=192.168.10.0/24 comment=defconf dns-server=192.168.10.1 gateway=\
    192.168.10.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.10.1 comment=defconf name=router.lan
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
add action=dst-nat chain=dstnat comment=FILESERVER dst-address=192.168.10.99 \
    dst-port=6601 protocol=tcp to-addresses=192.168.10.99 to-ports=6601
/ip service
set www-ssl disabled=no
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Stockholm
/system identity
set name="CrazyFin Router"
/system routerboard settings
set cpu-frequency=auto
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
CASE CLOSED!
It was my ISP Telia that had configured it wrong.... After 3 calls to tech support at Telia that took me the whole day the 3rd person at their 2nd line tech support finally configured it right!
It works fine now and I can access my fileserver from outside of my local network.
anav
Re: Port forward setup wrong OR I might have a NATed IP address from my mobile broadband provider (Telia)?
Fri Sep 10, 2021 5:42 pm
Good work!
Typically selecting what is my IP is a good way to see if it matches your WANIP in IP DHCP client etc.
Also one can look at their IP cloud settings as well!!
Users browsing this forum: Bing [Bot], derolf and 24 guests
