nmbugua
Utorrent
Thu Sep 20, 2007 10:17 am
How can I enable my Mikrotik Router to accept traffic and ports for utorrent? I cant download using utorrent when using mikrotik router. Please help me!!!
mrz
Re: Utorrent
Thu Sep 20, 2007 11:35 am
by default nothing is blocked in firewall. Probably you have created firewall rules that are blocking ports uTorrent is using.
foffa
Re: Utorrent
Thu Sep 20, 2007 2:02 pm
port forwarding is the solution
like normal routers we make a rule to open a port for traffic
now how to do that in mikrotik wee need experts help
they say it is soo easy
but i cant make it at alllllllll
alwayes fail
janisk
Re: Utorrent
Thu Sep 20, 2007 2:06 pm
here you can read how and what you can do with NAT using RouterOS:
http://www.mikrotik.com/testdocs/ros/2.9/ip/nat.php
that includes port forwarding, address map etc.
Znuff
Re: Utorrent
Sat Sep 22, 2007 12:14 am
or just enable UPnP
foffa
Re: Utorrent
Tue Oct 30, 2007 2:39 pm
upnp not good enough
wee need normal port forwarding
janisk
Re: Utorrent
Tue Oct 30, 2007 5:02 pm
simple NAT is the same in 2.9 and 3.0 so this manual page that i pointed earlier is still working - read that page and pay attention to destination nat and how to write destination nat rule, that is what you need.
if you do not know what is NAT and why it is needed, you have to read networking basics.
alex_rhys-hurn
Re: Utorrent
Wed Oct 31, 2007 7:48 pm
nmbugua! Are you in nairobi? I am.
Yes, you need to set up src-nat to help you with this. As per the manual page listed.
Post your configs so we can help or even send me a message offline....
Rgds
Alex
mhisword
Re: Utorrent
Thu Nov 01, 2007 8:48 pm
Example of Destination NAT
If you want to link Public IP 10.5.8.200 address to Local one 192.168.0.109, you should use destination address translation feature of the MikroTik router. Also if you want allow Local server to talk with outside with given Public IP you should use source address translation, too
Add Public IP to Public interface:
The IP 10.5.8.200 is it the one provided by the ISP. As I have a connection to my ISP with pppoe and it keep changes each time.
I used to have Masquerading, just like this one(/ip firewall nat add chain=srcnat src-address=192.168.0.0/24 action=masquerade)
After I disable the Masquerading, what should I type to get the Destination NAT with same IP table.
Users browsing this forum: hazartilirot and 24 guests
