TengNding
Need help on rb750gr3 about maximum lan connection
Fri Sep 17, 2021 7:32 pm
Hi, i need help regarding my network. I have 10 wireless router connected to my rb750gr3. They are connected using dhcp via bridge through eth4, one of them is using pppoe with a 20Mbps queue. all my wireless routers are connected to my 24 port switch and my 24 port switch is connected to my rb750gr3. All the wireless routers has 20Mpbs download and upload bandwidth management. My ISP internet speed is 400Mbps.
The problem is the internet is getting laggy and sometimes online games are getting server connection error. When you browse a website, sometimes it wont load and nothing comes up, I need to refresh it for it to appear. Just like when I browse websites that has videos like for example youtube. The videos just keep loading and it needed to refresh the browser to play the videos. When I add another wireless router, the problem gets worse. But there are no problems when there are only few routers connected like 6 or below. I believe there's a packet drop happening? May I ask how many local area connections can this router handle? Or is it because there are some things I need to configure in the settings?
ConnyMercier
Forum Veteran
Forum Veteran
Re: Need help on rb750gr3 about maximum lan connection
Fri Sep 17, 2021 9:49 pm
The Mikrotik RB750gr3 is quite powerfull and should have a no problem handling 400Mbits.
Could you send us the Config-Export (export hide-sensitive) of the Mikrotik Router ?
mkx
Fri Sep 17, 2021 10:03 pm
OP started two identical threads, this is the other one: viewtopic.php?f=2&t=178631
Let's continue thrre, shall we?
ConnyMercier
Forum Veteran
Forum Veteran
Fri Sep 17, 2021 10:05 pm
Yop !
TengNding
Sat Sep 18, 2021 11:16 am
Noted sir, will continue on the other thread. Thank you and sorry about that.
Users browsing this forum: 9m2pju, jstaw, phascogale, voytecky and 34 guests
