MUM Europe 2020
ourdele
Help router board 133c configuration setting is not saving
Mon Dec 31, 2007 2:43 pm
i have two router board 133c which i tried to configure for my clients but each time i reboot the router or due to power outage, it returns back to its default setting.
Pls what can be wrong? After the settings, its works perfectly before reboot!!!!!!!!
Help
oops1180
Re: Help router board 133c configuration setting is not saving
Mon Dec 31, 2007 11:24 pm
Hi.... check your Bordar battry maybe it's over... :shock:
ourdele
Tue Jan 01, 2008 2:42 pm
Please how do i check the battery? i just ordered it newly. what can i do?
SurferTim
Mon Jan 07, 2008 10:48 pm
Greetings from Miramar Beach, Florida!
I have a set of RB133's. No battery. No Realtime clock, as it were. To get the clock back up to the correct time, I set up one of my radius boxes as an NTP server. Otherwise, you are going to be set to dec/31/1999 at 18:00 (time equiv to -1) every time you loose power/reboot.
Tanker
Fri Jan 18, 2008 4:15 pm
Try enabling NTP Client in the packages....
Reboot...
Set the NTP client to:
146.64.241.228 and,
146.64.241.229
set your system to your country clock...
enable the NTP Client... and it should synchronize the correct time.....
T
Users browsing this forum: Google [Bot] and 32 guests
