lahoras
How I do to install a second drive for web proxy
Thu Nov 22, 2007 9:36 pm
Hello, and thanks for help me, I have running mikrotik OS on PC over compact flash and I want install a hard disk drive to be used by web proxy, must I install a drive and reinstall router OS again or simply install hard dirve and start system?.
thanks in advance.
ARIEL
maximan
Trainer
Trainer
Re: How I do to install a second drive for web proxy
Fri Nov 23, 2007 1:35 am
Install the sencond HD and select secondary on webproxy
Max
MKE Solutions > Professional Support IT (Spanish / English)
FastNetMon / FNM Manager: DDoS Detection Tools.
lahoras
Sat Nov 24, 2007 5:02 am
Maxi, thank you very much, my name is ARIEL, my amateur radio license is LU7MBE, I remember you since packet radio, very cool times!
thanks again
ARIEL
cmon69
Sat Nov 24, 2007 10:05 pm
I have a Rb532a, and I would like to attach a 7200RPM 200GB 2.5" SATA harddrive to it. Can it be done? If so where would I look for instructions on how to do it?
Christapher James Hasher
Waseca Wireless
Don't blame me, I didn't drink the cool-aide!
maximan
Trainer
Trainer
Mon Nov 26, 2007 4:23 pm
thanks again
ARIEL
Ariel: send me you msn to elmaxi[at]gmail.com. I remember those years. Look where we meet again, crazy not?
Max
lahoras
Tue Nov 27, 2007 5:37 am
Yes, TCP/IP never well dead, in a way or of the other, we will continue transmitting packets!!!
I send a mail.
thanks again.
ARIEL
roadrunner
Thu Nov 29, 2007 12:55 pm
rb532 only has the Compact Flash slot no SATA port. Compact Flash is similar to ATA/IDE but it would be difficult to arrange a power supply and adapter for a IDE/PATA hard drive. And then the compact flash controler on the routerboard probably wouldn't know how to mount the hard drive.
Instead just get a large compact flash card, 8,12 & 16 GByte cards are available. Another alternative would be a IBM micro-drive that uses a compact flash interface. Seagate also makes a hard drive in a Compact Flash form factor.
If you want a 2.5" drive you could just install RouterOS on a mini-ITX x86 system. I just use the parent proxy setting instead and point it to my Linux proxy server in my NOC with large and fast drives.
Users browsing this forum: Bing [Bot], erlinden and 50 guests
