MUM Europe 2020
Lollo
Strange DNS behaviour, randomly fails resolving
Sat Sep 01, 2007 7:08 pm
Hi there,
I just started noticing a strange DNS behaviour on my RouterOS box. Let's say that's my network:
PC -> RouterOS 5Ghz CPE ---> Ap --> Bridge ---> PPPoE Server
My PC DNS points to my first hop (RouterOS CPE). RouterOS CPE's DNS points DNS to PPPoE Server Address. PPPoE Server has DNS addresses provided by my ISP.
When I try to resolve certain domain names, it fails and marks them in IP->DNS->Cache with a "N"
If i try to resolve the name directly by using OpenDNS or my ISP DNS, it just works flawlessly. If I just put my ISP DNS in my CPE DNS, it works.
Could it be a bug or something?
Equis
Forum Veteran
Forum Veteran
Re: Strange DNS behaviour, randomly fails resolving
Sun Sep 02, 2007 11:50 am
YES, I can say I have the same bug
DNS works for a few days under high load then stops resolving untill next reboot.
I wonder if it is alot of work to out service watchdog in RouterOS?
Lollo
Sun Sep 02, 2007 12:10 pm
Well, at least I know I'm not the only one experiencing that weird behaviour :(
Should we file a bug?
Equis
Forum Veteran
Forum Veteran
Sun Sep 02, 2007 12:13 pm
I have spoken to MT about it but they could not replecate the problem.
Perhaps if you did a supout and mention that you have spoken to another pwerson with this problem.
I ended up just installing a Bind DNS but would love to just use MT
Equis
Forum Veteran
Forum Veteran
Sun Sep 02, 2007 12:19 pm
One Day I'll get around to testing this with V3, hopefully it may be already fixed :-)
Lollo
Sun Sep 02, 2007 12:31 pm
Eheheh :) Ok, I'll make a support request :)
So you solved by using a separate DNS server (bind)? I think I have to follow your steps too, but that's a real pity, I really would like to see things work just with MT :)
Equis
Forum Veteran
Forum Veteran
Sun Sep 02, 2007 12:42 pm
Yes
I have always had my own Bind dns server but liked having it on the core router.
It mean if power was off for a long time and ups went flat I could run router & radios off 12 volt car Battery and system would still run :-)
omega-00
Mon Sep 03, 2007 5:06 am
Why not just set the clients to use openDNS directly?
Pretty much guaranteed better uptime anyway :-)
Equis
Forum Veteran
Forum Veteran
Mon Sep 03, 2007 5:10 am
For me I like to Cache DNS
But that would be a good option for a secondary.
Lollo
Mon Sep 03, 2007 9:56 am
Well, they're way too slow (200 to 300ms latency) from here :|
Users browsing this forum: ab130kd and 57 guests
