MUM Europe 2020
traveler
Switch Issues
Fri Aug 24, 2007 10:43 pm
Any one know of a switch that is compatible with the card Atheros 5413 in the Mikrotik router. Currently I have my switches in half dulpex, 10MBs, and auto negotiation disabled. Iwould like to push 100 MBs, auto-negotiation enabled, and full duplex.
changeip
Re: Switch Issues
Fri Aug 24, 2007 10:49 pm
the atheros is a wireless card, what are you talking about ? any 10/100 switch should work out fine, if its not, post what model it is and we'll have a look
traveler
Re: Switch Issues
Fri Aug 24, 2007 11:47 pm
The switch currently in use is a 3COM 3300XM linking an AP to a backbone link . The AP side is up and down unless with any setting but 10MBs,half duplex, auto negotiate disabled.Thx
Equis
Forum Veteran
Forum Veteran
Re: Switch Issues
Sun Aug 26, 2007 8:50 am
Just put a cheap $10 "dumb" switch in.
If that doesn't fix it I think you have another problem.
I would guess your switch can auto-negotiate but is not plug & play (thus when you set to 100 full switch is neg to 100half)
I use HP Procurves at 100 half and it works really well.
Users browsing this forum: Bing [Bot], MSN [Bot] and 36 guests
